Question about Amana ACF3325AS Dual Fuel (Electric and Gas) Kitchen Range
Control panel stuck om 5 Ab and does not work
This is the Amana with electronic starter for gas cooktopp and oven.
    President:
  • Amana Master
  • 2,651 Answers
Youve somehow had the oven enter a Sabbath mode SAB if the code
Sabbath mode can also be cancelled
by pressing and holding the 8 key for 3
seconds
http://www.servicematters.com/maytag_library/docs/S231_5R0.pdf
hers a link to a manual check page 14 for your problem explained
Posted on Nov 03, 2008
1.Our gaz range (with electronic range control) Amana ACS3350AS oven bake works normally at 350 F for 40 minutes, then stops. While the broil can still work at this point, it's likely the Oven - High...
Works normally for 40 minutes? Then after she cool down will work again? Let me look un momento mon ami. Aha Your temp sensor might be faulty,
Another thang it could be is a weak ignitor,
An oven limit would shut down and NEVER come back to life. It ain't gonna be no limit er fuse.
Basic American oven fault codes and more HERE
Feb 11, 2011 | Amana ACS3350 Gas Kitchen Range
Amana oven AGDS902SS started beeping and showing a F1 error.
F1=Electronic range control failure
It is telling you may have a fauilty control...need to replace control or EOC.
If you are an novice working over the control board. please do take the help of an authorised technician doing that.
Mar 02, 2010 | Amana AGDS902 Gas Kitchen Range
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Digital display is flashing F 5 and won't turn off
maybe you need to replace the electronic range control
Jun 22, 2009 | Amana ARGS7650SS Gas Kitchen Range
Bad electronic contral panel on Amana gas range
On the Amana: Several Ebay stores carry panels like this. Problem is, once you open electronics they usually are hard to send back.
The stove is ten years old. You'll likely spend more than it is worth finding the right part and repairing it. It might be a good time to consider buying a new stove and selling this one for parts or scrap.
May 11, 2009 | Amana ARGS7650SS Gas Kitchen Range
Our Amana AGDS902 Gas Kitchen Range is beeping and flashing an F7 error code. We have found solutions for other Amana ranges online, but none of them seem to be for our exact range type. We can stop the...
AMANA – Range/Stove/Oven Fault Codes
Glass link Electronic Range Control (ERC)
F7=Shorted touch panel Verify glass to adapter board connection good, if so, replace glass panel.
Dec 02, 2017 | Amana AGDS902 Gas Kitchen Range
Amana ARGS7650 Keypad has no power
I had the same problem, same model. The electronic panel has to be replaced. This part is ~$215 before tax and shipping. With labor, I was looking at over $400. I bought a 4 yr old used GE gas oven for $75. That was my solution.
I believe the part to replace is labeled Erciii, gas
Part Number: AP4041311 made by WHIRLPOOL
This would have taken at least a week to ship (no one seems to have them in stock).
From now on, I will never own a range in which the oven or stovetop controls are electronic. Knobs and associated mechanics can be replaced MUCH more easily and cheaply!
Dec 01, 2008 | Amana ARGS7650SS Gas Kitchen Range
Amana gas range
the only f5 code listed for the amana range states faulty erc(electronic range control) solution replace control
Feb 19, 2008 | Amana ARGS7650SS Gas Kitchen Range
Amana Convection Wall Oven Model AOCS3040 Does Not Heat in any Mode
sure its possible, sounds like you've blown an over limit thermostat behind stove, gets too hot and for safety reasons cuts off unit untill replaced
Feb 11, 2008 | Amana AOCS3040 Electric Single Oven
Amana ARGS7650SS problem
try this site - repairclinic dot com. there are some helps about where the screws are to remove the control panel.
Aug 21, 2007 | Amana ARGS7650SS Gas Kitchen Range
Amana ACF3325AS Dual Fuel (Electric and Gas) Kitchen Range Logo
279 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
