Question about Philips SA5125/37 MP3 Player
MP3 won't turn on. When it does, It turns itself off and won't come back on unless reset. Then problem repeats.
When I turn on my MP3 player, it goes through it's normal Turn on Process. When it gets to the GoGear screen, it goes black. I try to turn it back on and nothing happens. I plug it into the computer and nothing happens. Then, I use a pin to hit the reset button and the process repeats. I even tried resetting it and then plugging it into the computer. My TV won't read the MP3 player and my player won't acknowledge the computer's presence. I have about 400 songs, 3 videos, and 17 pictures and I don't want to delete them (Took me a whole year to collect it all and most of it is non-replacable). What should I do?
The problem with your Player is that its Firmware has been crashed....So you need to reinstall the Firmware using Philips Device Manager software given along with the player....But you cant retrive those data coz once you reinstall it all the data will be erased.....To do it is very simple.....just go into the repair Tab In Philips Device Manager and Follow the instructions...
Posted on Nov 21, 2008
I tried that ..still no use =(
Posted on Nov 08, 2008
  • desi_gangsta Nov 22, 2008
    umm i tried dat but still no use...it just startes charging from the same spot.
Stick a small pen in the reset hole
My Coby MP828-8G MP3 player is stuck on a blue screen sensitivity test that reads "Touch the Center of the target and hold for one second.Repeat as the target moves." I've already tried...
I cannot go back to calibrate. Even after using reset button on back of player it turns off the player but then when you turn it back on it goes right back to the blue screen again. Cannot get out of blue screen.
Jul 25, 2013 | Audio Players & Recorders
The screen is frozen on the PHILIPS icon and when i reset it it did nothing, but when i put it on the charger then reset it, it starts charging, but when i take it off the charger it goes back to the...
Please follow the below steps and check if that resolves the issue:
  1. Press down on and hold the "Power" button on your Philips GoGear MP3 player.
  2. Press down on and hold the "Volume Up" button on your Philips GoGear MP3 player. Continue to hold both of these buttons down for three consecutive seconds. The MP3 player will turn itself off.
  3. Press and hold "Power" until your Philips GoGear MP3 player turns itself back on. Your GoGear will no longer be frozen and you can use it as normal.
If you require further assistance then please revert back.
Regards
Anand Gupta
May 04, 2011 | Philips GoGear ViBE Digital Media Player
When my iTouch is in suffle mode it plays the same song untill i manually change it. i reset all the settings and it works great for a while but eventually it goes back to repeating the songs again. is...
when you are playing music, look at the top of the screen holding the iTouch vertically. (longer end up and down) Now look towards the upper part of the screen and you will on the right side two arrows criss crossing, this is the shuffle, and on the left side of that you will an arrow circling itself. Touch the arrow that circles itself until it's white, which means that the repeat feature is turned off. If it's blue, the repeat is on and is the cause of your issues. Let me know.
Jul 21, 2009 | Apple iPod touch
My e250 is stuck
sounds like it was'nt safely ejected and is damaged
Nov 09, 2008 | SanDisk Sansa e250 MP3 Player
Screen will randomly change positions and sometimes turn black
Reset by holding in power slide for 10 seconds.
There are no firmware upgrades available from website. They suggest that you call the Geek Squad.
Jun 05, 2008 | Insignia Pilot MP3 Player
Mach speed trio clip problem
the sound on the mp3 doesnt' work the way it's sopposed to the whole song doesn't play normally
May 20, 2008 | Mach Speed Trio Portable MP3 Player
Mp3 player turns on by itself
probably the firware is corrupted, try rebuilding it.
i found a good step by step tutorial in
http://www.samsung.com/mx/support/popup/howToGuidePopup.do?howto_guide_seq=78&howto_guide_step_no=1
and the software can be downloaded from
http://de.samsungplay.com/supports/download_detail.jsp
(just find "yp-t9 firmware")
Jan 07, 2008 | Samsung Yepp YP-T9 Digital Media Player
Mp3 player
Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All)
Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware
Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Dec 30, 2007 | Creative Labs ZEN V Plus MP3 Player
Philips SA5125/37 MP3 Player Logo
67 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
