Question about Sony KDS-60A2020 60" HDTV
Screen turns off and on every few minutes
I have a sony kds60a2020 rear projection tv , today it started acting up
The screen turns black then picture comes back on after a couple minutes
then goes black again it does this every couple minutes on and off .. but the tv is still on there is also still sound when this happens. It does this for every input so i knoow its the tv. also it has a lamp replacment light on the tv but its not on so it cant b the lamp. i cant figure it out. when its on the picture is good . the tv is less than 1 year old. I have it connected with a surge protector as with every other component and there is no prolem with the other equipment
  • 8 more comments
  • csaynay Nov 15, 2008
    I have the same issue does anyone have a solution
  • IPlay72 Nov 27, 2008
    I have the same problem.  The green light on the front of the TV doesn't start flashing like it does at power up before the picture comes on.  The green light is on solid and I just lose the picture for about 20 or 30 seconds.  I don't feel any extra ordinary amount of heat around the TV, so i don't think it is some kind of over-heat protection mode but i'm not sure.  It started doing it once every couple of days a month ago.  Now it is happening every other minute.
  • thunt1 Dec 20, 2008
    i have the same problem the power light is solid when the picture is there and when it goes black the light blinks, but i still have sound. this happens about every 30 seconds the picture is only on for about 10 seconds.
  • chopperdnp Jan 08, 2009
    I have the same problem, TV on for about a minute, then off for about 30 seconds. The green light blinks 30 times while it is off, but is on solid when picture is on. I purchased mine on Sep. 2, 2007. Looks like maybe Sony needs to step up to the plate.
  • memills1960 Feb 14, 2009
    On power up the green POWER led will flash for several seconds and go on solid when the picture comes on. After a few minutes the picture goes dark and the led again starts flashing. After another minute or so the picture comes back on and the led is again solid green. Cycle repeats for up to 30 minutes then the picture will stay on.
  • Shelia Siebert Mar 10, 2009
    We just starting having the same problem. Picture and sound come on like normal, then picture goes off (sound stays on), for 30-60 seconds, then back on for 30-60 seconds, then off, and continues. The sound of the fan is not as loud as it was.
  • SonyKDS Mar 21, 2009
    I have the same problem. My TV is about 18 months old and it sees alot of vibration kid traffic. I notice the picture goes black with less frequency after 90 minutes or so. I just tried turning it off and on agian. The power light blinked 31 times before the audio or video showed up. Is that normal?
  • Anonymous Apr 04, 2009
    TV GOES ON AND OFF REPEATEDLY, SOMETIMES IT WILL BE DAYS BETWEEN EPISODES
  • TylerTackett Apr 14, 2009
    I have the KDS-60A2000 (the 06 model vs the 2020 07 model just different plastic on the outside from what I hear) and have the same issue with the picture randamly going out. I do not use the television speakers so I don't know about the sound continuing. I have devices hooked up HDMI, component, and composite and the source does not matter. I usually turn the set off and back on as it is quicker than waiting for the picture to come back.
  • Any Guy
    Any Guy May 11, 2010
    There are anumber of things that can cause this problem. If it were a bad lamp, most likely the sound would go out as well when the picture disappears.If the green light starts flashing when the pic goes out, that still could indicate a bad lamp. Otherwise, I would start to wonder if you have a bad B1 video process board. Can you display the menu or on screen display when the picture disappears?
5 Suggested Answers
video-tek
  • 150 Answers
SOURCE: Sony KDS50A2020 Blackout
Replace the lamp, clean the fans, seen it a hundred times, I know "the lamp light isn`t blinking" replace your lamp and you`ll be back up & running, gl, video-tek
Posted on May 29, 2009
  • 556 Answers
SOURCE: Sony Grand Wega 60 inch LCD Projection TV goes dark.
most likely, buy you a lamp and install it yourself, the owners manual tells you how to do this.
Posted on Sep 11, 2009
techman007
  • 1112 Answers
SOURCE: 60in Sony KDS-60A2020 LCD rear projection picture goes on and off
yes replace the lamp, sony units have certain specs that the lamp must meet to operate correctly. If the Lamp you purchased is made by LTI, these lamps do not last long as they are poorly manufactured. Look at the bulb and see who is the maker if its says LTI then replace with a Phillips brand that meets spec's for sony.
Posted on Jan 30, 2010
Testimonial: "This was the problem. I can't believe we went through all this over a lamp! Now my monster power is blinking as abnormal voltage at 130. Any ideas?"
  • 2322 Answers
SOURCE: What does techman007 mean by
The XL5200 is the original lamp for your TV.
Check the info from this link as well for instructions on how to replace it. Go to page # 51.
Posted on Feb 21, 2010
TV works fine for about 3 minutes then the picture goes black and the red light on the front of the TV starts blinking. The sound works the entire time. If I shutdown the TV and wait a few minutes and...
The light is blinking a code. The code will be a series of blinks, a pause and the blinks again. Phone Sony service and give them this code. They will be able to advise you as to the problem.
Apr 03, 2010 | Sony KP-53HS30 53" Rear Projection...
I have a KP65Wv700 Sony Tv it turns red after a few minutes of watching tv. I turn the tv off and on so see a few minutes of normal colors but start gettinmg red again any ideas
I'm afraid, its RED Picture tube problem that will be replaced.
It is qualified tech job to replace picture tube in rear projection TV because there are few adjustments required after replacement.
Please call local tech for fix tv.
Thanks.
Dec 14, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
No image on sony rear projection tv (model KP-53V35) for 20 minut
sony has a circuit than balances the 3 crt's. it needs a screen adjustment which is located in the front of tv behind speaker grill. easy repair
Oct 22, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Hi I have a sony KDP-57XBR2 television set and the
I had the same problem in blue. I took the right front speaker cover off (pops off) and the access panel on the right side 2 - 4 screws. In the upper right corner is a black plastic box with 2 rows of 3 adjustment screws. All I did was turn one of the "screen" screws (not the "focus" screws). Hope this helps. May only be a temporary fix, but good luck...
Aug 19, 2009 | Sony Grand WEGA KDP-57XBR2 57" Rear...
The image leaves and the screen goes black.
Either the picture tubes are going, or they are dusty. Take apart the front grill and take off the black cut away behind the grill. Inspect the tubes and the circuit boards. If they are dusty blow them off with an air can duster. It might work and its free and takes 5 minutes.
Ben
Mar 23, 2009 | Sony KP-61HS10 61" Rear Projection...
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
KP-51HW40
sounds like the tuner may be going out on the set.
Aug 10, 2008 | Sony KP-51HW40 51" Rear Projection...
I think I have the same tv. Its a philips 50 in projection tv.
Common problem with the older projection Magnavox TV set. The opto IC chip has failed. Try www.magnavoxhelp.com - They have instructions and kits on their site.
Jun 14, 2008 | Philips 9P5034C 50" Rear Projection...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony KDS-60A2020 60" HDTV Logo
82 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
