Question about Sony CDXF7715X
Not Reading Burned Discs
When I insert a burned disc the players reads it for a awhile - part of or perhaps one song - then stops. It happens for all discs created on several different computers and burners. Any ideas?
2 Suggested Answers
  • 84 Answers
SOURCE: MP3 files start skipping/popping after few minutes of playback
Sony say in the manual that if you record high bit-rate mp3's the sound may be intermittent. I feel this is due to the decoder having to move ALOT of bits around to play, try some makeing a disk with mixed rate mp3's on. e.g.) some 64Kbps, some 128, some 192, and some as high as you can get and see if there is any differ Luck
Posted on May 04, 2007
  • 3 Answers
SOURCE: CDX-M8800 won't read CD-R discs
i was going to sugest switching brands of blank cdrs but you say ones that were working fine are now not the problem is with the stereo not the cds.
 did you try a lens cleaner the eye may be dirty ..or possibly going bad.. Hey does it read regular bought disks ok???
Posted on Nov 01, 2007
0 characters
1 Points
My cd player has an ERROR15
Error 15: Disc contains no data.
If other discs work - it could be a bad disc.
If it is a burned disc - are the songs in the correct format?
If no discs work - the laser could be out of alignment - requires professional repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 18, 2010 | Pioneer DEH-1900MP CD Player
Does the kenwood kdc-2025 have a way 2 hook up a mp3 or i-pod?
no, it says mp3 player because it can read mp3 discs that are burned with Kenwoods software.
Dec 30, 2009 | Kenwood KDC-2025 CD Player
Some players are picky with certain cdrw/dvdrw discs. You might have to experiment with different brands/types for your discs. I used to have a cd player (teac) which would just refuse certain brands cd-r discs but play others just fine. I know it sounds odd, but once I noticed which ones work and which ones don't I never looked back.
Also, have the "problematic" discs been recorded on just one recorder? Have you tried playing discs recorded on a different recorder?
Also - I'm sure you've already tried it-it's always a good idea to clean the laser just in case.
Hope this helps+
Good luck,
Nov 13, 2009 | Boss BV7970 CD Player
TOC eror
The TOC error is the same error seen on computer disks, TOC is the table of content, this has to be read before the the unit will know the details of tracks etc......
If every disk inserted (not just burned discs) has this error, the laser is faulty or out of alignment. Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 01, 2009 | Kenwood Sirius KDC-MP522 CD Player
CD doesn't work. LED readout says FRMTREAD, error 12. ;what's happening?
If this error appears on any music CD (burned or store-bought), it's likely the laser/lens assembly is having trouble focusing well enough to read the disc. You can try resetting the unit (use a paperclip or ballpoint pen to press the button in the small hole next to the eject button), but there's only a small chance this will help. You could also take it to an electronic repair shop to see how much a cleaning would cost (usually more than the player).
If it only happens on burned discs, try changing brands of CD-Rs or even burning the disc at a slower speed. If the songs are burned from iTunes, try burning other formats (i.e. MP3) via a different method.
Mar 16, 2009 | Pioneer DEH-P6800MP CD Player
Won't read mp3 and wma cds
The discs were not "finalized" or "closed" - place the cd's back on your computer cd-rom drive and search the help file of your CD burning software and search for "closing disc" or "finalizing disc." Some programs will allow you to close or finalize after you have already burned them, but others (Sony SoundForge is one exmaple) will not allow it - you may have to re-burn the discs and select the option that says "close disc after finishing" (this option is usually left unchecked by default, because closing or finalizing a disc prevents you from adding any new information to the disc).
-Tha Mp3 Doctor
Jan 02, 2009 | Panasonic CQ-C300U Car CD/ MP3 Player
My mp3 player will not load up songs
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
Dec 29, 2008 | Naxa Electronics NX-671 Car CD/ MP3 Player
2002 JEEP [Wrangler] CD player will not play Nero burnt CD's
I had the same problem in my 1998 Jeep GC Limited. It has been a year and a half since I have played a burnt cd in my cd player. I researched everything possible and came to the conclusion that it was either the type of cd I was using (some cds with prints etc are hard for the laser inside the player to read) or the burning speed, and after many failed attempts, I still couldn't find a combination that would work. Then yesterday, my brother had a burnt cd he had made with his computer and we tried it just to see if it might work and it did! So, the brand of cd is Memorex, the type is CD-R, and they are 80min. worth of recording time. I purchased some of these cds at Hastings (although I'm sure they are avaliable wherever you purchase blank cds) and tried burning one in my laptop just to make sure it was going to work and it did! I burned the cd using windows media player and before I started the burn I went into 'burn options' and set the burning speed to the lowest possible. Hope this helps!
Dec 11, 2008 | Jeep AM/FM Cassette with CD Changer...
Most CD players that would not play a disc even with a known good disc inside signifies that the laser eye/lens is not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs
2. defective, weak, dirty/dusty burned-out laser eye/lens;
3. dirty, dried up lubrication of the slider shafting (where the laser eye's carriage moves) or some other components; and/or
4. dirty, dried up lubrication, defective spindle motor.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door (if it's got one) once the disc is loaded;
5. relube, clean as necessary but that would require pulling the unit out of the dash.
Should this not be corrective, perhaps your best bet would be to seek the services of a qualified professional such as those in a Service Center. Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Thank you for using Fixya.
Feb 14, 2008 | Car Audio Receivers
Toc error
toc error means "table of contents" error... means the player is unable to read the disc at all. May have a dirty focal lense to laser. clean gently with some windex on a cotton wool bud. It may be a faulty spindle motor that spins the disc. the bearings get worn or uneven and do not allow for disc reading to be successful. a check for this is a drop of oil to the bearing. It may then start to read discs, but will still require the motor to be replaced. . Check for the above... but if there is more required, take it to a Kenwood 'Agent... it may need a laser change
Dec 04, 2007 | Kenwood KDC-MP228 CD Player
Car Audio Receivers Logo
Top Sony Car Audio Receivers Experts
Larry Stiles
Larry Stiles
xxxxxx xxx
Are you a Sony Car Audio Receiver Expert? Answer questions, earn points and help others
