I have a AMCO TV, i bought a rca universal remote control (RCR312W). There is no code for my tv. and i need help to program it.
Slinteriors
  • 8617 Answers
SOURCE: US2-PM435S PHILIPS UNIVERSAL REMOTE, I
heres a link to the phillips universal remote site it has all the codes and programing instructions that you require.
Posted on Apr 10, 2008
ellis-y
  • 38 Answers
SOURCE: need to program a ge
here is the 3 digit codes ive found to try 586, 651, 720, 666, 731, 800
MAGNAVOX ............ 0062 0004 0009 for digit codes
........................... 0456 0183 0226 0288
........................... 0008 0068 0075 0141
Manually turn on the device (TV, VCR, DVD, etc.) you wish to
program.
2. Press and hold the CODE SEARCH/SETUP button on the remote
until the INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming
(TV, VCR, DVD, etc.). For AUX, press AUX then the device button
you are assigning to AUX. The INDICATOR LIGHT will blink then
remain lit.
4. Enter the three or four digit code for your device using the number
buttons in the GE Universal Remote. After your code is entered the
INDICATOR LIGHT will turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the
POWER button. Your device should turn off.
Note: If your device does not respond to the first code listed,
repeat steps with the next code. If none of the codes listed for your
device work for your device or your brand is not listed,
try the Code Search method described below.
USING CODE SEARCH FUNCTION
If your TV, VCR, DVD, etc. does not respond after you have tried all the codes
for your brand or if your brand is not listed, try searching for your codes by
following the steps below.
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR
3. Press and release the device button for the device you are
programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will
blink once then remain lit. For AUX, press AUX then the device
Posted on Jun 24, 2008
  • 133 Answers
SOURCE: I need a code #
I own a One-for-All universal remote, and my booklet says the setup code for a Prima TV ( without a built-in DVD or VCR) is one of the following numbers: 0761, 0783, 0815, 0817. I can not guarantee these numbers will work with your remote, but it is worth a try.
I assume your DVD has been attached separately, and not built into the TV. In some cases, you might not need an additional setup code. Once the TV has been turned on, you simply push the DVD button on your remote, to activate the DVD. The instructions which came with your remote and your DVD should provide you with more details. If the instructions indicate that an additional DVD setup code is required, then please respond by telling me the brand name of your DVD.
Posted on Jul 05, 2008
  • 54 Answers
SOURCE: need codes to control symphonic 27
  1. These instructions come from the RCA website. The crucial step is to keep pressing the reverse button.
  2. Turn on the component (the tv, dvd, etc).
  3. Hold the TV (or DVD) button and the on/off button at the same time. It will stay lit.
  4. Press the play button every five seconds until the component turns off.
    • Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
  5. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
  6. If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS UNTIL THE COMPONENT TURNS ON again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
    • If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
  7. To save the new code, press and release the STOP button.
  8. The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
Tips
  • Turn on TV
  • Hold in the TV button and the ON/OFF button until the ON/OFF button stays lit
  • Press the PLAY button every 5 seconds until the device turns off
  • Press the REVERSE button every 2 seconds until the device turns on
  • Press the STOP button to lock in the code...the remote should work now.
  • Important to press reverse button every 2 seconds, not just once.
Good Luck!!
Posted on Aug 18, 2008
SOURCE: programming rca universal remote for my toshiba tv
I can't exactly help you, but can you tell me how you programmed the remote to your TV, because I cannot get mine to work...
Posted on Sep 12, 2008
Need a universal remote control code for Hisense tv
Hello
Four digit universal remote codes for Hisense TV are:
0073 0182 0216
Five digit universal remote code for Hisense tV with RCA RCR312W remote control is:
10748
Dec 12, 2011 | Hisense LHDN32V66AUS 32 in. LCD TV
Lost RCA Universal Remote booklet for model RCR312W remote.
you need to supply the SONY TV model just do a google of any URC booklet and then look uo the ctrl codes for your TV it has little to do with the brand of the remote
please rate our help to keep service online
Aug 19, 2009 | Televison & Video
RCA Remote (RCR312W) Code for Sharp Television (19R-M100)
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
if this helps please give a fixya rating
Jul 14, 2009 | RCA 3-Device Universal Remote with...
Need to know "HOW TO" set up RCR312W
You have to hold the component button (TV) and enter the code from http://www.rca.com/codefinder. The SKU it asks for, on my RCR312W, was under the lid from the batteries. Hope it helps.
Feb 15, 2009 | RCA Universal Remote Control
I need code for zenith tv to program into rca remote #rcr312w
Hi cuddles3634!
For that remote, the tv codes are:
Zenith 1000, 1006, 1049, 1054, 1078, 1116, 1133, 1167, 1170, 1172, 1207, 1230
If the TV is digital: 1016
Hope that helps!
Jan 04, 2009 | RCA Universal Remote Control
Program the RCA#rcr312 universal remote control
hold the code search buttton until light comes on then select the device you are programing and enter code
Oct 22, 2008 | RCA Universal Remote Control
I NEED PROGRAM CODES AND PROCEDURES FOR RCR312W
I can help. I too have an RCR312W remote and it did not work.
I found this code on bobvila.com message board. The code from the RCR311W remote works.
1) turn on unit
2) press and hold componet button on remote (TV, VCR, etc)
until On/Off lights up
3) press and hold On/Off while holding component button. Light will go out. Continue hoding both buttons until light comes back on.
4) release both buttons. On/Off should stay on.
5) Press On/Off repeatedly until unit turns off.
6) Press the Stop key at bottom.
7) light goes off. Remote is programmed!
Oct 17, 2008 | RCA Universal Remote Control
NEED HELP PROGRAMING UNIVERSAL REMOTE CONTROL
rca d770 universal remote how do i program
Sep 03, 2008 | RCA Universal Remote Control
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
