Question about Acer Computers & Internet
I have an acer aspire L350 i want to restore it from the recovery partition but i dont know what to press to get to it please help
Ty very much
Posted on Nov 03, 2008
  • 903 Answers
When you first turned on your laptop from new, you should have been prompted to create back up disks of your system.
If you did not do this, then you can try the following.
Most models of Acer Aspire have recovery system capabilities.
When booting up press F2 to enter the bios. Make sure that D2D recovery system is enabled then exit and save the changes. Press Alt+F10 to enter recovery. If this does not work for you then contact Acer for replacement recovery disks.
I hope this helps
Posted on Nov 02, 2008
I want to restore the factory settings on my aspire v3-531 but i dont know where to start. can someone help me please?
Acer usually have a restoration drive. When the computer is first starting up press the F8 key this should give a set of different options. One of which should be repair. Then select restore.
Apr 12, 2013 | Computers & Internet
How to delete all my files and restore my acer 5336 aspire
Restoring from the Acer Aspire System Recovery partition is easy Most Aspires will have a second partition that can be used to restore if you do not have CD It is recommended that you make those CD when you first buy the laptop If you don t you run the risk of not being able to install Windows again if that second partition fails Restoring From The Acer Aspire System Recovery Partition Keep in mind that running the recovery will restore the computer to the way it was when you first brought it home Anything you added will be lost so make sure you have program disks passwords favorite websites photos, documents and anything else you need backed up before proceeding with the recovery of your Acer Aspire.Hard Disk Recovery should be enabled by default If it is not you may need to go into your system s BIOS by hitting F2 at boot and enable it under the Advanced tab Once Hard Disk Recovery is enabled, restart the system and hit ALT F10 This will begin restoring from the Aspire system recovery partition. You will be prompted to type six zeros as a security step Type 000000 to proceed You will then see a screen to select your Operating System. Do this and hit enter and the recovery process will begin You Cannot Use The Acer Aspire System Recovery Partition The process for restoring from the Acer Aspire System Recovery partition is similar with all major brand names The most important thing to remember is to always have backups of your data and take a few minutes to burn recovery DVDs using Acer s built in utility. Creating these backup DVD is vital If the hard drive fails you will not be able to perform a recovery from the Acer Aspire system recovery partition Create the media and store it in a safe place along with the rest of your software and computer documentation
Nov 04, 2011 | Acer Aspire AS5336-2524 Laptop
Hi Im trying to restore my acer aspire 5742 back to factory default in windows7. I do not know how to start the process, I have the recovery discs I took them the day I bought it. Can you help please....
Hi
Please save any files or photo,s that you may have on your laptop ist
Then you could try this method without using the disks
Click Start" menu
Click Programs
Click Acer Recovery Management
Click the Restore button on the bottom of the dialog box that opens
Click Restore System to Factory Default
Click Yes in the warning dialog box which asks if you wish to continue the recovery process
Click yes Start to restore the computer to the default factory settings
Sometimes there is a default acer password which is quite often 000000 that is 6 zero's
or place the recovery disk into your cd
restart the laptop pressing F12 i believe
then follow on screen instructions
many thanks
please let us know if this has helped you so that we can hopefully help others
Jun 19, 2011 | Acer Aspire 5742Z-4200 Notebook
How to do system recovery on aspire one
Hi you should be able to do the following, if not you will need an external CD drive & recovery disk.
1. Consider what data you still need from your Acer Aspire One's hard drive. Save the files to an external USB device.
2. Restart the Acer Aspire One's operating system. Wait for the Acer logo to appear on the LCD screen.
3. Press the "Alt" and "F10" keys at the same time to bring up the recovery menu. Press "Enter."
4. Click "Next." Follow the prompts that appear on the screen to restore the operating system back to factory settings.
5. Use the drop-down boxes to select the time zone and language information for your Acer Aspire One. Restart the netbook when you are prompted to finish restoring the computer.
6. Connect the external USB device to your Acer Aspire One and transfer the data you saved earlier back to the netbook.
Warning:
It is possible to delete the hard drive partition that has the recovery tool.
If your Acer Aspire One no longer has the recovery partition, you will need
to acquire an external USB DVD drive and then contact Acer for a recovery DVD.
Connect the USB drive to the netbook's USB port and then insert the recovery DVD in the drive.
Hope this helps.
Feb 14, 2011 | Acer Computers & Internet
I have a loptop of Acer Aspire5520.I have to formate now but i lost my system backup & restore disk.How can i get this backup.Pls let me know.
Normally , acer laptops have a hidden recovery partition on the hard drive , which contains all of the recovery data so you dont need the recovery discs.
When you boot up your computer and you get the Acer logo etc , try pressing keys to start the recovery - this puts everything back to factory default settings and erases your data.
Also , A program ships with the laptop called 'Acer Empowering Technology - eRecovery' which allows you to burn your own recovery disc - You then use this disc to perform a complete system restore.
Jan 22, 2009 | Acer Aspire 5520-5908 Notebook
Need Help
try this one:
if you knew that on the hidden partition contains all the drivers and the vista you will need to do system restore or system recovery
system restore:
-click start
-point to all programs
-click accessories
-click system restore
system recovery:
-restart your pc
-i dont know the unit of your laptop but there's a message on the screen (black screen) that says to press F8 to go to recovery (some of the computers tells to press F9 or F10, just follow which function key you will press that will appear on the screen
-click system recovery then follow the steps that will appear on the screen
hope this would help you solve your problem
Aug 16, 2008 | Acer Aspire 5610-4648 Notebook
Acer aspire 3680 problem (anyone help plese?)
if you haven't delete the recovery partition, you can reload the OS using alt+F10.
during boot (after acer logo), press alt+F10, it will guide you to reload your OS.
if your recovery partition is corrupt, you should call acer call center to get the cd or you can buy cd from microsoft
Jul 05, 2008 | Acer Aspire 3680 Laptop
Dont know how to restore factory settings
to restore OS (factory), there are 2 ways.
1. If you already create recovery disk, you can boot from disk and follow step by step.
2. I hope you haven't deleted the recovery partition in your hdd. If you haven't, Boot your computer, before it go to windows, press Alt+F10. it will go to recovery menu, this will wipe out your C drive.
otherway:
you can order recovery cd from acer, but they will charge you (i don't know how much).
Jun 08, 2008 | Acer Aspire 5050-3242 Notebook
Acer Aspire 5920 laptop, cannot invoke Alt-F10 when booting initially
just press alt f10 ONLY when you see acer logo on boot and hold for a sec i had the same problem and its all adout timming hope i help...
my acer a0751h
Feb 14, 2008 | Computers & Internet
Computers & Internet Logo
214 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
