Question about GE Profile Spectra JGBP90 Gas Kitchen Range
How to light stovetop pilot light?
My stovetop pilot light went off after cleaning, how do i light it?
  • patdepalma1 Dec 02, 2008
    Two burners pilot lights on my GE profile cook top do not light after cleaning. At the time it was only about two years old. What has to be done at this point? Any ideas on how to fix without spending a fortune on getting fixed? One "handyman" said it would cost 275.00 to fix. That I would have to place all four burners. Yikes.
  • 59 Answers
This cook top uses an electric ignitor and does not need to be lit.
Posted on Nov 03, 2008
Pilot light lights but burners wont light
If this is a stovetop, there are little holes on the side of the burners were the tube from the pilot light goes, they are probably clogged not allowing gas to get to the pilot light to light the burner
Nov 27, 2016 | Heating & Cooling
Two of gas burners will not light
Assuming you have electronic ignition on your stovetop, you may have spilled food onto the burner which has clogged the holes needed to get gas to the spark ignitor. Clean the holes (or slits) and dry them and try again. If they are not dirty, check to make sure you have a spark at each burner. If you have manual pilots, there could be many other problems, like the pilot is not lit, dirty vertical holes (on the burner side) at the pilot tunnel or tunnel is not positioned properly.
Mar 16, 2015 | Cooktops
A few minutes ago, I sent a note that I had not received the manuals, warranty papers, etc. for the General Electric Range and General Electric Microwave that I had purchased. After sending my e-mail, I...
Hi one of us has to respond to close out the post. If you need any more assistance you can still respond to this post after it has been closed. I can and will help you. Just glad you found your paperwork.
Thanks,
Kelly
Sep 09, 2011 | Kitchen Ranges
PILOT LIGHT OUT. sTOVETOP CONTINOUSLY MAKES A CLICKING SOUND. i BELIEVE THE PILOT IS OUT. hOW DO i REIGNITE THE PILOT AND MAKE THE CLICKING STOP
Sorry to read about your problem, I hope this helps you out.
Their is no pilot lite on your oven..the clicking you hear is the electronic pilot system..
you have a defective control knob...
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 21, 2010 | GE Cooktops
The pilot don't stay on
Is this the pilot for the oven or stovetop burners, or both? Pilot flames can be adjusted to increase or decrease the size. It's probably dirty which is causing it to go out. Use a small flat screwdriver to scrape the pilot tip clean or a small needle to poke it, if necessary. Then use the screwdriver to adjust the pilot flame as needed. If you follow the small aluminum tubing from the pilot, you will find a small screw on the line to adjust it. If you need more help, just let me know. Obviously, there can be other issues, but this is the most common problem. Douglas
Jun 04, 2010 | Vulcan VG36 Gas Kitchen Range
We let our propane tank get empty. It's full now, and the water heater and stovetop work, but the oven pilot won't light. It worked fine before the gas went out. It glows, but there's no gas flow. What...
Call your gas supplier for help. If you feel comfortable you can inspect the tank first and check that the valve isn't off. If your delivery guy knew that you ran out he would shut it of from the tank to protect your home. (since multiple pilots may have gone out).
If the valve is on then you may want to try resetting the valve to the appliance, one at a time. If I'm speaking french to you don't worry but ask a professional for help. Good luck.
Apr 23, 2010 | GE Kitchen Ranges
The pilot light will not stay lit. A new
Try cleaning the orfice for the pilot light. You will have to dis-assemble the fuel lines from the thermostat to the burner to get at it. The orfice has an extremly small hole in it, do not make it any larger, just clean it out.
Mar 14, 2010 | Drills
Want to clean under stovetop
Hello
welcome to Fixya,
This stove has sealed burners and there is no need to lift or clean under anything except the burner caps.
You can not get inside the top and you can not lift the top like the old pilot stoves!
When you clean the burners and around rings do not spray or saturate the are and or the igniter element that creates the spark.I'll be back in a moment with your user manual.
first what is the complete model number of your range as written on the sticker in the door jam of the storage compartment down below. left side!
Huuum
Dec 15, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
159 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
