Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
Hoover Windtunnel Bagless bolt fell off
My one month old Hoover Windtunnel Bagless vacuum started making this loud awful sound then started smelling. After unscrewing the four screws over the roller I found a bolt that fell off the wheel holding the thick belt. The belt was split and the plastic was melted. I can't figure out how to put the bolt back on. The angle is wrong and I cant get my fingers or any tool in there to put it back on. Help.
  • 294 Answers
With this self propell series, the entire bottom needs to come apart to re-install the nut. if it is one month old I would highly recommend taking it in for warranty service. What plastic is melted?
Posted on Jan 20, 2009
Hoover vacuum started smoking
Sounds like the roller became stuck and the motor burnt the belt into. I worked on Hovers for years and that is the most common problem.
Apr 02, 2014 | Hoover U5750-900 WindTunnel Bagless...
Hoover beater bar is loud & vibrating.
brush roller /agitator needs replacement. part price : $25.00 to $ 30.00
May 06, 2010 | Hoover U6630-900 WindTunnel Bagless...
Hoover U5780-900 Windtunnel a month 1/2 old just started stopping when it is running and wont turn back on for a few hours why?
The motor has a thermal protection sensor on it. So your motor may be going bad, it is pulling to many amps for some reason, could be a clog somewhere or a bad bearing in the motor.
Feb 21, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
I've had the Hoover Windtunnel for a couple years now. Its starting to smell when you vacuum. Why and how do I fix it???
I was experiencing the same problem right after changing the belt for the first time, as my Hoover is just a few months old. I am assuming what you are smelling is burnt rubber, like your belt, right? Well, if you have changed your belt recently, make sure you are using the right one. If you're not using Hoover's authentic belts and you're buying it from Wal-Mart, make sure it's the correct one, otherwise it won't work right and/or it will give off a burnt rubber smell. One other thing you could try doing first, is raising the carpet height adjustment up a notch or two. If you have it too low and your beater-bar/brush roll has to work too hard, it will start to smell also.Good luck!
Aug 07, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Vacuum Cleaner Bad Smell
change filters. the filter inside the unit and the one on the side needs to be changed once a yr. (these are not to be washed, only the side filter if foam can be washed ). also flat belt change every 6 months and the v-belt once a yr.
Jul 19, 2009 | Hoover U6616-900 WindTunnel Bagless...
Burning smell coming from vacuum
use a penny to turn the 2 screws on top a quater turn then fold down the vacuum and lift up the cover and you will have access to the belt. Clean the small hepa filter with soapy water. their may be 2 of them. The cannnister filters need to be shaken but not washed. Good luck.
Apr 09, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover wind tunnel u5755-900. smoke, smell. self-propel
Can you verify the model number? However, based on your posted description, it sounds like the flat belt is either broken or fell off. to access the belts turn it over and remove the bottom plate (4 screws). the Flat belt will connect to the motor shaft in the back and the large black pulley.
Mar 13, 2009 | Hoover Self-Propelled WindTunnel Bagless...
My Hoover bagless vacuum starts to smell like something's burning
What does it smell like? If it smells like burnt anything-it could be that the fan is broken and lodged in the motor. You can see if the fan is good just by looking into it.
Mar 13, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover Windtunnel
Sounds like you have a bad brush roll(48414115), take it out and see the the ends turn freely or not, if not, then replace it. Also check the the slots that the brush roll sits in to make sure they haven't melted. I am assuming that the motor is running, if not, then it may have froze up.
Feb 28, 2008 | Hoover U5753-900 WindTunnel Bagless...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
147 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
