Question about Kenmore 24032\24036 Top Load Washer
Kenmors 110 keep spining
The tub or barrel is constantly in motion - like a medium rate spin. The agitator works fine, but with the constant spin of the barrel during the wash cycle, clothes are being twisted and tangled , (actually ripped & torn) under the agitator, (around i'ts base). It works fine during the spin cycle, when it's supposed to constantly turn, and does so with an appropriate increase in the speed of the spin. We removed the agitator to check on it, (it's fine) but we did find two holes on opposite sides of the staff, and couldn't figure out if something there had been lost or broken. All in all, it works fine providing you manually hold the barrel in one place during the wash (agitating),and rinse cycles.
Thanks
    Sergeant:
    Champion:
  • 324 Answers
The tranny should either spin or agitate not both
Posted on Nov 03, 2008
Kenmore 80 Series 110.27802690 agitator barely moving
It's the transmission that's bad. The motor turns one direction to spin and the opposite direction to agitate. The transmission converts the constant belt speed from the motor into the back and forth motion. In the other direction, the transmission stops and the whole system spins.
(I don't suspect you have it set to "delicates")
Jul 20, 2016 | Kenmore Washing Machines
Loud constant noise (metal on metal clicking / whirring / grinding) during spin cycle
renault laguna 2006 diesel. unlock code for radio... modell renrdw100-10 .
n874 security...
pls..
thanks
Nov 22, 2013 | Whirlpool Washing Machines
When the dial is set for a medium load, the water fills to about the mid point up the side of the wsher barrel and stops. Then the inner barrel starts to spin at a moderate speed and the water is thrown...
Sounds to me like the pump is not operating up to par. Open the machine and check all the drain lines form the tub to the pump, from the pump to the waste pipe and also, when you check the tub to pump line, feel up into the tub to make sure you don't have a article of clothing stuck in there. Check the inside of the pump too. Here is a link to a video to show you how to access the pump and lines.
Dec 28, 2010 | Maytag PAV2300 Top Load Washer
Making constant buzz, tub not moving, will not finish spin
you need to replace a component called the"capacitor".this should solve the problem.
Nov 01, 2009 | Whirlpool LSB6300PW Top Load Washer
My washer doesn't spine
If the agitator works but not the spin cycle, you have a locked up water pump. This keeps the motor from spinning in the other direction so the gears would lock up to spin the whole tub, and work the pump at the same time. turn the washer on its side, and see if there is a small sock or other smal item that have made its way to the pump causing it to get stuck. The pump is easy to take out it is fastened by two clips.
Jul 01, 2009 | Kenmore Washing Machines
KENMORE WASHING MACHINE MODEL#110. 254872300 WONT SPIN
if your sure it will agitate?[because the pump is on the other side of the motor and will drain,but if coupler broken ,wont agitate or spin although it makes noise like its working.so if will truely agitate drive coupler fine and its going to be the clutch or that area unless somthing[clothing] is between the two tubs creating anough resistance to stop the tub from taking off.clutch pads will just slip on drive plate.hope that helps>God bless ,tom
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Keep spinning
sounds as if hte tub block has gone bad. its the locking block that ties the inner tub t the transmission shaft, after it strips out nothing stops free rotation of inner basket.
Nov 05, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Mod 110 keep spinning
the holes are sapose to be there it filters the lint out.it sounds like you have a bad transmission.
Nov 02, 2008 | Kenmore 24032\24036 Top Load Washer
Where is the agitator in a Indesit WG1385
Open machine's rear panel and remove belt. Check if motor spins (when it should, as per cycle stage). If motor is spining - Move tub manually and check for smooth spin In case it doesn't spin smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, you should remove it. In case motor doesn't spin- Check with multi-meter if it get power. If it get power - The problem is with the motor. Good luck !!
Jun 07, 2006 | Indesit W 123 Front Load Washer
Machine does Agitate
Kenmore 24032\24036 Top Load Washer Logo
176 people viewed this question
Sal De
fordexpert
Robert Rankin
