Question about Mitsubishi WS-55809 55" Rear Projection Television
Distorted picture my picture on the 55 inch mitubishi seems bo bow. I some times fix this problem by turning the tv on and off several times. sometimes this works and sometimes it doesnt.
    Sergeant:
  • 337 Answers
It seems you have a loose conection in the Horizontal deflection circuit,I will start checking the horizontal driver transformer then any overheated areas in the power supply and overall chassis.If you are familiar with tv service you know where to look but if you are not be safe and call for help,try no to use the set or the problem will be worst.
Posted on Sep 26, 2006
Picture is bowed and colors are not aligned
This called Projection TV convergence. Take a look on this site for a tip on Projection TV convergence.
Apr 19, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Center bow on picture top and bottom with 1" black showing
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba TN55X81 55" Rear Projection...
We have a Hitachi 53udx10b tv. Recently it was
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 05, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Sony 46 inch proj tv picture is bowed in the middle and color is
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Oct 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Picture was fine, then lines diagonally, now light
Projection sets have two very common problems outlined below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
*Screen Looks 3-D
*Colors wont align
bb0cf99.pngSOLUTION
Oct 10, 2009 | Mitsubishi WS-55909 55" Rear Projection...
I have a philips 60 inch tv with on picture and sound
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 28, 2009 | Philips 60P8342 60" Rear Projection...
Philips 46-inch Rear Projection with bowed image?? slight distortion
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jul 02, 2008 | Philips 46PP9302 46" Rear Projection...
Phillips 55PW9363
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 24, 2008 | Philips 55PW9363 55" Rear Projection...
Bowing at bottom
convergence ic bad, should also replace bad caps in DM
caps:
· http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
· http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
· http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
· http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Jan 16, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Edges of Picture & Text Sloping
This mis probably a cold solder connection in the horizontal circuitry called the pincussion. Theres a couple of coils and resistors that overheat from time to time and the solder connections get loose. Not really for a handiman has this tv has hi vboltage inside even when turned off. Shouldnt cost an arm ans a leg to fix if the repair shop knows what they Are doing. Good Luck
Jun 26, 2006 | Akai CFT2490 24" TV
Mitsubishi WS-55809 55" Rear Projection Television Logo
55 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
