Question about Neff H7871A2GB 800 Watts Convection / Microwave Oven
Power but no display to unit
Neff H7871. Replaced part numbers: 268692 (module power) and 268690 (display module). There is AC power to the unit but the unit appears 'dead' with no display lights. Does anyone have a wiring diagram or ideas on how to fix it please?
  • Neff Master
  • 9,156 Answers
Not sure about the Neff brand, but in general you'd want to check for 110VAC power on the primary side of the low voltage transformer on the control panel / board. If that is present, check the secondary for voltage, about 12-30VAC. If the unit has a VFD type display, there will be a heater filament supply, usually around 2.5-6VAC. Also look for bad connecitons on the VFD. If those voltages are present, check connections on the board, look for bloated / bulging capacitors, shorted diodes, breaks in the board, etc. Also look for thermal cutouts and thermostats. If this doesn't fix it, can you take several photos of the inner parts and circuit boards?
Posted on Nov 01, 2006
Hi getting an error 4 on a Neff oven/microwave. any ideas out there
make this and fix it. God bless you
A power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
Nov 02, 2013 | Neff H7871 Convection/Microwave Oven
Neff H7871 oven door does not stay closed. Catches do not appear to be working
The door latch is either cracked or broken.The door when gets closed the door latches clicks.But if the door latch is loose or cracked it will not click and door will not close.The door needs to be disassembled and the door latch has to be replaced, if the latch is cracked.Also to check the latch from inside the door needs to be removed.-------- This will help.thanks.Helpmech.
Jun 29, 2011 | Neff Microwave Ovens
Sparking at the ceramic bush just above the microwave stirring blade on a neff h7871 built in microwave
If the ceramic bush, that is a good insulator of electricity, is arcing. Maybe it needs cleaning.
Apr 04, 2011 | Neff Microwave Ovens
Replace light bulb on the Neff H7871 combined oven and microwave.
The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
Mar 17, 2010 | Neff H7871 Convection/Microwave Oven
Neff microwave h7871 arcing
This antenna is called the stirrer here in the US. Its purpose is to stir the microwaves to ensure even cooking.
The cover is usually made of plastic, as opposed to ceramic, and it keeps grease and food particles off the stirrer to protect it from arcing, which can damage the surfaces and the magnetron.
The stirrer, stirrer cover and the area around it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available in appliance parts stores and hardware stores.
Also, the stirrer will arc if it is not turning when the oven is cooking. That may mean a bad stirrer motor.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron and stirrer.
You can download Neff manuals here.
Even if you don't find your exact model, they should all have contact info for Neff in case you need to call them to get spares / parts.
Dec 13, 2008 | Neff H7871 Convection/Microwave Oven
Neff H7871 inner glass broken
Hi, I am having a same problem I have managed to order theglass from:-
http://www.4neff.co.uk/cgi-bin/product.pl?PID=876912&query=Neff%20H7871N1GB%2f01&model=H7871N1GB&path=127858
1. Open the door.
2. Take out the 2 screws just behind the handle, on the inside of the door, thedoor should flop down at the handle end.
3. Hold the door handle and pull the door out. It is only housed in by a slipin hooks at the bottom end.
4. Once you remove the door you will see the inner metal mesh and the inner doorbehind it.
5. Remove the 16 screws holding the inner glass with a special star type screwdriver bit no T30.
6. Once you done that the glass housing holding the inner glass can becarefully prised free and taken off the inner door assembly.
7. Once you done that remove and inner glass, and be careful to leave the glassseal intact, clean around the frame housing and the seal then replace the newinner glass and reverse the process.
PS. Be careful of the inner door once you've removed the outer door, asthe hinges holding the inner door tend to shut quickly as there is less weighton the hinges.
It will do the job if you follow these instructions. AL (srahbah@hotmail.com)
Dec 05, 2008 | Neff H7871 Convection/Microwave Oven
How to remove door on neff H7871
You can find diagrams of Neff microwaves here.
Maybe they will help.
If not, try their spares shop.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 09, 2008 | Neff Microwave Ovens
Neff h7871
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Jul 06, 2008 | Neff H7871 Convection/Microwave Oven
Neff combi blown diode.
If the diode failed by opening, there may be no other damage. If the dioded failed by shorting, the alternating current may have damaged other components. Ohm it out. You can get diodes from digikey.com, mouser.com, or radio shack or any electronics or appliance supply. If the diode is charred and you can't get the part number, the oven rating can be used to select a replacement. Since the fuse was 10 amps, the diode should also handle at least 10 amps. If you can power the unit and read the voltage at the diode input this will give you the power (volts times amps). It's always worth trying as it's cheaper than replacing the unit.
Oct 14, 2007 | Neff H7871N2GB Convection / Microwave Oven
Power Problems on NEFF H7871 Combi Microwave
It would seem there is a bad connection in the fuse holder or in the wall socket or in the microwave itself. Maybe you can narrow it down to the microwave by trying other devices in the wall socket. If it's the microwave, it's time to call for serivce.
Dec 11, 2006 | Neff H7871N2GB Convection / Microwave Oven
Neff H7871A2GB 800 Watts Convection / Microwave Oven Logo
548 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Bob Farthing
Level 1 Expert
Jaime Hernandez
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
