Question about Cuisinart DCC-1200 Coffee Maker
Coffee maker brews too hot
Water burns the coffee grounds and produces an unusual amount of steam when I open the lid. Coffee tastes burnt.
  • 8,596 Answers
The 1-4 setting makes the coffee extremely hot. If the 1-4 setting was not activated, make sure you are not using paper and permanent filters at the same time. If you are not using them at the same time, it is time to clean the coffee maker out with 2 cups vinegar and two cups water.
-Tha Mp3 doctor
Posted on Jan 09, 2009
Jura S7 says fill tank but tank full
The brew unit is damaged and needs to be repaired.
Aug 18, 2014 | Jura Capresso Impressa S7 Coffee Maker,...
Our coffee tastes just awful no matter what brand we use. How can I clean it to get that good tasting coffee back?
remove tank from machine seperate lid from tank (remeber where everything goes and be very careful not to tear a gasket) descale with a descaling liquid or clean out what ever foriegn substance is in tank. If tank is clean then i would make sure it is getting hot enough when you brew as brewing to low will make coffee taste awful. also make sure you have a sprayhead on the machine to properly saturate all the grounds.
Sep 15, 2011 | Bunn VPR Coffee Maker
I put in 6 cups of water and only 5 cups brew. It
The amount of water you put in the carafe isn't the same amount you'll get out of the coffee maker, as some of the water is normally lost as steam vapor during the brewing process.
I would also look at the water level gauge inside the reservoir or on the sight gauge to make sure I have added the right amount to make the amount of brewed coffee I want.
As to the filter pre-soaking issue, it shouldn't matter since you likely made several pots since then and the filter has likely expelled any residue already. I would run a full pot of just water with a filter in the basket, just to see if you're getting a full carafe after brewing, making sure you have a full reservour to begin with.
As to the grind of the coffee, I find that a medium coarse is best for all but expresso coffee. However, you might want to experiment with your grind settings until you find the setting that makes the coffee to your likeing and taste. Coffee is all about what you like to drink, so take some time to find what you enjoy.
I use a high-end filter for all my drinking and coffee brewing water to get the best possible taste as it does make a difference.
My nieighbors have the same coffee machine and use the same coffee brand, etc., but don't filter their water. They've noticed the difference and always comment that they need to get a filter for their water.
When I run white vinegar thru my machine, I always run at least two (2) full pots of plain water thru the unit before I start making coffee again, to rid the reservoir of any vinegar residue.
Hope you find this helpful and best regards!
Aug 06, 2009 | Cuisinart DCC-1200 Coffee Maker
General question about the Mr. Coffee Espresso ECM10
Greetings!
Put desired amount of water in resevoir (plus a little extra to be used to steam your milk for latte) and close up tightly.
Put espresso grind coffee in basket and tamp down with a tamper. If grounds are not packed, steam will seep through and will cause an erosion of sorts instead of just letting the steam hit the grounds.
Put the basket with handle group in recess rotating to the right as far as it will go.
Rotate the ON/OFF switch to the symbol for "Brew" until you get out the desired amount of espresso.
Then, take a caraf of milk and immerse it with the plastic black steam arm. Rotate switch to "STEAM" and froth milk. In the beginning, ensure that you have enough water for the espresso AND enough left to froth without having to shut off machine, refill with water, just to froth.
Be careful when you open the water resevoir cap after brewing because there is a vaccuum created and a burst of steam will shoot out the lid and may burn you.
The gasket above the grounds hopper eventually will deteriorate and more steam will escape than espresso is produced. There is no replacement parts for this machine since it was made in China according to a Mr. Coffee representative that I called this morning at 1-800-MR-COFFEE (800) 672-6333.
Good luck with your machine. Hope this helps! If you don't have a tamper for the grounds, I found one at Bed Bath and Beyond. It is stainless steel with 2 sizes. The smaller size works for this model.
Jan 17, 2009 | Coffee Makers & Espresso Machines
Filter basket opening during brewing
Push the permanent filter's basket handle all the way down and then reclose the filter basket drawer lid. There is a pretty flimsy piece of plastic holding it in, though - may require replacement.
Sep 06, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee tastes burnt/No steam for froth
I don't know about the burning business but I had the same problem with the steam wand. the first thing I did to solve this problem was to take small object like a needle or safety pen and insert it into the base of the steam wand. (I have feeling that most problems related to the steaming wand are due to deposits clogging the wand itself.) After I cleared out as best I could I used vinegar and water to help remove any calcium deposits. Sure enough, after inserting the needle into the wand steam began to flow again.
Feb 26, 2008 | Mr. Coffee ECM10
so i guess our expresso you dont have that creamy topping that lack pressure descalcify not with vinegar remove caicium in chunks have a chance of blocking everything descalcifier solution melt the calcium 1part solution 1 part water fill the water with solution open the valve if some come out close it leave the solution in it for 15 minute repeat untill empty rinse very good cheers
Feb 03, 2008 | Mr. Coffee ECM20 Espresso Machine
Cuisinart DCC-1200 Coffee Maker Logo
366 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
