Question about Amana Refrigerators
My amana refrigerator model arb1905cc bottom freezer leaks water out of the bottom
  • 76 Answers
SOURCE: freezer leaks water!
luvbug, Your refrigerator is "frost free" which means it is automatically defrosts after the compressor runs 8 to 12 hours. The defrost cycle lasts approximately 30 minutes. If it is in normal condition, defrosted water goes through the drain into the drip pan under the refrigerator and then evaporates. The problem you are having is one of the most common - the drain line is clogged up. To fix it you have to remove the freezer drawer, defrost and clean the drain. The drawer removal procedure described in the refrigerator manual book. If you do not have one you can find it there: http://www.amana.com/amana/jsp/manual.do You will see the drain hole on the freezer floor by the rear panel. To defrost it you can use your hair dryer. To make sure it is open, run a cup of very hot water through the drain. Reinstall the freezer drawer and enjoy it! Gendos....post it back
Posted on Dec 22, 2006
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
had same exact problem - followed advice for fixing same problem in similar refrig. took of the back panel off the freezer section - 8 hex head screws - and found the cooling fins all frosted over.
Posted on May 31, 2008
SOURCE: water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Posted on Nov 17, 2008
aborcass
  • 2651 Answers
SOURCE: Amana 18 Top freezer Refrigerator-leaking water in refrigerator
the middle insulation hasbecome water logged, forma faulty defrost tube, so, every time trhe unit defrost, 2 maybe 3 times a day it will spill water inti the vents, andin to the refrig, the only correct way to fix is to have the enitre center drain block replaced, part not that expensive but labor to install may be, ohter then nussincence, not really affecting machines workings
Posted on Jan 11, 2009
Maanita
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    Buildup of ice on bottom of freezer compartment. Ice then melts and leaks out the bottom
    sounds like you have a stopped up drain line where water drains out when freezer is in defrost mode. My Amana freezer does it quiet often.
    Jul 15, 2012 | Amana ABB2224WES Refrigeration :...
    Water leaking onto floor coming from under refrigerator
    Their are a couple things causing that leak
    1) the water valve(s) for the icemaker/door dispenser are leaking. Pull the refrif. out,remove service panel from the rear and inspect the valve(s) for leakage. Sometimes their is just one valve on certain models their is two.
    2) the drain for the auto. defrost cycle in the bottom of the freezer back wall is blocked so the defrost water is running out of the freezer door at the bottom
    Good luck,i hope i have able to help you stop the leak,
    Aug 20, 2011 | Amana Side-By-Side Refrigerator 26 cu. ft....
    Water leak on floor
    Typically on this model the drain hole Under the evaporator cover gets clogged. Remove the cover off the rear of the refrigerator and pour hot water into the drain until it goes down quickly. To remove the cover u will have to remove all the freezer shelves and the icemaker. Remove the covers screw and u should see that at the bottom u will have a block of ice down below. The refer goes onto defrost every couple days and will leak the melted ice onto the floor
    Jul 06, 2011 | Amana ABB1927DE Bottom Freezer...
    Our amana bottom freezer refrigerator Model ABB2224DEQ at times leaks onto our kitchen floor. We don't have an ice maker so I am wondering where it would be coming from and what needs to be done to...
    This is likely water from the auto defrost operation leaking from the evaporating pan. Sounds like the pan may have a hole in it, or the hose which drains the water into the pan is leaking, The pan is at the very bottom of the unit.
    Charlie
    Mar 27, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
    I have an Amana BRD18V1 or V2, bottom freezer. About every two weeks it leaks water on the floor on the right hand side and i have to defrost the bottom part to get about an inch of ice out. I trust...
    I assume you mean water leaking on floor of bottom freezer? There should be a small hole in floor in back to drain defrosted water down to pan under unit. This line might be clogged with food or frozen water. Carefully pour some hot/boiling water down tube to clear. You should see it empty into pan under unit where fan evaporates it.
    Jul 15, 2010 | Amana ABB1927DE Bottom Freezer...
    My Amana ABB2257CS bottom freezer leaked water
    your freezer cabinet need to get all out also the ice machine,and open the back wall
    there is a drain hole in the bottom middle of it make sure it is clean, and if you pure water they go all the way
    through the pip to the drain pan next to the compressor.
    good luck 911servicetoday .com good luck
    Jun 29, 2009 | Amana ABB1927DE Bottom Freezer...
    Amana bottom freezer: water leaking & ice build-up
    There should be some kind of drain at bottom of freezer compartment to collect and run off any condensate that collects during defrost cycle.. Clean out the drain and snake out the line that leads from it. Right now the liquid is collecting where it should not and it will leak out the gasket when you have enough of it.
    Sep 09, 2017 | Amana ABB1927DE Bottom Freezer...
    11 year old amana bottom freezer icemaker drips water when filling tray
    as long as the temp in the frz is normal. the i/m could have a bad thermostat that, could be causing it cycling too soon or the tray is leaking water. either way i/m needs to be replaced, sorry
    Sep 26, 2008 | Amana ABB1927DE Bottom Freezer...
    Freezer leaks water!
    Dec 21, 2006 | Amana ABB1927DE Bottom Freezer...
    Refrigerators Logo
    48 people viewed this question
    Top Amana Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
