Question about Boston Acoustics Recepter Clock Radio
Blue LED display too bright
The blue LED on my HD radio lights up the whole bedroom wall, even on the lowest display setting.  I have taken to covering the radio front with a cardboard sheet, which of course blocks the entire time display. Can I replace the current LED with one of lesser intensity?  My husband's similar non-HD radio has a yellow display, which is fine for me.
  • bwkahan Jan 31, 2009
    Thanks very much for your help.  I really appreciate it.  The problem was solved using your input, although my husband said he had to add some other slight fixit in addition.
TRY........with radio on and set on "AM", hold "Clock" button about 7 seconds and let up - bringing a setup menu. Using tuning knob,scroll to "Hardware". Press tuning knob in, bringing up contrast menu. Press tuning knob in, bringing up "contrast level". Turn tuning knob counter-clockwise to "00". Brightness, dimming level should be "170". Turn radio off to exit, then adjust "Dim" button to your liking.
Posted on Jan 02, 2009
Sharp comfort touch air conditioner screen doesnt show settings and buttons wont work after cleaning. help its hot!!!!!
Switch off the unit at the isolator or fuse box. Leave off for 10 mins to reset. When powering up again and it still wont work, check your remote control batteries are good. Also confirm you haven't "blanked out" the display. Some controls have a display or LED function which blanks out the display so that the lights are not bright at night time. (For bedrooms so that the light doesn't keep you awake) Also check that you have not pressed a "child lockout button" This will stop anything ..
Jul 25, 2013 | Heating & Cooling
The radio led light does not come on
First ~ used deduction, the light is generally don't may not have voltage on the LED's are negative, if is red light blue light general voltage between 3.2 to 3.6 is 1.8 to 2.2 if the voltage is not normal bright LED that is open or damaged
if you want change one please led light
Mar 19, 2013 | 2005 Honda Accord
There is no brightness at all in the display - what would the problem be?
Brightness in display is usually an adjustable feature in most devices and often times due to malfunction this function adjusts itself to the lowest level or someone mistakenly operates it to that level. All you have to do is locate the brightness button and increase the brightness.
If on the other hand this does not work then the LED light inside the unit is either burnt or the wires connecting up to it are burnt. In this situation you will need to refer it to an expert or just replace the unit as cost of fixing might be worth a new one.
Hope this solution has been helpful?
Jan 01, 2011 | Sony ICFCD3iP CD Radio Clock iPod iPhone...
Radio display is not bright
Press and hold alarm time for about a second, then press your tune/playlist button until your bright hi or bright lo choices display, once you chose which lighting you want, do not press anything else. It will set to your last selection.
Oct 31, 2010 | Bose Wave Radio
The power light (bright blue) on my Olevia 26" LCD burns brightly in my bedroom ALL DAY and ALL NIGHT. Is there anyway to dim it?
Had the same problem and took the easy way out: I cut a small piece of electrical tape and covered the LED. There is no way to dim it.
Dec 23, 2009 | Olevia LT27HVX 27 in. LCD Television
Backlights are to bright
Take a ride to the local automotive store like Auto Zone and pick up a small sheet of dark window tint. Cut the tint to fit the display. That should do it. If it's still too bright, apply another layer of tint. Or buy several sheets of different darkness and find the perfect darkness in just one sheet.
Dec 18, 2009 | Sangean America WR-3 Digital AM/FM Table...
Wave Radio-dial face,display very dim.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Mar 23, 2008 | Bose Wave Radio
Alarm clock won't change time with daylight savings
unless it is an automatic , atomic clock none I have ever owned do the change automatically
Feb 27, 2017 | RCA Audio Players & Recorders
Back lighting
Funny, I've got one I've just stopped using because the backlight is too bright, even set at its lowest.
Maybe we could trade ;-)
Is your's out completely, or just very dim?
Jan 22, 2008 | Timex T150 Clock Radio
Bose wave radio/cd
Found this in the manual:
To adjust the display brightness -
The display dims automatically to medium or low brightness, as appropriate for low light room conditions. You can adjust the brightness setting of the display for both strong light and lowest light environments, but not for the medium light setting. Turn the system off before setting brightness levels.
• In a strongly lit room, hold down CD Mode and press Volume up or down to adjust the setting between 5 and 9 (it is preset to 8).
• In a barely lit room, hold down CD Mode and press Volume up or down to adjust the setting between 1 and 5 (it is preset to 2).
• If you do not want the system to dim automatically, set both levels to 5.
Feb 25, 2007 | Bose Wave Radio
Boston Acoustics Recepter Clock Radio Logo
1,391 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
