Question about HP Jetdirect 615n Print Server
Jetdirect 615n ip config
When I print the config it shows 0.0.0.0 About a year ago, I used some software and a twisted ethernet cable attached to my laptop and set the ip.
I do not remember what software I used.
    Genius:
  • 1,124 Answers
You can use Jetadmin directly from HP to set the ip address.
You can download the software here
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=18964&prodSeriesId=27915&lang=&cc=us
Also you can reset your printer to a factory settings and print a configuration printer page, in that page you will see the ip address of your printer (default)
To reset your printer to factory settings do this
Keep holding down the button ONLINE or GO when you turn on your printer.
You will see on the lcd display " Cold Reset or Restoring Factory Settings "
(If your printer doesn't have lcd display, the lights will start blinking once).
After that you can add the printer doing this:
Click Start, then Printers and Faxes (Windows XP) or Windows icon,
Control Panel, Hardware and Sound, then Printer (Windows Vista).
Double-click Add a Printer to start the "Add Printer Wizard," then click Next.
You will be given an option between Local Printer and Network Printer.
Select Local Printer. Make sure the Automatically detect and install my plug and play printer is not selected (Windows XP), then click Next.
Select Create a new port in the Type field, then select Standard TCP/IP Port.
Click Next (twice in Windows XP).
In the Printer Name or IP Address field, enter the Domain (host) name of the printer.
Click Next, then Finish.
If you are placed back in the Select the Printer Port window, make sure that Use the following port is selected.
From the list, select the Standard TCP/IP Port you just created.
It should appear at the bottom of the list. Click Next.
Select the manufacturer and printer model, or select Have Disk if you are going to install the drivers from a CD or have installed them from the Web.
Click Next.
In the Name field, enter the name that will identify your printer on your computer.
Specify whether you want this printer to be the default printer. Click Next.
Select Do not share printer, then click Next twice. Click Finish.
The printer should now be accessible from your computer.
Posted on Nov 02, 2008
  • HP Master
  • 13,433 Answers
Hey,
all the instructions for your unit are on this HP page
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&prodClassId=-1&contentType=SupportManual&prodTypeId=18972&prodSeriesId=71540
I will take a look also and let you know if I find the details before you do.
Tip
I think there are 6 ways (at least?) to connect this printer: (1) Direct to Mac...
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable(3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch(4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless)(5) WiFi to router, with Mac/PC via Ethernet to router/switch(6) WiFi to router, with Mac/PC also via WiFi.
As (1) should be simplest, tried this first. First document would print instantly and completely, next doc would hang in queue with unexpected msg, "Printer is offline." Only way to print 2nd doc was to power cycle (off-on) the printer. This problem occurred whether 2nd doc was sent to printer before or after 1st doc had printed. Tried 2nd USB cable, tried new driver, tried reinstalling printer; same problem. Spoke to both Samsung and Apple support, including both on a conference call; never got this to work and never clarified if problem was in printer hardware/software, driver, or something else. Both companies now showing this issue as unresolved.
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Procedure required connecting first via Ethernet, obtaining Configuration Report by holding down orange button for 5 seconds, then using browser to connect to the printer's IP address. Also required different driver for wireless config (as opposed to USB).
Bottom line: What seemed simple - USB direct connect - proved unworkable, but wired and wireless network config works fine.
on Apr 25, 2010 | Office Equipment & Supplies
How to counfugre asa 5505 cisco Router
Use the Cisco ASDM or SDM software, that will give you an easy graphical interface to configure the ASA. One of them would have been shipped with the device.
Don't forget the ASA has to pre-configured, just a simple config. Have HTTPS enabled and telnet/SSH helps as well if you dont have a serial port or the console cable.
Cisco's website will give you quite a lot of info for free...
Jan 18, 2010 | Cisco ASA 5505 Firewall
Dhcp setup on a Cisco 2851 router
Let's look at how to configure basic DHCP on an IOS-based router. For this example, we'll start off with the default configuration on a Cisco 2611 router running IOS 12.2. (The configuration should be the same—or very similar—on all IOS-based routers).
To begin, connect the router's Ethernet port to a switch, and connect the switch to a laptop, which will serve as the DHCP client.
To configure Cisco IOS DHCP, follow these steps, which include sample commands:
1.Configure an IP address on the router's Ethernet port, and bring up the interface. (On an existing router, you would have already done this.)
