Question about Canon PowerShot A70 Digital Camera
A70 start-up problem
First of all, this is a great site. My PowerShot A70 has this tricky malfunction. When CF-card is inserted, my camera won't start. Without CF-card, it will start OK, though, it will report "no memory card". So, the problem seems to be in CF-slot... Any homemade-idea, how could i fix this? Thanks in advance.
  • stanmurphy Jan 05, 2009
    I have the same problem with my Powershot A70 and a brand new Kingston 1GB Compact Flash card.
    The camera starts without the CF card but not with.
  • 641 Answers
It could be as well a malfunction CF card. Try to use another CF card in your camera. Good luck!
Posted on Aug 01, 2007
No Memory Card error
Check to see the largest capacity card that the camera will accept - if you are trying to use cards larger than this, I would expect this error.
Jul 28, 2017 | Canon PowerShot A70 Digital Camera
I get a memory card error even though it has a card installed
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a70#ServiceAndSupport
Issue: Memory card Error
Solution: Try a different memory card and/or Reformat memory card PowerShot A70
Formatting a CF Card You should always format a new CF card or one from which you wish to erase all images and other data.
caution_a70.gifPlease note that formatting a CF card erases all data, including protected images and other file types. Please check the contents of the CF card before formatting it.
  1. Turn the power on.
  2. Press the <MENU> button and select [ tools_icon.gif(Set up)] using direction_arrow_lt.gifor direction_arrow_rt.gif.
  3. Select format_icon_a70.gif(Format) using direction_arrow_up.gifor direction_arrow_down.gifand press the <SET> button.
  4. Select [OK] using direction_arrow_lt.gifor direction_arrow_rt.gifand press the <SET> button.
    • To cancel formatting instead, select [Cancel] and press the <SET> button.
    • The capacity of the CF card displayed after formatting will be less than the rated capacity of the CF card. This is not a malfunction of the CF card or camera.
  5. Press the <MENU> button.
  • If the camera does not work properly, the inserted CF card may be malfunctioning. Reformatting the CF card may solve the problem.
  • When a non-Canon brand CF card is malfunctioning, reformatting it may solve the problem.
  • CF cards formatted in another camera, computer or peripheral device may not operate correctly. When that happens, reformat the CF card with this camera.
Aug 03, 2010 | Canon PowerShot A70 Digital Camera
Canon powershot model A70 screen says memory card error even with new card. What now?
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, don't fret. Although professional repair would be more costly than the value of the camera, there is a very good chance that you can repair this yourself. Please see this link,
Jun 04, 2010 | Canon Cameras
Does the A70 need a memory card in order for it to take pics?
Yes. The camera has a very limited internal memory only used to buffer (temporary storage while processing) digital images. You need a CF Card (type 1) to save and store your images.
Feb 05, 2010 | Canon PowerShot A70 Digital Camera
I have a Canon PowerShot G6 and every CF card I insert in the camera displays Memory card error 100-0002. Any idea why this is happening?
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, don't fret. Although professional repair would be more costly than the value of the camera, there is a very good chance that you can repair this yourself. Please see this link.
Jan 22, 2010 | Canon PowerShot G6 Digital Camera
After inserting cf card into canon s30 i get cf
Believe it or not, the camera's internal clock battery is worn down, causing this problem. Unfortunately, it's buried deep inside your camera, and is difficult to replace. But happily Canon will fix this problem for free. Please see this link.
Nov 14, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
Pictures are all black
Send it to Canon they have a recall on this model, N/C Go to the canon web site and look up Service Advisory, CCD malfunction.
Feb 25, 2009 | Canon PowerShot A70 Digital Camera
Internal memory
Sorry, most Canon cameras do not have internal flash memory (maybe the newer models? But the A70 definitely does not). Those other model cameras that do have internal memory only have a few megabytes. And this memory is primarily intended only to take a couple pics to verify that the camera is working properly.
May 14, 2008 | Canon PowerShot A70 Digital Camera
My CompactFlash card is no longer recognized by my computer (Sony Vaio notebook w/Windows XP home edition)
It isn't clear from your description, but are you inserting the reader into your USB port, and *then* inserting the CF into the reader? If so, try reversing this -- insert the CF into the reader, then insert the reader (with the CF) into a USB port. It is possible that your PC is only looking at the reader once (when it is inserted) and not finding a CF, then ignoring the CF once you insert it. If your camera can read and write to the CF, then it is unlikely that the CF is damaged. Since you have determined that the reader is ok, and since your PC recognises the reader, it is unlikely that it is a USB driver problem. Similarly, it is unlikely that it is a physical problem with the USB port, or the pins in the reader or the CF card.
Mar 03, 2007 | Canon PowerShot A50 Digital Camera
Formating a CF sandisk card
I dont know about formmating CF sandisk card with canon A70, however, i can recommend another method: hook it up to your desktop and format it through a CF adaptor. It may take a couple of attempts. it didnt do any damage, at least not one that im aware of. Im not 100% sure though, so don't get me responsible in case it will damage yours. anyways, if you do it, you can try the process described above. good luck.
Apr 03, 2006 | Canon PowerShot A70 Digital Camera
Canon PowerShot A70 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Doberman
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
