Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Too much wate flow into icemaker
I think too much water is flowing into the ice maker. water overflows and spills into the freezer freezing everything. what controls the amount of water flowing into the icemaker??? the icemaker does make ice but the exceswater spills into the freezer making a frozen mess.
  • 9 more comments
  • zerogee Nov 03, 2008
    I forgot to add this is a Kenmore model 106.955761
    no it is not leaking. the ice tray is full of water and freezes that way. it is just putting too much water in the tray overflowing.
    what controlls the 4oz of water??? the valve or something in the icemaker?
    i just did a test. i placed a 16oz bottle over the in-fill tube and it almost completely filled the bottle. i would say it has 12oz of water. so back to my orginal question, what controls the water valve, something in the icemaker or is the vavle set to deliver a set amount of water only???
  • jonesteague Nov 06, 2008
    Mine does the same, but I was wondering what controls the valve opening and closing, a timer?. If the valve was not closing completely, wouldn't it leak through all the time?
  • zerogee Nov 07, 2008
    well i changed the water valve but it still is putting out too much water. so, what is my next option??? buy a new icemaker??? is there any way to reset the icemaker?? i would really hate to buy a new icemaker when that one is working ok execpt for the water. i'm open to any suggestions??
  • Anonymous Nov 12, 2008
    For the past 2 weeks the ice cube molds have been over-filled, the extra water has been freezing in a cascade form into the ice holder. The amount of extra water has gradually increasing. Where is the timer forthe water inlet valve?
  • teddybear39 Nov 17, 2008
    leak water and over flows everwhere
  • ricardoroth Nov 26, 2008
    My Stainless Steel Kenmore does the same thing. How do you replace the wtr valve?
  • cryder44 Dec 23, 2008
    model # 9515511 Kenmore Coldspot-- Icemaker quit working, and I took cover off, tapped the wheel and it started turning. Everything worked fine until it was time for the water filler to fill tray up again. It started filling and wouldn't stop. I had to tap (lightly) the wheel again, and it proceeded to stop the water and act normal. Whats the problem?
  • TerryBagby Dec 28, 2008
    I just put on a new water valve, and now get too much water in the tray each cycle. The rest flows into the tray and freezes all the ice together. How do I control the amount of water? What makes it shut off when full?
  • Debbie Jan 14, 2009
    I have an older Kitchenaid fridge, and the icemaker just started doing this same thing. . .too much water in the cube tray, so the ice doesn't pop out more than once or twice a day, and when it does, new water overflows and runs into the rest of the freezer. If you can figure out what the problem is, please let me know, as I don't really have the money to buy a new icemaker at this point. Thanks~
  • 120 Answers
It over filling or it leaking from the mold i never seen thi model over filled mold when i see wtr in bin is usually the mold that is leaking you can check with a mirror or remove to inspect is texture is peeling off repl entire ice maker if is ok then repl wtr valve is not closing when it has filled the mold you only need 4oz of wtr
Posted on Nov 03, 2008
  • Rosendo Madero
    Rosendo Madero Nov 05, 2008
    repl the wtr valve
  • Rosendo Madero
    Rosendo Madero Nov 06, 2008
    zerogge it looks like the wtr valve is not closing on time repl it it should only stay open long enough to fill mold with 4 to 5 oz no more than that
Water flows into ice maker when water lever is pushed
Be sure that you have the water inlet valve wired correctly.
Nov 26, 2012 | Refrigerators
Icemaker clogs with ice. Water flows with icemaker unplugged.
ur solenoid could be allowing water to flow freely its in the back its blue try replacing this solenoid and see if this fixes the problem they r cheap and easy to change
Feb 27, 2010 | Amana ARSE67RBB / ARSE67RBW / ARSE67RBC...
Ice in freezer bottom
2 things:-1)Freezer door does not close completely, leving a gap allowing outside air to come in and te humidity causes water to freeze at the bottom of the freezer. This would explainwhy is forming over 2 days.
2)If your fidge has a ice maker in the freezer and a cold water dispemser, the both these compartments water flow for the ice &for dispenser are controlled by a solenoid valve, which in turn uses a sensor to detect the quantity of water in the ice maker trays and switces off the wster supply appropriately. If the sensor in the icemaker fails to detect the right quantity, overflows very slowly so as to appear to be noticeable..............sdeep
Sep 03, 2009 | Refrigerators
Freezer and icemaker freezes, jams.
I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
May 01, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Adjusta cube ice maker spilling water
check at the back of refrigerator were water line comes in see if there have eany hole or check your freezer may be it (ajar)
Apr 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water over flow
Depends on the model. It could be a water switch that is sticking or a motor in the icemaker running to slow. My advise is to replace the faceplate of the icemaker. Part #150
Jan 16, 2009 | U-Line Icemaker
Too much water getting to ice maker
The little cup that sits in front of the hose that dispenses the water, has frozen water in it . Check that first and if it's OK, then there is a small screw that you can adjust, look at your manual.
Nov 03, 2008 | Kenmore 53642 / 53644 Side by Side...
Water wont flow into LG LX259602b ice maker
You may have a bad water valve.  The valve has 2 sections, one for the water dispenser and the other for the ice maker.  Check those connections in the back of the refrigerator.  If everything is ok, replace the water valve.
May 18, 2008 | LG LRSC-26922 Side by Side Refrigerator
Ice maker overflows with water
yes, in fact the icemaker does meter the amount of water delivered to the icemaker, the valve should only be energized for 7 seconds. after that the power is cut off, so if valve continues to let water flow, it's bad (might have debris from water line keeping it open. unserviceable. )
Mar 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
541 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
