Question about Marine Pro MPSS-807B Blender
Marinepro 12-Volt Blender Model # MPSS-807B
Hi, the glass carafe or pitcher broke when it fell and hit the cement. So how and where do I order a replacement?
Thanks,
Need replacement jar for model #14074 purchased 2003
If it cannot be purchased right from the maufacturer (which it likely won't as it is 11 years old), you can get nice blenders for around $20 at super stores like Walmart that work well and last for a while.
Jul 08, 2014 | Ultrex 834-334 Die Cast Work Top Blender
Need glass pitcher for model No 54200
Possibly on the cheap at http://www.ebay.com/itm/VINTAGE-HAMILTON-BEACH-BLENDER-GLASS-PITCHER-5-CUP-40oz-JAR-REPLACEMENT-PART-/161614412690?pt=LH_DefaultDomain_0&hash=item25a0f83b92. For an unused replacement try typing in your model number at HB's parts wesite located by clicking here . Check out the many www sites like abtecparts.com and goodmans.net. Besides matching description, I would match the pictures of what you are going for against what you've got as much as possible. Good luck!
Mar 15, 2013 | Hamilton Beach 54200 BlendMaster Blender
How do I fix or replace my kitchenaid blender blade KSB560BF (Polycarb Jar)? It's leaked thru the blade assembly.
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks.
Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it.
I hope this helps. If it does, please come back and rate my suggestion!
Jun 15, 2011 | KitchenAid KSB560 5 Speed Blender
My blender base has become discoloured with a sort of green mouldy streaks, how do i clean
If you remove the blinder base where the blades are you can put it all in the dishwasher. To do this grab the handle on the pitcher then unscrew the plastic base from the glass. make sure that you look how it comes apart first. then put in the dishwasher to clean. Then reassemble the way you took apart.
Jan 11, 2011 | Oster 12-Speed Brushed Nickel Blender...
Need a replacement pitcher for model56200 typeB17
The same thing happened to me. I ordered a new one and they sent it to me in the mail. You can find replacement parts here:
Oct 25, 2010 | Hamilton Beach 56200 Power Work Top...
I need the replacement glass bowl. My wife dropped and broke. It is the blender bowl for the Cuisinart Smart Power Duet, model FPB-5CH
Hi!!
Smart & Final carries a variety of glass bowls in plastic, glass and metal, at the cost or the S&H you would pay if ordering from dealer.
If helpful, click below.
Apr 08, 2010 | Juicelady JL600 Professional Work Top...
Need to replace glass pitcher for durabrand blender YD-298
hi iam using toastmaster blender/chopper model #,1135 now i need jug with blade. How can i get it ?
Jun 08, 2009 | Toastmaster 1135 Work Top Blender
Need a new plastic pitcher for our villaware 5787 Smoothee
Got the number from your website and called direct to VillaWare...waiting to see if it arrives safe and sound, thanks so much!
PS...There are only a few left of this now discontinued model, so I'm glad I called (and I ordered 2 more instead)
Jun 01, 2009 | VillaWare 5787 Double Smoothee Work Top...
Back to basics blender solution 5000
have you tried ebay or typing the model type in the search engine?
May 06, 2008 | Blenders
Marine Pro MPSS-807B Blender Logo
106 people viewed this question
Top Marine Pro Blenders Experts
eyecam
Are you a Marine Pro Blender Expert? Answer questions, earn points and help others
