Question about Packard Bell Computers & Internet
Laptop is full problems even with norton running, want to reset to factory settings and start from again
Try to reinstall windows again.
hope this helps.
Posted on Nov 02, 2008
My compaq CQ56-219WM (recently restored to factory settings) runs extremely slow and i get a constant "high CPU useage" message. how do i fix this please?
When Norton is active it scans the computer for viruses and this will slow the computer down until it finishes.
You computer will improve with more RAM especially if has 512Mb of RAM.
Apr 17, 2013 | Computers & Internet
How to configuration hard drive to factory default
Step 1:
Which operating system ?
Laptop computers can be wonderful devices, except when the need to troubleshoot arises. Acer laptops are no different. A quick way to fix many problems with an Acer laptop running Windows is to reset it to factory settings. Resetting your Acer laptop to factory settings can eliminate slow operation, registry problems, virus problems and spyware issues. What's more, a factory reset of your laptop may reduce the need for a full reinstallation of Windows.
Back up all necessary data to an external device such as a disk, flash drive or hard drive Make sure all programs are closed and shut down your Acer laptop. Detach any external hardware such as an external hard drive or printer. Press the Power button to boot your Acer laptop. Press "Alt-F10" on your keyboard when the Acer screen appears at the start of the boot-up process. Wait a moment while Windows loads the reset files. Select "Restore System from factory default" in the Acer eRecovery Management window. Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration. Click "OK" in the notice window to proceed with resetting your Acer laptop. Wait while your Acer laptop is reset to factory settings.
Mar 16, 2013 | Acer Aspire 5500 5570-2609 Laptop
When I go to start menu to shut down and press shut down it will just reboot and will ot shut down
Step 1:
Feb 20, 2013 | Acer TravelMate 2300 Notebook
Need factory settings aspire 5920
Laptop computers can be wonderful devices, except when the need to troubleshoot arises. Acer laptops are no different. A quick way to fix many problems with an Acer laptop running Windows is to reset it to factory settings. Resetting your Acer laptop to factory settings can eliminate slow operating, registry problems, virus problems, spyware issues and more. And a factory reset of your laptop may reduce the need for a full reinstallation of Windows.
1.Back up all necessary data to an external device such as a disk, flash drive or hard drive
2.Make sure all programs are closed and shut down your Acer laptop by opening your Start menu and selecting "Shut Down" from the options for shutting down and restarting windows.
3.Detach any external hardware such as an external hard drive or printer.
4.Press the Power button to boot your Acer laptop.
5.Press "Alt + F10" on your keyboard when the Acer screen appears at the start of the boot up process. Wait a moment while Windows loads the reset files.
6.Select "Restore System from factory default" in the Acer eRecovery Management window.
7.Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration.
8.Click "OK" in the notice window to proceed with resetting your Acer laptop.
9.Wait while your Acer laptop is reset to factory settings.
Sep 06, 2011 | Acer Aspire 5920-6727 Notebook
Was in the middle of restoring the computer to factory settings, it was at 98% and it died now it says the windows failed to start
Hi there!
If the restoration to the factory settings did not finish then Windows was not reinstalled properly in your computer. I suggest that you reset again the computer to factory settings. If the restoration died again at any point before completion, I suggest to do a manual re-installation of Windows.
Hope this helps.
May 20, 2011 | Computers & Internet
How can i make factory setting for Aspire 5610 without recovery disc and/or with recovery disc
You do not have to make factory setting, infact you can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+F10 (try both), it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Thanks and regards,
Anil.B.R
Aug 18, 2010 | Acer Aspire 5610 Notebook
Full system scan not getting completed
Open NIS and run LiveUpdate. Keep re-running LiveUpdate until it says that there are no more updates. Reboot the system if prompted to do so (you may want to reboot even if it doesn't say it is required, just to be sure everything got replaced properly). Open NIS again, select Tasks and run a Full System Scan. The error message should not appear again.
Mar 19, 2009 | Symantec Norton Internet Security 2008:...
I purchased Norton through BT on a monthly basis and I got HomeHub and it installed fine. I had to do a Factory reset on computer to clear Trojans and delete problems with uninstalled programs but when I...
Dear Sir,
Generally, if Norton is installed once & uninstalled. It won't allow you to install again. Simple solution is to get the Norton Complete Remover from Norton website available as a free program to tackle these type of situation.
After you run the complete uninstaller, you can once again install norton your system.
Check on Norton website or else write to me, I will give you the link to download from..
Jun 25, 2008 | Computers & Internet
Norton 360
i need to download norton 360, my computer crashed and need to installed.
Dec 15, 2007 | Norton Internet Security 2005...
Computers & Internet Logo
29 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
