Question about Mitsubishi WS-55807 TV
Pink screen turn on set, the screen is pink for hours, or all day, borad looks dry
  • rickbowers Nov 03, 2008
    Thanks
    But what I found was a loose plug, Push on all of them, one clicked, then rechecked pic (ok)
    hopefully that's the problem
    Rick
  • Anonymous Dec 14, 2008
    my pink screen is back. Which board is the convergence ic board?
    Rick
  • 934 Answers
Rick, Check the convergence Ic's on the foil side for any hairline cracks in the solder joints and re-solder them if you find any... Other than that you may need to replace the convergence Ic's and possible some of the yoke return resistors. What you're seeing on the screen is an absence of one of the colors, blue from what you're describing and that may just be one of the amps is missing voltage due to ring cracks.
Bill
Posted on Nov 03, 2008
  • William Rayburn
    William Rayburn Nov 03, 2008
    My guess is, depending on the plug and where you found it, that the pressure exerted to re-seat it may have brought back the picture by flexing the pc board near the area of ring cracking I described. Ring cracks are VERY common in that unit. You may want to test that theory by applying slight pressure in other areas of the board with a non-conductive probe and see if the problem returns...
    Bill
My tv will work fine for say 1 minute then keeps flashing green and shuts off i have looked up the code it says its the D borad thats gone bad is there a wasy i can self fix it.
The "D board" is the flyback transformer, but if it was bad, you would have no picture at all. Here is a proven method to get it to work (for a while....)
The adjustment method is to put the set on a video input with nothing conected
to that input. Turn the screen control up slowly until those fine lines appear
and then down until they just disappear. Do this with all three colors. You
might need to turn one of them down a little initially if the set won't stay on
long enough to get to adjustments. You cannot do the adjustment on a TV station
or on live video input. If the adjustments are too high, the set will turn
bright and shutdown. If they are too low you will never get a picture at
all.
You would want to touchup the adjustments after a warmup of a few
hours, then recheck the next day when cold.
successfull and the set stays on but the color reproduction is very poor then
one of the tubes is probably bad.
If you are lucky and everything turns
out OK, you will probably need to do it every year or so.
Dec 01, 2010 | Sony KP-57HW40 57" Rear Projection...
I have a Woods 24 hours indoor lighting timer. I have followed the instructions provided with the timer, but lamp won't come on. Can someone please provide EXACT step by step instructions. Thank you
If you have a different model number than the 59377, please re-post with exact model number
If you programmed conflicting on-off schedules, the timer will not perform correctly
Make a schedule of times before starting, and that will keep everything organized, just like a recipe
How to program Woods 59377
Timer has rechargeable battery.
Plug timer into wall to charge battery to see LCD display.
All the Woods manuals
Download Woods 59377 manual
Up to 8 ON/OFF programs per day >> program 1 program 2 ... program 8
Choice of individual days, or blocks of days
Image shows buttons:
Set time of day:
Hold down CLOCK button until settings are made
Use DAY button to choose current day MO - TU etc
HOUR button to set current hour
MIN button to set current minute
Release Clock button and time is set
Program preview
> Have your schedule ready to avoid conflicts in programming
Manual says:
>For each ON time, you set DAY HOUR and MIN
>For each OFF time, you set DAY HOUR MIN
> So Program1 has ON and OFF settings that require DAY HOUR and MINUTE
> Program2, 3 , 4 etc also have ON and OFF settings that require DAY HOUR and MINUTE
>Manual shows blocks of days to choose from > for example TH FR SA is one block; MO WE FR is another block ,,, there are 9 possible blocks of days to choose from ... including individual days.
> Each program requires you to select days for ON time, and then when setting OFF time for that program, make sure you have correct day or block of days.
Looking at the display while programming is critical for programming timer correctly
Look for the number 1 or 2 or 3 etc located on left of display > each program has a number
program 1 is #1, program 2 is #2 etc >>> look for the small number on display
Look for the word ON that indicates you are setting ON time for program 1 or program 2
Look for word OFF that indicates you are setting OFF time for program 1 or program 2
Program timer
Press PROG once and look at screen ... you will see '1' and 'ON' in tiny letters
You are ready to set ON time for program 1
Press DAY to choose block of day for program 1
Press HOUR to choose ON hour for program 1
Press MIN to choose ON minute for program 1
Press PROG button once to validate ON time for program 1
Before pressing any more buttons, look at the screen >>> screen shows '1' and 'OFF' in tiny letters
So you are ready to set OFF times for program 1
Press DAY >>look at your written schedule to make sure the correct block of days is chosen >> if you chose ON for TH FRI SAT, you probably want OFF on same block of days
Press Hour to choose OFF hour for program 1
Press MIN to choose OFF minute for program 1
Press PROG to validate OFF time
Before pressing any button, look at screen and '2' and 'ON' show on screen
You are ready to set ON time for program 2
Press PROG button to advance to program 3 through program 8
Press ON/Off button to exit programming, and timer is ready
Other features
Daylight savings time: Press HOUR & MIN buttons simultaneously and clock springs forward 1 hour ... press again and clock falls back 1 hour
Look for S in display to see if timer set for S summertime
Press reset to clear all programming
Up-vote if this information helped you. Thanks for the feedback
Oct 14, 2010 | Woods Industries 59377 Indoor Digital...
Having Difficulty programing Woods Brand electrical timer !
Download Woods manuals
59377 manual
Set time of day:
Hold down CLOCK until settings are made
Use DAY button to choose MO - TU etc
Program preview
> First I suggest you write out your schedule to avoid conflicts in programming
Manual says:
>Manual shows blocks of days to choose from > for example TH FR SA is one choice; MO WE FR is another choice ,,, 9 possible blocks of days to choose from
Looking at display is critical for programming timer
Program timer
Do not hold down PROG button
Press PROG button once to finalize ON time for program 1
Press DAY >>look at your written schedule to make sure the correct block of days is chosen >> if you chose ON for TH FRI SAT, do you want OFF on same block of days?
