Table Saws
Problem for Table Saws
Generic problem for all Table Saws
On/off switch table saw
By robersonnc on Nov 02, 2008
Ihave a 10 in. table saw (Delta 110 volt). I replaced the switch but it keeps tripping the breaker. I tried several switches but with the same results. I can straight wire the motor and it runs. I am familiar with simple wiring but this has me stumped. Please e-mail if you have any suggestions? Thanks,Earl robersonnc@aol.com
Same Problem
Mar 16, 2009
-   Similar problem. Breaker trips motor when under the slightest of loads. I can reset the breaker after a few seconds and start up again, but it's impossible to cut anything for more than a few seconds. Blade is new, nothing is binding, plugged directly into 20 AMP dedicated circuit. Any ideas what's wrong?-   roblan
Feb 28, 2009
-   I also have a problem with the wiring on my 36-979 switch. I removed the switch and lost my wiring sketch, can you help? -   Don Kurz
Dec 01, 2008
-   I have the same problem; almost brand new table saw and it keeps tripping the breaker. It will run without load sometimes, other times it won't start and will simply sit idle with the motor straining to turn and then trip the breaker. Other times it will bind up under load.
It has been sitting idle in my shop while I was in Afghanistan, got back and now I am trying to fix it. -   Guest
Solution #1
posted on Feb 25, 2009
Somewhat Helpful)
Tooler1
Rank: Master
Rating: 75%, 6 votes
It sounds like you are wiring the switch wrong. Give me the model # and I will look for a wiring diagram for you.
Was this helpful?
Yes
No
Popular Solutions for Table Saws
Questions and Unsolved Problems for Table Saws
Answer
work light not working on model 1800 dremel scroll saw
Answer
How do I wire a 440 volt motor for 220 volts. The cover plate does not have a diagram on it and I... (More)
Answer
I have a Craftmans table saw Model # 137.248880 that worked yesterday but today its like there is no... (More)
Answer
bolt that connects blade to table saw broken need new nut and bolt
Answer
I need to locate an owner's manual for an SWS table saw # 66630. I prefer a PDF file.
Describe your Table Saws problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Table Saw Experts
Top Garden & Power Tool Repairmen
in , MD
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
