Question about Pioneer DV410V DVD Player
USB support suddenly not working
I was using a card reader and a flash  card (4 gig kingston) to watch avi content on my player. It was working perfectly up until a couple of days ago, suddenly it stopped recognising anything being in the usb port. I have in the process pulled the system down (renovating) and put it back together again. There has been no damage, though perhaps some dust?
Any thoughts?
  • jermhorse Nov 10, 2008
    The DVD player suddenly doesn't recognize external hard drive, or Sony PSP device, that I have been using to play AVI's on my television via USB mode. I can't even get a linux menu up to explore device. It works great on DVD mode but now USB outlet seems to be dead. Everything was working great until a week ago. That is the most frustrating part. I read something about a firmware update possibly..... or maybe I changed a setting in initial set-up? Does anyone know why this is happening? Any help would be greatly appreciated. thanks
  • baudelaire Nov 27, 2008
    That's excellent. thanks for that. I just solved it by buying a thumb drive. I've had no trouble since, but that sounds like a really logical solution and something you don't imagine you can do with a deev player.
Thanks, curtaudrey. Your solution saved me shipping charges on two decks. I had tried connecting a 500gb drive to view divx movies. Your help brought both decks back to usb functionality, after unplugging the unit first, then holding the stop button and and power. The units reset themselves.
Does anyone know if this deck works with usb hard drives, no just memory sticks?
Posted on Jan 18, 2009
I have a similar problem and got it to work by resetting the player to the initial settings.
To do this, turn the player off. On the front panel
Hold down the STOP button and turn the player back on.
Display will show CLEAR.
You will have to reenter your settings, but it recognizes the USB again.
I just got this to work, so who knows how long it will last.
Posted on Nov 27, 2008
My LG DP122 will play some AVI files from a USB device but not others.
figured this out, lg dp122 uses DivX Home Theater profile, so the technical specs of the video must match that.
Those specs can be found here: http://www.divx.com/files/DivX-Profiles_Tech-Specs.pdf
Jan 23, 2013 | LG DP122 DVD Player, Multi Format...
What's your problem?My husband got a Vivitar ViviCam 7028 as a rewards gift from his company and we've been busy taking lots of photos and video on it, but when I try to download the photos to my...
The first problem is explained by the error message. Your camera is consuming too much power to go through a USB hub. Try connecting it directly to a USB port on your computer, without going through a hub.
The second problem is most likely related to the card reader. You didn't specify the exact model of Belkin reader so I can't give you a definite answer, but it appears the reader is designed for SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it will not work with devices not specifically designed to work with SDHC cards.
To sum up: If you want to use a USB port, connect directly to it without going through a hub. If you want to use a card reader, make sure the reader is SDHC-compatible.
If you have additional questions, or some part of the above isn't clear, please feel free to respond to this post.
Oct 22, 2011 | Cameras
Missing a card, how do i get one? and what software do i download to make it work. How do i get music and videos on here?
Zvue uses a standard SD memory card (I think there may be a 2 Gig upper limit). Mine came with a 1 Gig SD card and I can use the one from my digital camera as a spare. I use an HP card reader plugged into my PC and just drag and drop files as needed onto the SD card. Then put the card into the Zvue.
To convert the videos download "Free Video Converter" and use the following settings: Output format - Avi, Codec MPEG-4, Size - 240 x 176, Fps - 15, Bitrate - 4880. Choose Rescan from the Options menu, and then relax and enjoy the music.
Apr 12, 2011 | Zvue ZV002 Digital Media Player
I have bought a 4 Gig SD card but my camera won't accept it
If it's a 4 GB card there is a chance your camera doesn't have SDHC support.
SD cards 4 GB and over are called SDHC cards and your phone may not have the ability to "talk" to the card.
Jul 09, 2010 | Kingston 4GB Secure Digital High Capacity...
Picture sides cut off when watching avi files
My new LG LCD is not syncing the video and audio when playing avi movies on either USB stick or HDD.
Dec 28, 2009 | LG 37LC5DC 37 in. LCD Television
My kingston 8 gb data traveller suddenly became skymedi storage device.i cannot access it. can anybody help? thanks.
try maybe it is bricked or damaged, try downloading Pheonix products which can help u repair any usb damaged storage media, worked on my 8gig usb and nokia n95, or u can try googling flashing utilities for you flash
Oct 07, 2009 | Kingston flash memory card - 256 MB -...
Kingston DataTraveler Card Reader Problem
I have one also here just like that always write protected, you know what is the problem of that is your card reader, its a USB connection input to your computer, all you have to do buy a new one Card Reader, I'm sure it will not work anymore unless you try to repair that Card Reader to a Technician. Always pop-up write protected but when I twist my USB Wire sometimes it work, sometimes not. Don't let plug it again because this time your USB connection in CPU will be damage. Supposed to be only Card Reader is the and maybe your USB Connections too will damage.
Hope this idea will help you.
Jul 29, 2009 | Electronics - Others
My computer won't recognize my phones memory card!
Well I found that these older card readers will not read the 4g sdhc format. In your case you found a 4 gig card that can be read (your sisters) Bring your's back to the store and get an exchange for the brand your sister has, let them know this. The knowledge for them is good. They most alway accomadate just to keep the customer happy.
Jul 26, 2009 | PNY 4GB microSD High Capacity Mobile Media...
4GB micro sd card.
According to what I've read, you can double the original memory, but no more than that, so the max you can have on a Sansa e250 would be 4 GB (2GB internal memory and 2GB external memory). I also read that the micro SD cards holds
music only-no video.
Nov 13, 2007 | SanDisk Sansa e250 MP3 Player
Pioneer DV410V DVD Player Logo
464 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
