Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony vega 36" tv
Hello.
My tv has grey rolling lines across the screen.
Sue
    Genius:
  • 1,139 Answers
Hello ladybaker,
This is possibly a problem with the low voltage power supply, or it could be a problem with the tuner. To test this out. What I need for you to do is to disconnect the cable from you cable TV set top box to the RF connector of your TV. Then I want you to connect either your composite or component video cables from the set top box to the TV and using the remote switch the input from the RF (tuner) to the composite input and note if this removes those lines. The select the component video input from the menu and note if this gets rid of those lines.
If the lines disappear for the composite and component video input test. Then the problem is in the tuner, if the lines remain then the problem is in the power supply or there is a video problem.
In either case after the test I would suggest that you have a qualified TV technician troubleshoot the TV and repair the problem. At least you will have input to tell the technician on whether the problem is in the tuner or the power supply/video section.
I hope this helps,
Thank you,
Shuttle83
Posted on Nov 22, 2008
Screen keeps going black then grey and white lines start to come across the screen.
This is not the fault with remote control. It is with your TV itself. Contact any service technician.
Gopakumar Gopalan Google
Mar 24, 2014 | Televison & Video
Static & no picture from UHF input / Component Video fine
there is sinal interferences from laser products pc mobile transmitters or video games get high quality vcr and cable tv cables move or switch off any video games cd players energy saving lamps or pc and microwaves n motors like pumps change the position of installation of cable and antenna to avoid path of interference
Jul 18, 2013 | Sony KV-36XBR450 36" TV
Good picture but a squigly line
Will you please provide more details> Is the line across the screen at its middle?
Jan 02, 2013 | Sony FD Trinitron WEGA KD-36FS130 36" TV
TV TURNS ON,LINES ACROSS SCREEN THEN TURNS OFF BY ITSELF
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Fine interference lines running diagonally across picture.
Hi There,
Sounds like your Horizontal Output Circuit is leaking current causing diagonal lines across the screen. I hope this will help and thank you for using FixYa!
Mar 29, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Standby light flashes 2 or 5 times; lilac picture with horizontal lines; and instant offs
There is some electronic circuit problem with your TV. Best if you want to repair it you find a reputable TV repair shop. Sorry.
Sep 18, 2008 | Sony KV-24FV12 24" TV
Sony kv-36hs500
This sounds like the beginning of a convergence IC failure. If you can solder, you should be able to resolve this yourself. Let me know if that is what you wich to do and I'll provide some additional details and instructions.
Dan
Aug 01, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony kv36fs100
defective flyback is the main problem part number is 1-453-286-11/Nx4600X
Jun 19, 2008 | Sony KV-36FS100 36" TV
SONY TRINITRON TV 36"
I think you had an arc in the high voltage circuit which zapped the blue drive circuit to the picture tube. This could have been caused by the high temperatures the your set was subjected to. Stargazer
Aug 08, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
190 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
