Question about Sony VAIO VGN-FS980 Notebook
SONY VAIO VGN-FS980 Battery does not hold charge
My battery lasts for less than 5 minutes - any suggestions? It is not a part of the recall program and I understand there may be different ideas to get it to restore a partial charge before I incur the cost of a new one...
THanks in advance,
s
  • 4 more comments
  • cford31 Nov 07, 2008
    Did you find out a solution for this besides buying a new battery?
  • Anonymous Dec 19, 2008
    my battery also does not hold a charge
  • Anonymous Jan 18, 2009
    two years old holds charge with minimal screen brightness, wireless networks off, and muted sound for about twenty minutes. Really the only option without getting all electrical or dangerous is to buy a new one but you can find the same model battery with more mAh and have a long life. The higher the mAh the longer the battery will last.
  • internetmail Mar 04, 2009
    no solutions yet on the battery, should be able to get it to hold a charge, it is a rechargeable lithium-ion battery - and yes I know batteries often die but with the overheating issues etc - just thought I might gain some insight.
  • Dan
    Dan May 11, 2010
    how old is your laptop? Laptops in general are not known for long lasting batteries.
  • internetmail Dec 23, 2013
    no I didn't. still curious. did get a new pc :)
Sony vaio vgn-nr285E battery won't hold a charge
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 03, 2011 | Sony VAIO VGN-NR285E/T Laptop
Sir, my name is RAJ. i am use to sony vaio laptop model no VGN-FS980. sir my laptop all divers is format so pl kindly info other vise forward to all divers. Thank you.
Hi! Welcome to www.fixya.com.
You can download the all the drivers of your Sony VAIO-FS980 PC notebook. Here is the link: http://esupport.sony.com/perl/swu-list.pl?mdl=VGNFS980
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 18, 2011 | Sony VAIO VGN-FS980 Notebook
My "sony vaio vgn txn15p"
if your Sony is older then 3 yrs I urge you to get a new battery. Make it last longer by draining the battery and charging it up everyday. This gives it a work out and helps it not get lazy.
May 02, 2011 | Sony VAIO VGN-TXN15P/W Notebook
Sony Vaio VGN SZ491N doesn't start or boot. No lights no noises. Tried holding start button 10 seconds, tested power supplies (OK on other machines), been having a problem with the battery being loose...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. The DC jack might be loose or broken. It might need to be either re-soldered or replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Sep 17, 2010 | Sony VAIO VGN-FS980 Notebook
My sony vaio VGN-FS980 PC Notebook wont shut down gets frozen at the windows is shuting down screen
yah i dont know waht your question is but try unplugging the power and taking out the battery or hold the power button down till it turns off
Apr 06, 2010 | Sony VAIO VGN-FS980 Notebook
Hi, I am looking for better battery for my sony
Hello there if you get a battery make sure that it is
a Lithium ion type battery they give the best run time
and it takes less time to charge the life time is also longer
best regards michael
Sep 23, 2009 | Sony Vaio VGN-NR110E/S Notebook
Can I run a Sony Vaio VGN-FS980 laptop closed?
You should be able to go into power management utility whether it be sony or Windows and change the "when lid is closed" option from hibernate/shutdown to "do nothing"
on XP
CP>Power Options>Power Schemes
Jun 10, 2009 | Sony VAIO VGN-FS980 Notebook
My laptop battery is discharged quickly
batteries will decrease overtime, it may just be time to replace the battery. if you have had this unit for a while it may be time.
Apr 10, 2009 | Sony VAIO VGN-FS980 Notebook
Sony VAIO VGN-FS980 Notebook Logo
414 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
