Question about Compaq Keyboard
Shift key not working
All of the sudden my shift key isn't working. do you have a fix for this
  • 4 more comments
  • kimberly-haw Nov 03, 2008
    neither of the shift keys on my laptop keyboard are working. i did check the sticky keys and there isn't a check mark in that box. any other suggestions would be appreciated. thanks
  • Anonymous Jan 14, 2009
    same thing and hp just says to send it to a dealer to pay to fix it, but their own site says it's a problem with the bios
    not sure what to do; obviously i don't have caps
  • Anonymous Feb 05, 2009
    yeah but its not just my shift key its the control key also
  • Anonymous Mar 10, 2009
    either shift keys work. stickykeys is not on. i have rebooted and followed all help advice. its driving me mad.
  • Anonymous Mar 29, 2009
    nothing happens if sticky keys is on or off .Both shift key not working
  • Joe winling
    Joe winling Nov 04, 2016
    I just need to know how to get the barrel out
    Scholar:
  • 35 Answers
You have 2 Shift keys on the keyboard. If the other shift key is working then the shift key that is not working is defective. You should consider replacing the keyboard on your laptop. There is no setting on Windows that can disable the shift key.
**Note : If both Shift keys are not working, Try to check if sticky keys feature on windows is on. Sticky keys should be disabled. To disable sticky keys, Click on start and Go into control panel > Accessibility Options, and under keyboard there is sticky keys. Remove the tick and click apply and OK.
**If "Use Sticky Keys" is unchecked, that means sticky keys is disabled.
Posted on Nov 02, 2008
In vista go into control panel>ease of access center>make the keyboard easier to use and make sure there are no boxes checked. If there are,uncheck and hit apply. On your key board hold the number lock key for 5 seconds and check to see if your shift keys are working.
Posted on Sep 20, 2012
Okay. I never found this solution posted so I hope this helps anyone out there that finds this topic. If your laptop is anything like my laptop, the keyboard ribbon has a fold. I took it apart and noticed that when I held my keyboard at a certain angle and above, my shifting would work again. My solution was to duct tape a wedge on that fold (my wedge was a tiny piece of folded paper). Now, when my keyboard is flat, the ribbon doesn't completely fold onto itself. Note, depending how big your wedge is, this may be temporary. Also, too much tension may break your ribbon cable.
Posted on Nov 22, 2010
  • 3 Answers
If you're using Skype, turn off keyboard short cuts. They define by default that Shift I, Shift A, Shift V, and Shift H all do things with skype calls.
Keyboard shortcuts are under options/advanced
Or, if you liked the shortcuts during a call and want to keep them on, signoff skype when you're typing a document....
Silly silly silly.
Posted on Mar 13, 2010
I had the same problem with my Acer Aspire 5943G, both shift keys were not working. Other than that everything seemed working fine, and nothing certainly relate to sticky keys! What worked for me was that i have disabled the touchpad (not to resolve this issue but it was getting in my way while typing) from the touchpad properties and my shift keys started working at once. I don't know if this is an Acer solution or unique to me but you can give it a try.
Posted on Mar 05, 2012
I have an HP laptop running Ubuntu Linux 11.10 which had the left SHIFT key not working correctly. Either nothing would happen or weird character would be emitted when pressed. I was running a program to disable the touchpad as I use an external trackball device and the touchpad was getting annoying.
I found that exiting from the Touchpad Indicator / Controller program fixed my SHIFT key problem.
Moral of the story is that this was not a hardware issue with keyboard but a software bug of some sort. So before you rip your keyboard out check for what software you have running first and remove extraneous ones.
Posted on Oct 25, 2012
2000 Plymouth Neon ignition stuck again! I have replaced the ignition control module and it still isn't working? PLEASE help!
Try lifting the shift lever while turning the key. You can also try holding the outside ring of the ignition switch in while turnig the key.
Apr 21, 2013 | Raybestos 2000 Plymouth Neon Coil Spring
The.spacebar.stopped..working.
If your space bar isn't responding when you press it, or if it responds sluggishly, it's possible that you have inadvertently enabled the "Sticky Keys" or "Filter Keys" accessibility option in Windows.
When these options are enabled, your keyboard response time will be dramatically slowed and may require more than one tap to register a keystroke.
Fortunately, it's easy to disable these functions and return your keyboard to normal working order.
Click "Start" and select "All Programs."
Click "Accessories" and select "Ease of Access."
Click "Ease of Access Center."
Click "Make Keyboard Easier to Use."
Click "Set Up Sticky Keys." Deselect the checkbox that says "Turn on Sticky Keys When Shift is Pressed Five Times." Make sure the box that says "Turn on Sticky Keys" is not checked. Click "OK" to save your changes.
Click "Set Up Filter Keys." Uncheck the box that says "Turn on Filter Keys."
Click on the checkbox next to "Turn On Filter Keys When Right Shift Is Pressed For 8 Seconds" to deselect it. Click "OK" to save your changes.
Click "OK" again to save all of the keyboard accessibility changes you have made.
Hope this helps
Oct 29, 2012 | Gateway LT2021u Netbook
IMac keyboard suddenly isn't working. Mouse works, but I can't enter any typed message.
if it's bluetooth, are the batteries ok and is it showing up in your bluetooth settings? if it's wired, try another usb port
Oct 21, 2011 | Apple iMac G5 Desktop
Key stuck in ignition of ford focus. column not locked
I had this same problem with my 2006 ZX4 Ford Focus. My focus has an automatic transmission. In order to get the stuck key out of the ignition, I discovered that there is sort of a "ring" on the gear shift that will sometimes slip down a little and cause the ignition to lock the key in place. The ring is located just benenth the plastic gear shift handle, right on the end there. If you push the ring up, you should be able to get the key out of the ignition. I found this out by accident. I know that sounds weird, but it actually works; at least it did for me. At first, I thought I hadn't put the gear in park. The ignition will not release the key if the gear isn't in park or if the steering wheel isn't in its lock position. I think most cars work on this principle; that wasn't the case here. For all of you 2006 Ford Focus owners out there having this problem, try my suggestion and I would also spray some WD-40 in the ignition hole too ( after you get the key out) . I hope this helps you folks out there. Good luck and have a nice day!:)
Sep 09, 2011 | 2006 Ford Focus
Why my email cannot open. Invalid ID or password.
Make sure that your using a "Shift" key/selection before capital letters in your login name or password; if there are any capital letters.
If both login name, and password only contain lower case text, make sure "Shift" isn't being used and that their isn't a "CAPS LOCK" engaged.
Aug 24, 2011 | Yahoo YHT-630 System
The shift key on the keyboard worked half the time for a while and now it won't work at all
Try the following:
1. Press the shift key several times and check if it changes anything. This is to make sure the inner part of the key isn't sticking onto the connector.
2. Press other keys as well, like Ctrl and Caps Lock.
3. Is the other shift key working? If it is, it is most likely that the other one is faulty. If it's the case, you need to buy one from ebay.
Try to search on ebay and see if you can find just that single key, some sellers are selling just the key for a much cheaper price. If you can't find one that's selling single keys then am afraid you should buy yourself a keyboard replacement.
Hope this helps.,
May 06, 2011 | Sony VAIO VGP-WKB1 Keyboard
try to use virtual keyboard in start/allprograms/accessories/accessibility/on screen keyboard. And press shift. If that problem still occur when you use on screen keyboard (osk), unplug your keyboard, and try to use osk again. If that's still occur, surely you got virus or setting error
Apr 19, 2009 | Acer 2581168-0001 Keyboard
Compaq Keyboard Logo
52,344 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
