If you have the ADF installed then you should have 2 document glass, the ADF uses the small one to scan the original, if this glass is dirty even a small dot will become a long line on the copy result. Clean this glass.
a client ask for p2 display in the machine, it´s a sharp am 900. Somebady help me what does...
(More)
a client ask for p2 display in the machine, it´s a sharp am 900. Somebady help me what does it mean.
I replaced splitter and wall jack because fax,copier sharing phone line with credit card machine.fax...
(More)
I replaced splitter and wall jack because fax,copier sharing phone line with credit card machine.fax is o.k.but credit card machine says''line busy''if I switch cords at the splitter port the credit card machine will work but then the fax does not.HOW can this be?they share the same line on a new splitter and wall jack.. thank you for your help
Screen reads Paper Jammed even tho there is no paper jammed in the machine. This is an older product...
(More)
Screen reads Paper Jammed even tho there is no paper jammed in the machine. This is an older product SharpUX-5l0A
