Question about Compaq Presario 700 470024-192 Notebook
Will not start with charger but the lights come on.
Left computer in case for about 1 month when i try to use it battery is dead.put charger on and lights come on but will not start up.
  • 849 Answers
Remove battery and try to turn on without battery otherwise you have to replace the battery.
Posted on Nov 06, 2008
MD2614U will not turn on. red light blinks three times
The first thing to do is check that the charger is putting out the correct voltage, which should be ~19 volt. Then try to start it without the battery.If your voltage is OK and the battery out makes no difference, then I would suspect that you have a motherboard problem that must be fixed. If the computer starts up if you wiggle the DC plug where it goes into the computer, then it's the DC jack that is looks and must be re-soldered.
The dead laptop charger may be another cause. Try a new and correct one:
Intocircuit Gateway MD2614u AC Adapter 65Watt 19V 3.42A
Oct 30, 2012 | Gateway Computers & Internet
My refurbished hp compaq mini wont charge I havent yanked the cord or anything. i have had the computer for not even a week. it charged fine for the first few days but one night i left it charging and the...
It sounds like you have a bad battery charger, but it could also be slightly corroded battery contacts. Make sure the contacts on the battery and inside the computer are clean (you can use a qtip and alcohol, or a pencil eraser). You will have to measure or have someone measure the output of the charger, to make sure it's putting out a good charging voltage. You can use a voltmeter to do that.
If you can run it by Best Buy, they can check to see if the charger is good. There's also a possibility that the battery has gone bad, and in that case, they may not hold a charge.
Good luck, and hope this helps.
Mar 24, 2011 | HP Mini 1000 Netbook
Sony VGN-SZ470N Lap top will not power up -The charger green light is on. It has been plugged in- tested the outlet- Tried a second charger just to be sure. No charging light on the computer Just...
try removing the batteries for a minute and put it back. try to power it up again.
it happened to me may times now, and i hope it will work with yours also.
try it...
Dec 29, 2010 | Computers & Internet
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
My laptop worked fine up until a tech took out Windows Vista and replaced it with Windows 2007. When I got it back it glitched for a very long time. Then finally it was like nothing had happened. Then the...
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 28, 2009 | HP Compaq Presario V6000T Notebook
Laptop won't turn on, no lights - nothing!
Oct 26, 2009 | HP Pavilion zd8000 Notebook
My ACER 5920 will not boot up when the charger is plugged in th
Dear Sir,
By analysing your problem it seems to be your adapter dead.So first check your adapter,so your laptop battery may not have backup to turn on the laptop.
Sep 11, 2009 | Acer Aspire 5920-6727 Notebook
Inspiron 1521 adapter vs battery
take an ohm meter you can buy for ten bucks at radio shack put the volt meter on DC volts plug the charger into the battery charger end the black lead goes tothe outside and the red goes inside, set the meter for 12 volts dv and mesure the voltage. read the voltage output on the battery charger transformer see if it's within a half volt if not the charger is bad, if it's ok then use rubbing achol and a q tip to clean the battery connectors on the computer and the battery itself, if you do not get the light then pull the battery out and hold the power button in the on postion and hold the enter key for 1 minute and try again, if the lights do not come back on your battery is dead, if the computer will still boot with the battery then the charger is working if it won't boot up the battery is dead. Got it?
Jun 21, 2009 | Dell Inspiron E1705 Notebook
Lenovo z51t, no indication of life when power up
Try this. Turn off unit. Unplug charger. Take out battery. Replug charger - not battery. Turn on computer. If it comes on the battery has a glitch and should recover after an hour or so. If it doesn't come on, the unit needs to see a reputable computer repairperson.
Good Luck
Mar 21, 2009 | Computers & Internet
Toshiba satellite Dead
Try to push and hold the power button. It more than likely went into hibernation/sleep mode. If this does nothing then remove the battery and charger, then put the battery back in and plug it in and see if this does anything.
Jan 05, 2009 | Computers & Internet
Compaq Presario 700 470024-192 Notebook Logo
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
