Question about Electrical Supplies
John deere chain saw model ev55 (1986)
I'm looking for a service manual for this low hour saw. It seems to be starving for fuel. When I give it power It bogs down and stalls. .Also hard to start
This saw is an Echo model ev 550. Get a can of power tune or sea foam engine cleaner and decarbonize the combustion chamber. Also spray some in fuel tank and carb. Replace spark plug. Then the saw will run like new! You can probably download a manual from Echo. Thanks.
Posted on Feb 03, 2009
  • 169 Answers
I don't know where you can get a service manual. You've described the symptoms of a dirty clogged fuel filter down inside the fuel tank at the end of the fuel pickup.
Carl
Posted on Dec 03, 2008
My john deere 316 loses power going up hills and when I have the mower pot on
Sounds very much like a fuel issue, i.e., starving for fuel. Check the fuel filter and replace.
Aug 04, 2014 | John Deere 300 / 316 Hydrostatic Tractors...
Need gas cap for john deere 40v chainsaw
Take your saw to a lawn and garden shop that repairs chain saws. They should be able to help.
Aug 07, 2013 | John Deere 28 30 40v 50v 55v 60v 70v 80ev...
Homelite chain saw model ut10522 engine starves
All late model saw engines (in the US at least) have special 'D' shaped jet screw heads that require a dealer-only special screwdriver. Check the fuel filter for plugging and the fuel lines for decay or other damage. If you feel the H jet setting is responsible, then you are stuck taking the saw to a servicing dealer for adjustment unless you are skilled at making such a tool yourself. Hope this helps!
Sep 09, 2010 | Homelite Garden
What part number oregon chain do i need for a cs-52 john deere saw. They keep sending me the wrong john deere chain witch is three links short. thanks Vern.
Hello Sam;
I cannot find anything by Deere (probably an efco 152) about your saw. Oregon does list some particulars here:
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
I input:
John Deere; CS52; *see below; All (0.325"); All (0.050"); All (yours is likely green - low kickback).
*16" - 66 drive links (the part that fits in the bar).
*18" - 72 drive links.
If your saw does not use either 66 or 72 drive links I suspect the bar, drive sprocket, or drive sprocket and bar nose in use are not what the the saw was originally supplied with. Any local chainsaw seller/mechanic given your chain as a pattern can fabricate one in about 5 minutes. Often a local chain is less expensive (no shipping).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
efcoPower.com
http://www.efcopower.com/indexPri.jsp
Sep 07, 2010 | John Deere 16" Chain Saw Chain (Oregon ...
JOHN DEERE TRACTOR - MODEL A - SERIAL 642202 CLUTCH REPAIR
Try the John Deere web site, I think they will be able to help. donnyb60
Mar 21, 2009 | John Deere Garden
Electrical Supplies Logo
194 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
