Question about Audiovox D2010 Portable DVD Player with Screen
Multiple vertical colored lines on DVD player screen
Own year old portable DVD player, Audiovox D2010. Unit turns on (power light green), will not play any disc nor display any picture or play any sound. Screen shows two 2"-3" wide vertical bands of multiple colored lines. One band is down middle of screen, other is down right side of screen,left side of screen remains black. Is this repairable and/or worth fixing?
  • Anonymous Mar 30, 2014
    Dvd player doesnt want to turn on. When switched to the on position screen flashes on for a second and turns off. Simultaneously the power light turns green then red then off.
    President:
  • 3,130 Answers
Check this out http://www.techlore.com/forum/thread/12629/
Posted on Sep 26, 2006
I have great sound on my Audiovox portable dvd player but no picture. Can you help?
  • Check that the A/V IN/OUT Switch on the side of the player is set to the OUT position.
  • Check the small switch near the hinge at the back of the unit, if one is installed there. It turns off the LCD screen when the panel is closed. This switch sometimes sticks in the down position and the screen remains off. When the screen is opened, the switch is supposed to pop up. If it is still in the down position, try to free it with the ends of a toothpick or paper clip.
  • If both switches are correctly set and the screen remains blank, the unit should be sent to Audiovox for service.
May 16, 2011 | Audiovox D1708 Portable DVD Player
My screen has vertical lines that I can't clear
What is happening to your laptop is the power line connecting a few rows of pixels is failing so only partial colors are showing up causing the vertical lines. Usually screen replacement is the only answer to fix it. You can usually find replacement LCD on Ebay.
Feb 09, 2011 | Philips PET710 Portable DVD Player
My Audiovox D1817 Portable DVD player power light comes on but nothing on the screen and the disc does not sound like it is turning. What is wrong with it?
Two issues
1, if the CD is not spinning BAD motor, or not getting enought power from the supply.
2. LCD not turning on (bad back light) or power not getting to it
1. replace the A/C apator
1.a try holding a flash light up to the lcd display to see if you see anything. If not then you are not getting full power to the unit you could have a bad power supply or logic board as a whole.
Audiovox is "you get what you paid for device" basically speaking use it for a year and throw it away. Not trying to be blunt but simply put there not quality devices at all.
Take my advice with this following statment "your better off with a new player"
thanks for your question
please do click the accpet button for my adivce and findings.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 25, 2010 | Audiovox D1817 Portable DVD Player
Horizontal lines on screen.
Your unit may have a loose connection from motherboard to the display (video cable inside the unit), another distinct possibility is that the video processor chip is damaged or there is a power supply problem for the video chip (a bad electrolytic cap or similar somewhere around the video IC).
You can check the connection, but you'll need to take the unit apart, also check other connectors, but if it's an IC problem, this could get difficult or/and costly.
Please note that these are only suggestions and that the problem may as well be something else.
regards
3rq8 (Triarcuate)
Jul 23, 2009 | Audiovox D2010 Portable DVD Player with...
Audiovox D1020 will not power on?
I have a unit with a broken screen that I am trying to find a replacement for. (one with a good screen) Please email me and let me know if you are willing to sell yours. Thanks
buckeyevcr@aol.com
Feb 26, 2009 | Audiovox D1020 Portable DVD Player
Audiovox d2010 portable dvd...dark screen just see shadows.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Sep 02, 2017 | Audiovox D2010 Portable DVD Player with...
Dvd player screen is green
ok, you are right. LCD drive circuit might need replacement.
Sep 09, 2008 | Audiovox D1708 Portable DVD Player
Black and white picture instead of color
ok.maybe the system was reset and it switch to pal mode/ntsc mode.explore ur remote control look 4 some system related button or p/n button.press it 2-3 times..u have to detailed ur unit next time..
Feb 25, 2007 | Audiovox D1420 Portable DVD Player
Audiovox D2010 Portable DVD Player with Screen Logo
639 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