Press Hour
Press MIN
Press PROG to confirm OFF time
Press PROG to advance to program 3 through program 8
Other features
Daylight savings time: Press HOUR & MIN simultaneously and clock springs forward 1 hour ... press again and clock falls back 1 hour
Oct 07, 2010 | Woods Industries 59377 Indoor Digital...
Please tell me how to program my timer. How do I set the time and when it should come on and go off everyday
Smarthome has the T-1032 pdf manual
http://www.smarthome.com/manuals/4256.pdf
1) Test installation to see if your wiring technique is correct.
Open cover > set on-off switch to 'ON'
Press the tiny round reset button with paper clip
Screen displays 0:00, MO, MAN, OFF
Close cover
Push cover inward like a push-button (the cover is the manual override)
Lights should turn on
If lights don't turn on, then you need to rewire ... so re-post a re-wire question ... and then come back to this answer to program
2) Set Time and Day/ Correct time and day are needed for programs to work.
To start, notice on the screen - in the corners are little letters: MAN, MO, OFF. And to left of time is PM.
Set the Hour: Press hour button until correct hour shows, including PM or AM
Set minutes: Press MIN button until correct minutes show
Set the day. Press day key ... MO in corner changes ... for example TU is Tuesday, WE Wednesday, TU Thursday
Press one of the control buttons to finish operation
Programming overview
Timer allows 7 programs
Program 1, Program 2 etc
Each program has ON and OFF time
So you have to select Program 1
And then set DAY for Program 1, set ON time for Program 1, and then set OFF time for Program 1
Next you do the same for Program 2 , and then Program 3, 4 etc to 7
If you only want Program 1, then you do not need to set Programs 2 thru 7
Let's program
Press PGM button ... the timer screen show a P to right of time
The number 1 appears below P and indicates Program 1
Set days you want Program 1 to work: Press day button and you can see MO TU WE TH etc appear on screen.
If you want all week long, press day button until all 7 days appear in tiny print on bottom of screen
Now you have the Day set for Program 1
Notice the screen shows ON ... this means you are going to set the ON time for Program 1
First, Set hour you want Program 1 to turn ON: press Hour button until correct AM PM time shows on screen
Last, set minutes to go along with hour: press MIN button until correct ON time minutes show
You have the day, hour and minute set for ON time
Set OFF time for Program 1: we are going to set a Day, hour and minute you want Program 1 to turn OFF
Press PGM button, and notice that OFF appears in top right corner of screen
Set the day you want timer to turn OFF for Program 1 by pressing DAY button >>> Tip set same days you set for ON times. So if you selected all seven days for ON time, then select all seven days for OFF time
Set the hour and minute you want Program 1 to turn OFF by using Hour and MIN buttons as before.
OK, the ON and OFF day, hour and minute are set for Program 1.
To continue to Program 2, press PGM button until a 2 appears on screen below the P
If you do not want to set more Programs, then you're finished
To finish, press any control button
Close the lid, cross your fingers, you did good
Sep 30, 2010 | Aube Technologies Aube 7-Day 40-500w Light...
Tv picture is pink with vertical lines sony bravia 32 inch XBR
it sounds like a bad t-con board. this board my not be sold without geting the whole screen. the t-con borad is at the top of the screen and connects to your main board
Apr 15, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Laptop LCD goes black after a few seconds
Yes, The pink tint is an indication that the backlight is failing. Now the backlight is basically dead, the best way to get back going is to do an Ebay search for your model laptop and get a new screen. Most screens can be purchased for around $50.00 - $70.00 and they are very easy to swap. Email me if you need more info.
Buddy
Corporate Computer
www.ccl-la.com
Aug 03, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Phone is wet please help!!!
Try to let the phone dry out by itself, set it on the window sill let it dry out for a little while, a lot of times water still gets down (internally) inside the phone, so it looks dry on the outside but it's still wet on the inside of the internal components. Try to let it dry out for a couple hours in the sunlight, caution, though, don't let the screen sit with direct sunlight bearing down on it.
I would caution on using the blowdryer, too hot of a setting can damage the internal components, so use the lowest setting possible. you can also try a low suction vacuum cleaner, also...
Ensure you:
Immediately take the battery out, and leave it out, water and electrical components don't mix.
Take out the sim card and attempt to dry it, just be careful with it because it's sensitive.
Let it sit next to a low heat source for a couple of days, periodically checking up on it. But I would'nt try to power it back up until you are confident that all the water is gone and evaporated out of the phone, otherwise you could fry the internal circuits and damage your phone.
Nov 13, 2008 | Cell Phones
Pink and green colors on screen when first turning on tv lasting 1 hour +
Good Day,
Sounds like the TV's convergence circuit has failed:
*Call an Authorized Service Center and them give you an estimate cost of the repair, or
*Repair it your self; get KIT 10 locally or B&D Enterprises
1-800-458-6053; www.bdent.com.
Good luck, big IRISH.
Jul 29, 2008 | Hitachi 53UDX10B 53" Rear Projection...
LCD Monitor Half Screen Pink
sounds like a color balance issue. Check the menu, do a degauss...and then check for the color temperature (reset for default)..
Got backup?
Feb 10, 2008 | Proview PL 566s 15" Flat Panel LCD Monitor
Pink screen
Back to store or maker with it. Check out the makers Tech support site but this needs a new camera replacement.
May 16, 2007 | Kodak EasyShare C643 Digital Camera
Mitsubishi WS-55807 TV Logo
115 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
