Question about RCA HD61LPW165 61" Projection HDTV
Loud squealing noise first 5 minutes after tv is turned on
I replaced my lamp about 3 mths ago and ever since my tv has made a LOUD squealing sound. I took the lamp access panel off and it feels like the lamp is making the noise. Is it the fan? if so, does anyone know what the part # is? The model # is RCA HD61LPW165. Thanks
  • 2 more comments
  • gunter5 Nov 02, 2008
    I forgot to say that the squealing started out lasting for about 5 minutes after I turned the tv on then stopped. then eventually it started sporatically doing it after it had been on for a while and the picture would get distorted. now it won't show a picture at all.
  • dysang4482 Jan 09, 2009
    Please help, I have the same problem. The picture looks great but that noise is killing me.
  • Anonymous Jan 10, 2009
    I also have the same issue :(
  • yall007 Jan 21, 2009
    • I have the same problem. I've bought 2 expensive lamps, but they have not helped. The squealing is getting on my nerves. I can't afford another projection lamp. verne1231
Sounds like the color wheel. It's the only moving part in most DLP's and the bearings can go bad. If it manages to get up to speed the picture may look normal. One temporary solution may be to let it run a few minutes, then turn the set off for 10 minutes, then turn back on. When my color wheel was going bad that would often quieten it down. For the rest of the day, try to leave the set on, especially if you're only going to be away from the TV for short periods. You can turn off your cable or satellite box but leave the set on and you won't have to go through the hassle of trying to quieten down the color wheel until the next cold start. Of course the best solution is to replace the color wheel which even with a rebuilt unit won't be cheap if your warranty is expired.
Posted on Mar 12, 2009
Samsung HLR5064W DLP TV load vibrating noise like a fan blade hitting something, lamp light is one, Tv will light up but discolored
Sounds like a bad color wheel----remove lamp---the wheel faces it--look for missing pieces or the wheel shattered---these are known for the wheel making a loud high pitched sound or even a grinding sound if the wheel shatters.
if wheel bad You Tube has video instructions for replacing it---seen several people able to do this themselves in about a hour. Google the model number to ("color wheel") to locate a replacement on the internet.10_24_2012_3_58_01_pm.jpg
Oct 24, 2012 | Samsung HLR5064W DLP Projection TV
I have an RCA DLP tv model HP50LPW52. the sound was there with no picture. since it is 5 years old I replaced the lamp for the first time. got it all hooked up, turned it on and the tv slowly came on....
That is your Color Wheel that is bad. I wish you would have posted the problem before buying a lamp. I would have told you to treat yourself to a new set instead of putting good money into a DLP set that is 5 years old.
Feb 10, 2011 | RCA Televison & Video
My Sony Grand Vega (KDF-E50A10) LCD just made a loud pop sound and now there is no picture. The only sounds are a loud buzzing coming from the back....is this a burned out lamp??
Yes, loud pop sound was broken lamp in tv, replacement of lamp will fix tv problem.
Lamp replacement procedure is easy and would be written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
Nov 02, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
1997 Saturn SC2 squeals very loud the first 3-5miles
Try replacing the belt tensioner. Comes out easily, once you figure out access to it. Remove inspection panel inside front passenger side wheel well. Tensioner is right there, two bolts. If the spring gets weak, the belt will squeak.
Feb 15, 2010 | 1997 Saturn SL
The tv picture goes out
Sounds like the ballast has gone out. Samsung recommends replacing the smps board(power supply board) when you replace the ballast because it is the smps that takes out the ballast. replacing just the ballast ,machine may work ok for a short time but will destroy the new ballast fairly quickly.
Dec 30, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Sony rear projection standby light stays on color red, has no pic or sound ? help please.
Hi,it sounds like its time to replace the lamp,especially if tv is between 2-3 yrs .Any clicking noises? if you do it could be an issue with the board that powers the lamp it's called the ballast.Your lamp is made by Philips and it last 6000-8000 hrs ,make sure you get the original, generics dont provide same quality and life time is way shorter 4000 hrs 6 mths - 1 yr.Have a blessed life!
Nov 17, 2009 | Televison & Video
Sony grand wega kf-50we610 red lamp light blinking
The red light means that the prjection bulb needs to be replaced. They ony last about two years depending on hours of use. The low popping sounds as well as fan noise is normal for the Sony projection TV. You can Google the owners manual by entering the brand,model etc. and ask for the owner's manual. I had to go to several sites but eventually found it.
Jun 21, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Anoying
My mom and dad had this problem, after replacing the bulb everything is working great again.
Jan 25, 2008 | Hitachi 50VG825 50 in. LCD HDTV
RCA HD61LPW165 61" Projection HDTV Logo
151 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
