No boot disk error when hard drive disconnected
I'm having trouble booting to a Win XP OS installed on a hard drive. Every time I start the computer up, the BIOS screen flashes, and then it stops responding at a black screen with the white cursor blinking at the top. I know the hard disk has an OS installed, as I hooked it up to a working comp and checked it out.
The strange thing is, when I disconnected the hard disk from the computer I'm trying to get to boot, when I start it up without anything for it to read an OS from, it does the exact same thing as when the hard disk is connected. This seems like a hardware issue, but which hardware could it be?
  • Xgamer4 Nov 02, 2008
    Set the hard disk jumper to master and I can finally get to the safe mode prompt, thanks!
  • Latanya Johnson Feb 16, 2009
    On December 10, 2008, i purchased one of my sisters, the DELL OPTIPLEX GX260 COMPLETE SYSTEM 2.4GHZ 512MB 60GB XP PS/2 from EBAY. What is happening now is that about after about a month, when we start to boot up up the GX260 system, it takes a while for the sytem to boot up. I will press buttons but nothing happens. There is this dark blue screen that stays on for about 10-15 minutes with cursor in the top left hand corner just blinking. Now after about 10-15 minutes the Window bar screen will come up. Sometimes it will show the operating system info or will just go to the sign in page. Dell is saying that the files has been corrupted and that memory needs to be restored by formatting the system and reinstalling the operating system by using a restore cd. I do not want to do and this is not the problem. Is there any other way to fix this without formatting this computer. My sister has just been excepting this problem and just sits and waits for the system to come up. She do not want to format this computer. Please assist me with any solutions. Thank you. 2/16/09 3:10AM CST. Tanyaj.
    Master:
  • 409 Answers
Are you making the disk the "master" device when you plug it in to the PC?
Posted on Nov 02, 2008
Hello, ive just bought a brand new motherboard (GS7610 ULTRA) and i have installed it into my case with all my components and when i go to start my computer up, it goes pasted the boot menu and then i get...
Are you trying to install this OS (Operating System) , or is it already installed on a hard drive?
If you are installing it, make sure you change the boot order to the optical drive (DVD drive). If it's already installed, was it installed with an OEM disk? If yes, then you might need a new Windows XP disc. This is because, when using an OEM disc, if you change the hard drive or motherboard, it doesn't really work.
Sep 24, 2011 | EliteGroup GS7610 ULTRA Motherboard
Mine hitachi hard disk is 80GB SATA i cant able to install OS because it is showing error some virus found and u r not able to formate this. first when i put OS CD in drive it will install some files and...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Apr 15, 2011 | Hitachi (14R9464-20PK) 250 GB Hard Drive
I use hp nx9010, i want to re-install windows xp but any time i try, the machine shutdown. sometimes is able to move up to copping files sometimes not then shutdown; i don't understand why is only windows...
well that is so easy to answer,
first off you are not using real HP disks are you.
sure. its old Blue Microsoft disks right,
and when you do that wrong, you get no HP chip drivers and lost more missing, even top row, fn keys dead, not just audio.
XP is a dead OS. for 3 years now, zero updates and is now a virus magnet extream.
nx9010 note book shuts down, all 3 os install different. !
old XP runs a very old and very DUMBB seteup.,exe
the newer OS run WINPE for setup.exe. vastly better and boots and loads the OS totally different.
Xp can be installed many ways, not one stated by you.
1-insert, HP install disk in CDROM drive and click, setup.exe running in a XP explorer window, live install
2: boot to HP install disk.
3: boot and hit F11 run HPs on HDD restore partition.
4: same as a above 1, or 2, but is Micro soft disk (wrong, you did it wrong, do not use mS disk) if must ask how, its a long long long story. ive done it all ways, 1000s of time. now since first PC.s ever.
if booting to XP , right or wrong CD. (its a CD right<)> or a stick
that too not stated,
it boots and you answer questions, then it starts copying
if it stalls that means, the CD is bad.
or PC is bad, you do know there are 3million transistors here to fail right? bad HDD, bad Mobo, and more. lots more
even the CPU can over heat and will shut down.
Personally I avoid all CD nows, they sux'd then and do now more.
make and ISO of your CD, (ask its easy and free)
then burn the ISO to a 4GB or bigger uSB memory stick using free RUFUS app.
boot to stick. on my HP hit F9 and pick Udisk USB. boot
bingo no more CD errors ever again.
i bet bad CD. seen it vast times, endless , but not today. too savvy now. to mess with any CD, if you copy it to ISO and get CRC errors
its a bad CD.
end pain.
the problem with real old PC most cant boot to USB
or must be BIOS flashed updated to get that.
ill now ill try to learn what yours can or can not do.
lacking ,what is there now.
but id do this first. go in to BIOS BOOT PAGE
What is the default boot order? The default boot order settings for the computer are configured in the factory. The default boot order for HP notebook PCs is listed below.
  1. Floppy disk drive
  2. Optical drive (DVD, CD-ROM)
  3. Hard drive
  4. USB device (see this?) bingo, can boot and install any OS here
  5. Network adapter
Apr 23, 2017 | HP NX9010: Pentium 4-2.4 GHZ, 512MB...
My laptop not booting.error shows "internal hard disk disk not found" servral times i resarted my laptop same error will come.i had XP OS. i tired to reintall the OS same error will come. pl...
The hard drive has probably failed to the point where the computer cannot even tell that it is installed...you will need to get a new hard drive...there should be a cover for the drive on the bottom of the laptop(it may have a small cylinder symbol on it). remove the screw to gain access to the hard disc...some models you have to unscrew 1-2 screws to remove the drive and some models have a clip like thing that holds it in...remove the drive and take it to a place like best buy..show it to one of their computer guys and they will assist you in getting the right one ...then you will have to re-install the drive...and then reinstall win xp or your choice of OS
Jan 17, 2011 | Dell Inspiron 1545 Notebook
Have Thinkcentre which boots in Win 7 and 2 Win XP
Try to re-install 2 Operating systems use this order,
1,Install windows XP by booting the XP cd,
2,and then install Win 7 by booting from Win 7 cd.
Then while you restart computer there will be a prompt menu asking to select OS to start. Thanks
Jul 25, 2010 | Lenovo ThinkCentre M57 Desktop - Intel...
How can i remove windows 7 starter and install windows xp
Boot to you bios and make sure you can boot off your dvd rom first. boot off you win xp disk and follow the instructions.
First locate drivers that are compatible with your computer and win xp.
Apr 06, 2010 | Acer Aspire One PC Notebook
Disk boot failure error while booting
What does it says???Cant find hard drive or what???
Jul 18, 2008 | Compaq Presario 700 470024-192 Notebook
Win vista uninstall
Put your window XP disk into the Disk drive. Start up your computer. When it asks you what Drive you want to install it on select C:\ (where Vista is) Say yes to deleting the current Operating System and follow the instructions from there.
You did say you wanted to Uninstall Vista!
If you mean Dual Boot Vista and XP, then you will need to create a Logical Partition of about 10 Gb to install XP on and when asked where to install select this partition. But note that XP will wipe the Boot sector clean of all other Operating Systems which means that if you want to Dual boot then you will have to reinstall Vista again to get Dual Boot functionality.
Apr 14, 2008 | Computers & Internet
PC halts while formatting hard drive
make sure your hard disk is error free Try formating the disk with FAT first ,if it doesn't work out the try disk utilities .
Nov 29, 2007 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
206 people viewed this question
David Payne
David Payne