Router(config)# interface ethernet0/0
Router(config-if)#ip address 1.1.1.1 255.0.0.0
Router(config-if)# no shutdown2.Create a DHCP IP address pool for the IP addresses you want to use.
Router(config)# ip dhcp pool mypool3.Specify the network and subnet for the addresses you want to use from the pool.
Router(dhcp-config)# network 1.1.1.0 /8 4.Specify the DNS domain name for the clients.
Router(dhcp-config)#domain-name mydomain.com5.Specify the primary and secondary DNS servers.
Router(dhcp-config)#dns-server 1.1.1.10 1.1.1.116.Specify the default router (i.e., default gateway).
Router(dhcp-config)#default-router 1.1.1.17.Specify the lease duration for the addresses you're using from the pool.
Router(dhcp-config)#lease 78.Exit Pool Configuration Mode.
Router(dhcp-config)#exit
I hope this is helpfull for you.
Thanks
Vikrant
Oct 26, 2009 | Computers & Internet
DLINK DP-300U. Desktop shows printer offline, Laptop prints OK.
First thing.. plug printer directly into PC.. does it work? .. if so its is a port setting. If now it is the device config on PC
If Port Setting Issues.. are you going through any other devices on the network or is you firewall blocking the IP.
If device Config issue check to see it is setup up as an IP Port not a normal local port
Jul 15, 2009 | D-Link DP 300U (DP-300U) Print Server
NO CONNECTION (LAN) on Brother MFC-440CN
I had the SAME problem. I have 3 pc laptops and 1 Mac. The Mac could still print, but the pc's were hosed. I called BrotherUSA and this fixed the problem!
Go to your printer and after making sure it's connected to the network with the Ethernet cable, go to Menu > Print Reports > Network Config. This will print a page that shows your printer's IP address. We need to config that address in your Printer, Fax and Scanner settings in Control Panel.
Go to Control Panel > Printers & Faxes. Right click on your printer > Properties > Ports tab. Click Add Port and select Standard TCP/IP Port. Click New Port and click Next on the wizard. Enter the IP address of your printer in the first field (the second one will auto-fill). Click Next and Finish. Printer's done!
Right click on your PC-FAX in Printers & Faxes and Properties. Click on the ports tab and just check the box that you just created for Standard TCP/IP Port. Click OK. Fax is done!
Go back to Control Panel and select Scanners & Cameras. Right click on your printer/scanner > Properties > Network Setting tab. Select the Specify your machine by address radio button and, if it's not already in there, enter the IP address of your printer. Click OK. Scanner's done!
This will work as long as your router is running. You may need to repeat this process after a power outage or if you need to reboot your wireless router. Not too bad, though! I just wish everything was as easy as a Mac!!!
Jun 25, 2009 | Brother MultiFunction Center MFC-440CN...
Can not set ip address on 615n
its called an Ethernet Cat5/6 cable.
ask ? this is real HP, fixya is not.+
https://h30434.www3.hp.com/
Jul 31, 2017 | HP Jetdirect 615n Print Server
DPR-1260 ... prints but cannot access web config page
To get into the web configuration you need to know your firmware on the DPR-1260. If it is 1.12, us http://dlinkps-xxxxxx where the X's are the last 6 number of the mac address. If it is 1.20 and up, use http://dlink-xxxxxx, where the x's are the last 6 number of the mac address. If you do set it up as DHCP or static and know the ip address of the print server just type in the ip address of the print server on the address bar.
Oct 21, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Arc 260m network help?
You will need to use the Sharp Network configuration program. This should allow you to setup the printer for network printing. You will want to use 'manual' settings for the IP. Example
IF DHCP is used, you will want to switch to Manual and put in a 'correct' ip.
IP Address: 192.168.1.189
Subnet:      255.255.255.0
Gateway:    192.168.1.1
The Gateway will not be necessary if you do not plan to use the advanced functions to e-mail scans, and prints.
Sharp Network Administration software link
http://sharp-world.com/products/asia-doc/c/download/license_01.html?link=http://www.sharp.co.jp/print/document/download-e/utility/Sadmin.ZIP
Oct 10, 2007 | Sharp AR-C260M All-In-One Printer
HP Jetdirect 615n Print Server Logo
439 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
