Question about LaCie F.A. Porsche (301177) Hard Drive
Lacie not working
My light was flickering on my lacie. And then when I plugged everything back in correctly, I am getting nothing. No light. The usb is plugged in and both plug ins seem ok?
Before going crazy REPLACE THE POWER CORD AND THE CRAPPY CHINESE TRANSFORMER!!!
I could not believe it - I took the drive at the office, plugged it to a different computer using the power cord from another lacie drive and it just worked! Perfectly! For a good four hours, more than enough to transfer all the files on other drives!!!
What sounds like a joke now is the PORSCHE DESIGN label - porsche my foot sir! And this comes from a designer!!!
Posted on Nov 20, 2008
  • 95 Answers
Does your drive make any unusual sounds like any of these: http://datacent.com/hard_drive_sounds.php ?
If yes then you got a problem - it's something mechanical with the heads.
If it sounds normal or doesn't spin up at all - try to connect it to another computer and if still no go - remove the internal drive from enclosure and connect directly to PC via SATA port.
Posted on Nov 11, 2008
Power Light comes on, no function what so ever
Check to make sure that the FireWire or USB cables are
correctly attached and firmly seated in both the drive and
computer's FireWire or USB ports. Disconnect them, wait 30
seconds, and reconnect them. If the drive is still not
recognized, restart your computer and try again. If they are
correctly connected and your drive still does not power on,
trying using the optional power sharing cable, described in
section 2.3 Connecting the Optional Power Supply of the LaCie Mobile Hard Drive User Manual.
Feb 17, 2013 | LaCie Computers & Internet
When my computer is in sleep the blue light on my lacie turns off, and then it will flicker and then goes off again and it will continue doing this
Probably due to sleep mode. The computer will power off things such as USB ports. You can disable "Allow the computer to turn off this device to save power" under Power Management tab in Device Manager on each "USB Root Hub". Not sure if there is an equivalent on Mac
Feb 01, 2013 | LaCie Computers & Internet
Hard drive is not recognized on my computer now and just has a flickering blue light .The system is vista and when it was removed and another lacie hd i have it works on the power lead and usb lead that...
The flickering light signals that the internal controller board has failed. Unfortunately this is terminal, the external case is dead. If you're really lucky the hard drive inside it still has enough life left in it to allow you , when connected directly to a desktop, to copy all your files from it.
After that just junk it and get a new one.
Apr 13, 2011 | LaCie External USB 2.0 500GB 7200 RPM 500...
We understand that your problem is: We understand that your problem is: Hello, I have Lacie porsche external hard drive. I also have a seagate firewire external drive which us working fine. Unfortunately...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 18, 2010 | LaCie F.A. Porsche (301177) Hard Drive
Whenever I plug the lacie hardrive into my computer nothing happens on the computer but a red light turns on and flashes on the lacie
If it still has a valid warranty, exercise the warranty to get a free replacement.
Otherwise, open the enclosure, and separate the disk-drive from the USB-to-disk-drive adapter, and connect the disk-drive as a 'slave' disk-drive in a desktop computer, to see if the adapter was the problem.
Oct 26, 2010 | LaCie 301103U 500 GB USB 2.0 Hard Drive
My 500GB LaCie will not power up
that is an external drive correct. It should run just off the usb. is the drive recognized ?
Robert
Aug 27, 2008 | LaCie d2 Extreme (300793U) 500 GB Hard...
LaCie Big Disk
Fixya is unable to suggest parts sources.
Dec 17, 2017 | LaCie 301294U 1TB Big Disk Extreme + with...
LaCie 250GB: Power (blue) light flickers when pushed, nothing happens
Sound very much like ypur disk is fried. Slim to zero chance of recovery.
Aug 26, 2017 | LaCie Big Disk (LAC300966U) 1024 GB Hard...
Lacie hard drive nonfunctional
I ran into this issue this week with my lacie big disk 500G external. Unit would power on when plugged into a pc blue light would flash and nothing no connection ding from windows.
Blue front light would flash repetedly slight ticking sound from drives but no connection i finally fixed this and gained access to my data by opening up the case and pluging my pc 12v connectors into both drives to power them up but leaving them connected to the lacie internals worked instantly and ive since copyed all my data off my 500 and will just transplant the drives to internal use on my pc. you cannot connect the drives internally and then copy the data due to the fact that they are raid 0 stripped drives so this hybrid setup works if your external case isnt powering up the drive correctly as mine wasnt.
Mar 02, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie F.A. Porsche (301177) Hard Drive Logo
594 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
