Question about Sanyo DP42746 42 in. Plasma Television
Sanyo Plasma Service Manual
Jerry,
I saw that you posted on a couple of topics about Sanyo dp42746 42" plasma tv's. I was wondering if you had any advice on where to obtain a service manual for this set?
Thanks,
Jono Gaughan
    Genius:
  • Sanyo Master
  • 1,689 Answers
The only source would be Sanyo. They can refer you to their parts sales rep for your area.
Just to make a suggestion, there is not much you can service in these sets. Some of these service manuals can cost upwards of $60 to $150 depending on the manufacture and model.
Servicing at the component level without the training, extensive diagnostics systems, jigs, and tools is mostly impossible unless it is a simple obvious fault. These sets are extremely complex in their assembly and design.
At the service centers they service these sets by board and module swapping. These sets are basically serviced like as if it was a PC computer. They have the basic calibration setups to calibrate replacement boards when necessary. Sometimes the new boards have to be matched.
I also found that if the set is more than about four to five years old it is sometimes impossible to have replacement boards. The technology turn-over is very fast with these flat panel TV sets and monitors.
Jerry G.
Posted on Nov 08, 2008
On a plasma 50 inch tv Sanyo model number DP50749 it got black line coming down the front of the tv, what is the problem
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 04, 2014 | Sanyo DP50749 50 in. Plasma TV
Sanyo plasma tv led 8001 blinking 12 times, indicates d12v code
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 20, 2014 | Sanyo DP42746 42 in. Plasma Television
Can you find me a replacement remote for my older sanyo plasma tv?
Anon, replacement remote for older sanyo plasma tv. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Sanyo LCD HDTV TV Remote Control GXBC GXAB GXBJ GXBD HT32546 DP50747...
Sanyo Remote GXBJ eBay
Welcome to Remote Central Universal Remote Control Reviews More
How to Program Universal Remote
https://electrohelponline.blogspot.ca/
Sep 26, 2014 | Sanyo HP261000500A T-Con Board V26DC1.,...
Tv shuts off
http://www.retrevo.com/s/Samsung-SPN4235-TVs-review-manual/id/275bh940/t/1-2/
www.scribd.com/doc/.../LG-TV-Plasma-Training-Manual
http://forum.electromaniacs.com/topic/6146-samsung-samsung-plasma-training-manual-ppt-zip/
Please find service manual and a user manual above. You most likely have a switchmode power supply problem, the PSU, is shutting down, for safety reasons, due to a fault, that may cause a fire and explosion or both. use these manuals to isolate your problem
May 23, 2010 | Samsung SPN4235 42 in. Plasma HDTV
Flashing picture
Could be the power supply or the main display driver board that is failing. These sets are service by swapping out the defective modules. You should contact the tech support for your TV to find out where to take it for service.
Jerry G.
May 12, 2010 | Sanyo DP50747 50 in. Plasma TV
I.Needs the codes for remote control one for all model URC 3220 to work at Sanyo Plasma Tv
I can help you to program your One for All Big Easy URC-3220 Universal Remote for your Sanyo Plasma TV.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
I hope that helps.
Jan 28, 2010 | Sanyo DP32746 32 in. LCD Television
I have a sanyo plasma tv that turns on then turns off. Tv repairman says it is power supply. I changed that but it did not fix it. I saw a posting that it is the V4 Y main board. I want to know if any one...
I am a military spouse and our same tv did the same thing on Super Bowl Sunday 2009! We did everything we know to do: call the company, called the repair man, etc. There apparently isn't a solution to this that wouldn't cost more than the tv is worth. So I got an attorney to start a class action:
If you would like to be compensated for your TV please contact me @
Danimimozi@gmail.com
Apr 30, 2009 | Sanyo DP42746 42 in. Plasma Television
Sanyo DP50747 50" Plasma sound but no picture green light is on.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Apr 25, 2017 | Sanyo DP50747 50 in. Plasma TV
Panasonic Plasma TV Repair info
Hi rob,
Please provide the service manual to easy find the correct service manual you want. Or you can try to these site to get free plasma tv repair service manual:
http://www.fastrepairguide.com
http://www.plasma-television-repair.com
Hope this will help you to get what you want.
Have a nice day,
Ken
Mar 31, 2008 | Televison & Video
Closed captioning
The closed captioning decoder circuit in your TV set may not be working, or the closed captioning information from the station may not be present. Start investigating by finding out if there is actualy closed caption from the station that you are tuned in to. If so, then call the tech support for your set to know if there is something that you missed in the set-up for the closed captioning. It may be very simple. If all of this does not work, then the closed captioning decoder in the set may not be working properly and require service.
Jerry G.
Jan 06, 2008 | Sanyo DP42746 42 in. Plasma Television
Sanyo DP42746 42 in. Plasma Television Logo
227 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
