Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Where is the fly back fuses 3 of them
I would like to know where the 3 fuses are in the fly back in detail could you tell me please
  • artic429 Jan 03, 2009
    Do these fuses just pull out like a regular fuse? I see that the red cap just comes off exposing the fuse inside. Is that soldered in place or does that just pull out too?
    Genius:
  • 1,030 Answers
Fuse in flyback. prehaps you mean the special fuses that are located next to flyback. the fuses are three brown rectangular brown or tan looking to the right of flyback. the one in the middle is f231 the one to look at if you have convergence problem.
Posted on Nov 03, 2008
Flybuys loginWhy is it hard to contact Fly Buys to tell them that we want to use up most of our 570 points on a Panasonic phone, code 36406 obtainable from Noel Leeming with one of your vouchers? Beryl...
Why won't you contact the Flybuys, with all these details? This site can't do anything for you, then answer questions. And I don't know why it is difficult to get in contact with that site.
Jun 23, 2014 | Cameras
Datasheet fly-back panasonic ztfp12507a
Actually, what do you want to know? Provide more details, please. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 21, 2014 | Panasonic Televison & Video
May i know the number of fly back transformer used in jvc av-21L11?
Download the service manual to it. It will have all details.
Jun 01, 2012 | Thomson 14MG135 14" TV
Tv screen is completely dark and barely see-able tried unplugging and plugging back in. please tell what this problem could be
solution
step 1: at first check your TV contrast control switch
step 2: Test your fly back transformer
step 3 : A.C. transformer out put voltage test
Jul 27, 2011 | Mitsubishi WD-60737 60 in. HDTV
I can't find auto converge choice in menu of rca 52" rear projection tv.model # R 52 WH 74.
You have 3 pico fuses by your fly-back transformer. One of them blew that controls your convergence circuit. Your TV now thinks that it is a Basic CRT set with 1 tube. Find the bad fuse and replace with a 1/2 amp pico fuse, and re-solder all the pins of your fly-back transformer. Your menu should have the convergence option again.
Apr 27, 2011 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 APPEARS IN 3D, I DON'T KNOW WETHER TO REPLACE FUSES OR DO I NEED MORE TO FIX THE PROBLEM?????? PLEASE HELP ME!!! -MOTHER OF THREE
Hi, thank you for visit fix ya.
Common problem on this tv, Loose connections-and open fuse.
Re solder all connections around fly back, and replace a little fuse located beside fly back ( is a little brown box), you will See 3 fuses parallel beside fly back; replace fuse 400ma.
Thank you
Jul 28, 2009 | Televison & Video
beside fly back you will se a 3 smals fuses ( red color), one is open ( 1-2 amp), and resolder fly back terminals.
Apr 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Detailer put coin in cigarette lighter
sounds like it blew a fuse. First remove the coin and check all the fuses. An owners manual will tell you where the fuse is located.
Feb 10, 2009 | 1999 Mercedes-Benz S-Class
Tv will not come on
HELLO. it sounds like it could be a couple of things why your set will not come on. 1. you could have a blown fuse.on the chassis. 2. you could have a bad power supplly transformer. 3. you could have a bad horizontal output transistor and a bad fly back transformer. it could be one of them or both of them as well as a blown fuse. because the fuse is blown from the horizontal output transistor burning out or the fly back transformer burning up. check and see if you have a burnt fuse, the size iof the fuse will be 5 amp to 6.3 amp fuse on the chassis right inside where the 110 ac cord comes in and hooks to the chassis. the fuse should be right there, look for it. hope this helps you"GOOD LUCK"
Aug 09, 2008 | Televison & Video
Fly Lifeview 878 chip set
Sir,
Try this link to download the software driver.
http://members.driverguide.com/driver/detail.php?driverid=86068
still if any problem tell me i will fix it. ok bye
Good luck
Don't forget to rate the solution
Mar 12, 2008 | Computers & Internet
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
118 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
