Question about Whirlpool 3.2 cu. ft. Plus Washer
Leaks occur in spin/empty cycle
Model 32822 Super Capacity, puchased 2002. Finding water on floor toward end of wash cycle when water level is set to higher limits. Have tightened hoses; same problem. Runs ok when on lower water limits. Does not overflow when filling.
Thanks,
Bud
Bud@CB4MyHome.com
  • 864 Answers
I just diagnosed a similar (intermittent) problem with a Whirlpool washer that came with the house my daughter bought.  When the washer spins while emptying, the water rises up the side of the tub.  It hits the rim of the tub and most of it goes back into the tub but at the opening in the lip of the tub for the bleach dispenser it shoots out like a geyser and runs down the inside of the cabinet onto the floor.  While we were trying to figure out how to fix it we discovered that the spin function was not consistent.  Sometimes the washer would spin while emptying (either after wash or rinse) and sometimes it would not.  The overflow problem seems to occur when there is a large amount of water (small load set for large or super) and a high spin rate.  Due to the spin inconsistency (and a power company rebate) they decided to get a new energy efficient washer/dryer combination rather than try to fix the problem.  In another post I read that someone had an overflow/no-spin problem that was solved by replacing the 2-speed motor.
Posted on May 19, 2009
I had the same problem, you need to turn the washing machine on it's side and look for a pin hole leak in the seam of the plastic holding drum on the bottom. I used a silicone sealant, "GOOP" , let it dry for 1 day and problem solved. It has not leaked in two years. good luck!
Posted on Feb 08, 2009
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Heavy Duty Super Capacity will spin but will not drain.
Pump may no be engaged, broken belt or clogged pump or defective pump. Easiest way to tell is to prop the unit up but keep it level. Put a mirror on floor under pump area, inspect belt to make sure its not broken. Inspect pump many are clear plastic so you can see any blockages. If looks OK, then put unit through wash cycle. Watch as it gets to the end of the wash cycle (good flashlight helps to direct the light where you need it) to see if belt is spinning and if pump is actually turning etc. I usually put a piece of 4 x 4 front to back under 2 feet on each side. Just make sure not to let tf slip off and don't put hands etc, under while its running.
Jan 01, 2015 | Washing Machines
Mav4757aww leaks water during spin cycle with full loads only
Thanks for the quick responses.Pulled front cover,ran a load on high level, no leaks .Ran a load on super level and when drum spins when full of water water level rose and poured out of left front side on top of drum. Pulled plastic ring on top of drum and and found piece of seal missing where leak occured .Ordered upper tub seal, should solve problem
Jul 27, 2012 | Maytag Ensignia MAV4757AWW Top Load Washer
IN THE WASH CYCLE THE TUB FILLS ALMOST TO THE TOP THE DRAINS. THE OL CODE THE APPEARS AT THE END OF THE CYCLE
Hi, the OL code means Overloaded..
OL flashes when the machine/motor control detects a load size that exceeds the washer's capacity.Open the door lid to clear display, remove excess laundry, then restart the cycle.
Oct 04, 2010 | Whirlpool WTW6400SW Cabrio Washer
22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
May 17, 2010 | Kenmore 22942 Top Load Washer
Spin vefy fast
A rapid spin cycle is actually a GOOD thing. This is an indication that the gearcase (transmission) and the drive motor are both running strong.
If the washer shudders during the spin cycle the first thing you need to do is check to ensure the washer is properly leveled. The following link explains:
http://www.fixya.com/support/r3868923-level_whirlpool_top_loading_washer
The model Whirlpool top loader you have, has an auto-leveler mechanism on the back two legs that can become unlevel periodicailly. You should check the washer level from time to time when it is empty. You need to also make sure the washer is level in ALL directions (front-to-back and side-to-side).
Accidental unbalance problems that can occur from washing blankets, comforters, or heavy loads of towels can also cause the washer to become unlevel and shake. This can also contribute to the level mechanism becoming unbalanced.
Overloading the washer can also cause unbalance problems. Washing blankets or conforters can cause the load weight to shift to one side of the tub. This will result in a tub that shakes violently and bangs against the cabinet. You may have to redistribute the load weight when washing heavy items. This can also occur when washing loads of towels. This is NORMAL as some heavy items do not distribute the weight evenly.
Another problem (which is less common) that can contribute to wash unbalance problems is a weak floor under the washer. If the floor flexes (even the slightest) during the spin cycle, it can cause the washer to bounce or shake. Mobile homes or laundry rooms on the second floor of a home are notorious for having weaker floor structures. This washer has a 35 gallon tub capacity. Coupled with the weight of a wet load and the spinning action, this can put a lot of centrifugal force on a floor.
If you have any questions or concerns, please post back and let me know. I hope this information is helpful to you.
Apr 25, 2010 | Whirlpool LSR5132PQ Top Load Washer
CANT DRAIN OR SPIN WATER OUT OF MY WASHER
Set it toward the end of any cycle - it will sense the water level and pump it out before moving on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 26, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool 3.2 cu. ft. Plus Washer Logo
189 people viewed this question
Dan Webster
Dan Webster
Sal De
