Question about JVC GZ-HD3 HDD HD Camcorder - 60 GB USB Hard Drive
Can't interface with my computer
I can't seem to get any software (even the programs on the disc that came with the camera) to recognized when the camera is plugged in. The programs open, but tell me the camera isn't plugged in. The USB cable tha came with it doesn't actually fit the camera (but it WAS an "open box"). My firewire all plugs in fine, but none of the programs seem to be able to find the camera.
  • fifeautosale Dec 09, 2008
    i have the same problem, i've even purchased pinnacle 12 with no luck...
If you put your camera in DV mode instead of CBR 1440 it will be found. Good luck
Posted on Jun 04, 2009
I have a new fuji finepix z70 camera i have followed instructions but no photos come up on laptop
Have you tried transfer to computer using a card reader ? If not transferring directly from camera it is more than likely the Fuji drivers are not correctly installed remove drivers and reinstall (check for correct drivers PC or Mac) Have you tried on another laptop? I would say it is more than likely a software problem. If still not working send details of you computer operating system and camera model number please.
Dec 29, 2010 | Fuji Cameras
Canon EOS 1000D will not connect even with solution disc instaled
To find out if the computer recognizes the camera, go to start>computer and see if the camera is listed. If it is, you can double click the icon to open it. Double click on the folder(s) until you get to the pictures. Click on the first picture, scroll down to the last picture and while holding down the shift key click on the last picture. Now right click on the pictures and you will get a menu. In Vista you can select copy or move them to a folder. In XP you will have to select send to>documents then move them to a folder. As for the program you installed, if it didn't leave a short on your desktop, go to start>all programs and look for it. If it's not there, it probably didn't install correctly.
Jan 21, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
My macbook wont recognize my hp camera, i installed the software that came with it but it still wont even recognize that its even connected.
your camera should work fine with the built in iPhoto software, simply launch the program and connect your camera, you should be able to download your pictures immediately.
Feb 22, 2009 | Apple iMac 24" Desktop
Compter does not recognise software when installed
You didn't mention what kind of interface you are using but USB is the most common.
I would recommend removing any trace of your camera you find in the Scanners & Camera folder of the control panel.
Have your camera attached to your system and restart it.
Windows should recognize the 'New Device' and may install the standard driver by itself. If you are given the option of of "Install from Disc," insert your installation disc at that time and continue.
Windows should locate the proper driver from the disc.
If you are still having problems, give us a shout back.
Jun 26, 2008 | Fuji FinePix F10 Digital Camera
Neither Vista or XP will recognize the miniDVD's from my camcorder.
You have to finalize the disc in the camera before you can see it on your PC.
Jun 13, 2008 | Hitachi DZ-MV730A DVD Camcorder
Connection between camera and computer
What operating system are you using? Is you camera connected via USB? Have you tried using another USB port? Did you make sure to install the software before plugging in your camera?
Generally if you are running Windows 98, you will need to reboot after installing the software to even have a chance of the camera being recognized correctly.
If you are running Windows 2000, XP or Vista, the camera should be recognized and a driver installed or searched for from the CD software you installed before plugging in the camera.
Sometimes if you plug in the camera first without installing the software, the PC finds a new device with no driver. You can see this by going to Control Panel -> System -> Hardware -> Device Manager and you should see and exclamation on a device in the list. You need to remove this item and reboot your PC.
Now install the software first and when the install is done, then plug in your camera. Generally this works out pretty well.
Apr 29, 2008 | Canon PowerShot A80 Digital Camera
Canon MP830 wont scan
you have to use other programs such as photoshop to use the scanner
Mar 28, 2008 | Canon PIXMA MP830 All-In-One InkJet...
EZ201 Rca Small Wonder Camcorder
Make sure you have the latest version of USB on your computer. I just purchased a Small Wonder EZ101 on ebay and it connects to my laptop without a problem.
Jan 12, 2008 | RCA EZ 105 Camcorder
Not acquiring pictures with any software
don't think it was the cable, they are a standard usb interface cable.
Had a similar problem, when I installed software for a new camera interface.
you can manually open the cannon software once the camera is hooked up to your computer. Its called "camera window" default install is start>all programs>cannon utilities>camerawindow>poweshot>camerawindow
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Software not being recognized
The software on the CD is slightly outdated. Here is the driver download page for your camera: http://alpha02.c-wss.com/inc/ApplServlet?RQF=MENU&RQS=WWUCA910&LA=1187365946277&SV=WWUCA1351&TRF=MAIN You probably don't need the drivers, but they're there if you do need them. What you do need is "ZoomBrowser EX5.8b Updater for Windows" Although it says it's an updater, you can use it even if you aren't updating anything. This includes CameraWindow, and all the software that would be on your CD.
Aug 17, 2007 | Canon PowerShot A630 Digital Camera
JVC GZ-HD3 HDD HD Camcorder - 60 GB USB Hard Drive Logo
226 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
