Question about Vizio GV42L 42 in. LCD Television
Vizio 42" LCD - Random appearance of small black rectangles
Small black rectangles randomly appear on my screen. Sometimes turning tv off and back on gets rid of them, sometimes it doesn't. They can appear anywhere on the screen. Sometimes it's 1, sometimes it's 3 or 4. ANy ideas?
    New Friend:
  • 7 Answers
I would check and see if you have the text option on under your closed captioning. With the new digital transition the signal for text captioning has been getting messed up during broadcast here lately. If it is on i would just shut it off or go to regular closed captioning.
Posted on Nov 09, 2008
2 Suggested Answers
jerryg50
  • 1689 Answers
SOURCE: Vizio 42" LCD - Random appearance of small black rectangles
There is a processing fault that is starting to occure. What you are seeing is a type of aliasing. This can be in the main signal processing or in one of the control areas.
The set will require service. The service rep will test the set by using board substitution. There are typicaly a number of areas in the TV set that can cause this type of fault. Once the defective board is located the fault will be easy to service with a simple board swap and some adjustments.
If the set is out of warranty, it may be expensive to service. With many of the no-name brands, spare parts can be difficult or impossible to have.
Jerry G.
Posted on Jan 02, 2009
VIZIO 42in LCD HDTV - Dark colors and flickering
It sounds that the back-light CCFL lamp is faulty. It is time to replace it. When replacing, do it to all CCFLs, because, the life time to these lams are expiring now, as the set is nearly 4 years old. Check this link http://electronicshelponline.blogspot.com/ to get more details about how to replace the CCFLs. Pull up older posts there. Some among it have details.
May 29, 2013 | Vizio 42 in. LCD TV
ImagypsyRe:Vizio 42" LCD TV Screen randomly
You should definitely return it. It is most likely due to backlight malfunction and or backlight invereter malfunction. Either ways you should return it and demand for a replacement if its under warranty.
May 30, 2011 | Vizio 42 in. LCD TV
On certain channels, mostly Nickelodeon (not sure why) sometimes there will appear a black line with colored numbers or letters inside. Looks like some other kind of language to me. Spot appears on center...
Sounds like you have your closed captioning turned on. The TV remote may have a CC button on it, if not it will be in the TV menu. Try turning this to OFF. What you are describing may be the TEXT 1, 2, 3, or 4 function of this feature.
Mar 15, 2010 | Sanyo 42 in. LCD TV
Random 3'' vertical red line on 42'' Hitachi Plasma TV
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.////
Sep 04, 2017 | Hitachi 42HDS69 42 in. Plasma Television
Black Rectangle appears on screen for no reason
Just use your remote or the tv menu to turn off closed captioning.
Jun 03, 2009 | Insignia 42" Flat-Panel Plasma HDTV
Visio LCD TV - Partial Picture blacked.
Hello! I have a 32" Vizio LCD...within 30 minutes of the tv being turned on, black lines start running through the bottom half of the screen and eventually blacking out the bottom half of the tv screen. It also doesn't have anything to do with the ratio as I have tried that. HELP!
Jan 06, 2009 | Toshiba 42HP66 42 in. LCD Television
Jerry G.
Jan 02, 2009 | Vizio L32 32 in. LCD HDTV
Black Rectangles on 42" Vizio HDTV LCD
Your DirecTV signal is probably too low. That would produce the small black rectangles (pixilation). Also, try replacing the cable you are using to get the signal from the DirecTV receiver.
May 20, 2008 | Vizio L32 32 in. LCD HDTV
No pic
SOUNDS LIKE YOU HAVE A BAD Z-SUS BOARD...LOOKING FROM REAR OF SET WITH BACK COVER OFF..ITS ON RIGHT SIDE..CALL ANDREWS ELECTRONICS IN CALIFORNIA WITH MODEL #..THEY WILL GIVE YOU A PRICE AND PART #...JOE ACE
May 15, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Black Squares on the Screen
this kind of problem is normally do of bad cable box or sat
Apr 05, 2008 | Vizio L32 32 in. LCD HDTV
Vizio GV42L 42 in. LCD Television Logo
146 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
