Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE Profile Energy Star Refridge...
I have the above 3 y/o fridge. Lately it seems to be limping along. The freezer doesn't seem to get cold enough to make ice and i've noticed things starting to thaw slowly. I put a dish of water in it last night and this morning there was a thin layer of ice on top but it should have been frozen solid. The refridge side also seems to be a bit warm for the temp setting it is on. I hear the fan (or compressor-or whatever) so its not completely dead. I'm wondering if before i call for service if there isn't something obvious i could look at. I don't know crap about this kind of thing. Any help would be appreciated...
  • robert thompson Sep 26, 2006
    thanks for getting back to me. I'll check all that stuff as best i can when i get home. I did notice a small amount of frost on the very back wall of the freezer...but nothing like the oic you've attached.
  • pgbsrmac Jun 23, 2008
    My fridge was left open for approx. 15 hours and now it doesn't seem to be getting cold. The temp has been set to 37 degrees but hte fridge doesn't seem to be getting colder. My freezer is also running at 17 degrees as opposed to zero degrees. What can I do? Thanks for your help
    Paul
    President:
  • 878 Answers
Brookid, first you want to start with the basics; door seals are good, light turning off with door closed, dispensor duct door closing all the way, condensor coils cleaned, evaporator fan and condensor fan are running. If you are satisfied that there are no problems here then you want to see if you have a heavy frost build-up on the back of the freezer panel. If you do, you have a defrost issue that usually involves the defrost heaters, main board or freezer thermistor. Tests will have to be made on the main board to determine these. If you don't have a frost build up, you need to check the airflow vents from the freezer to the refer compartment. I will attach a photo of a refrigerator with a defrost problem. Catriver...post back.
Posted on Sep 26, 2006
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Freezer thawing and refreezing ice into clumps
The defrost is sticking and staying on for too long...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 28, 2011 | GE Profile Side-By-Side Refrigerator with...
Freezer works but frigde isn't working
once ice forms on the freezer coils there is no air flow. I had the same thing. I suspect your defrost cycle is compromised. Could be the bimetal switch, defrost timer or defrost heater element.
Nov 25, 2017 | Pds GE Profile Bottom-Freezer Drawer...
Refrigerator cool freezer not as cold as it should be
try turning of the frige and let it be of for 1day then put back on and see if will works usally does,if not next usally is the compressor does give enough cold.motherboards dont go bad usally very rare,check all the above before you buy motherboard.please leave comment,vote,note.thankyou
Sep 13, 2009 | GE Energy Star 22.0 Cu. Ft. Side-By-Side...
GE Profile PSS25MGMB is too cold
After viewing the pictures of this part on this web-site - I took this part out of my refridge to see if the door was stuck closed or stuck open ( closed = fridge too warm and stuck open is too cold - my problem). The door within this part was broken off the hinge. I took this part apart - styrofoam and tape - and glued the door back together and in place with 2 part epoxy. I reassembled and everything seems OK now.
If this begins to happen again - I will probably just order a new part.
I think it is outrageous that a $700 fridge's performance is regulated by a cheap 50 cent piece of plastic. Spend another dime and make this piece glavanized aluminum? or other material that does not dry rot and holds up in cold dry environments.
Apr 08, 2009 | GE Refrigerators
GE Refrigerator cooling system problem
My guess is that you need more refrigerant gas. It may also have a problem with the auto defrost system for the freezer. You have a block of ice in the evaporator instead of clear fins for the air to pass through. Make sure the door is correctly closed and that the magnetic door gaskets are in good condition. Once those are fixed you can turn the thermostat to make the fridge a bit warmer. Another possibility is that the circulation fan in the fridge has failed. Cold air falls to the bottom which is why your veg is freezing. You can't work on refrigeration gas yourself anyway, so call an engineer. Correct diagnosis of the fault will be cheaper.
Google
'<your city> GE refrigeration service'.
Dec 06, 2017 | Pds GE Profile Bottom-Freezer Drawer...
Removing freezer drawer
my son fixed it - thx. problem solved
Nov 23, 2008 | Pds GE Profile Bottom-Freezer Drawer...
Ge side by side not cooling enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting,
Sep 07, 2007 | GE Profile PSS26NGS Side by Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
154 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
R.A. Ellis
R.A. Ellis
