Question about HP PSC 750 All-In-One InkJet Printer
Photo paper stops feeding
Photo paper enters but only goes through a inch and thewn stops. Keeps printing over same spot on photo paper then stops printing at all
    Scholar:
  • 121 Answers
Please verify that the main roller that is moving the paper out while its being printed upon is moving....if its not or it moves a bit verify that the gear teething are all intact at the gear assembly end....
check to see that you don't have worn out rollers.
Posted on Nov 10, 2008
HP Photosmart C6100 All-in-One
Just click below;
Set Up the Printer Hardware
Remove packing materials, check contents of the box, connect the power cord, set the menus, load paper, and install the print cartridges. s.gif » Product Specifications
Minimum system requirements, connectivity, print cartridges, specifications for print, copy, paper, print margins, paper tray capacity, memory card, scan, physical size, power, and ... s.gif » Printing Instructions for 4 x 12 and 5 x 7 Inch Paper
Generic printing instructions. s.gif » Creating Borderless Photo Prints with the HP All-in-One Software
... 4 by 6-inch photo paper with tab (snapshot paper) ... Remove the paper from the paper tray and load the snapshot paper. Insert tabbed paper with the perforated, tear-off ... Click Photo Prints . The HP Photo Prints window will appear. ..
hope this may help;
Regards,
VOTIT
Jul 31, 2008 | HP Photosmart C6100 All-In-One Printer
Samsung 1710 stops before printing
to fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
Oct 29, 2007 | Samsung ML 1710 Laser Printer
Epson c66 not feeding paper
Main reasons for a paper feed problem like the one you describe are:
-. One of the sensor actuators (normally It will be a little plastic lever on the path of the paper) is either broken or blocked. It could happend if you attempt to remove a paper in the opposite direction of the normal paper movement path. Check if you can see something like that near the point where the paper stops.
-. The second option will be dirt on the feed rollers. If you can remove them easily the you can try to clean them using water and soap. In that case what is happening is that the paper reaches the first sensor but the printer doesn't knows the paper is stuck until It detects that the paper arrives later than expected to the last sensor (a timing issue). As the printer keeps printing this is the most probable cause to your problem.
I don't know that model of printer in particular but I hope this serves you as a guide to pinpoint the issue.
Jul 07, 2012 | Epson Stylus C66 InkJet Photo Printer
False "paper jam" signal prevents printing: My HP 2210 had been working fine. Suddenly, when I try to print, the paper starts to feed for a few inches and then stops. I get a "clear paper jam" error...
it's probably due to what i would call the print head blocker ( on your left handside of your printer head) that is broken . check it out! it also responsable to control how far goes the sheet before start printing.
Jan 14, 2010 | HP PSC 2210 All-In-One InkJet Printer
The paper will not feed in all the way. it starts
The paper feed roller needs to be cleaned, you will have to take the printer in for a service.
Aug 04, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Photo paper stops feeding through about 1 inch from end
Regular paper feeds?
Then use a single sheet of photo paper at a time with nothing else in the tray
Use a ord processor to see if there is t software glitch
Jul 27, 2009 | HP DeskJet 950c InkJet Printer
Paper keeps feeding through and won't stop
Two possibilities;
One you have a messed up print job trying to print and when you turn the printer on the job just starts over.
Two the clutch that stops the pick roller is bad and the roller just keeps turning.
Unplug the machine from the computer and turn it off unplug power for awhile turn it back on not connected to the computer. If condition remains it is the clutch.
If condition goes away delete print jobs and re connect printer.
Hope this helps
Mar 26, 2009 | HP LaserJet 1300 Printer
Epson Stylus 580rx won't identify vellum paper
Ran into the same problem. The problem is that the printer's paper sensor sees through the vellum and therefore doesn't think any paper moved into the print position. To use vellum, fold up 1/4" edge on a standard peice of print paper and place the leading edge of the vellum under the flap. Place the paper and vellum into the printer and print. The printer will pull in the paper and the vellum together. Make the paper fold tight and straight to prevent jamming. You will need to feed one sheet at a time. Also the Epson inks take a long time to dry on vellum. I let mine dry overnight.
Jan 05, 2009 | Epson Stylus RX580 InkJet Photo Printer
HP PSC 750 All-In-One InkJet Printer Logo
85 people viewed this question
Seeker5211
Seeker5211
