Question about Maytag Performa PAV2200
Washer won't act right
I have a performa by maytag washer over 2 years and its been acting up lately. it will fill up with water then stop and won't do anything else after that. we let it sit for about 30 minutes to an hour and it start back up that is some of the time most of the time it jus sits there and does nothing. once it fills up with the water its threw, anyone know what i can do?
  • Anonymous Nov 09, 2008
    My washer is doing the same thing it goes through cycle till it get to drain and spin then it just sits there ...I cant afford to buy a new washer thought maytag was such a great product?
  • trishamercer Nov 14, 2008
    When i fill the washer it wont go throught the drain cycle. After that it wont do anything..Any suggestions?
  • 4 Answers
Most likely this is a problem with the main cycle knob, if for some reason the knob is not fully pulled
out, it just won't work, only fills with water, and the timer is the responsible one for the draining, but
the timer itself is not at fault, have your main knob selector switch checked.
Posted on Nov 12, 2008
Top load maytag performa washer won`t stop flling both on wash and rinse cycles.
The switch the tube connects to shuts the water off. Will it cut off on high medium or low level. You can try blowing on the tube to see if it works. It should cut off when you blow.
Oct 15, 2017 | Maytag Performa PAV2200
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Maytag washer performa is over filling with water.
Bad water level switch or pinched hose going to water level switch.
Feb 21, 2009 | Maytag Performa PAV2200
Maytag performa not recognizing when to stop filling with water
be sure the rubber hose runnig from the water level switch to the tub is conected on both ends if not conected to the tub the water will come out the hole the hose is supposed to be conected to and it want stop filling.
Jan 21, 2009 | Maytag Washing Machines
Maytag performa
does the water overflow from the waser. also try and fill the washer up with water and when you feel it should be filled to capacity shut the water off to the washer. and turn off the power. After you have done that turn the water back on and turn the power back on to the washer if the water stops running it could be your water valve and is easily replaced. if the water continues to run it could be the pressure switch (water level switch) or it could be a hole in the pressure switch hose.
Dec 30, 2008 | Maytag Performa PAV2200
Maytag performa pav2300
Just rehook the clear tube back onto the air dome (back right side of drum), drain any water from the drum, the refill, pressure switch will reset itself. Start to fill on small load size first, then move up when washer starts to be sure it reset all the sizes.
Aug 06, 2008 | Maytag Performa PAV2200
Maytag performa series washer
I purchased a Maytag Performa washer in 2003 and experienced the same thing. A service call found a loose electrical connection behind the switch panel. The washer has worked fine since.
Hope this helps.
May 28, 2008 | Maytag Performa PAV2200
Washer does not stop filling and it overflows!
check the pressure switch tube connectiong to the tub for a hole or crack first
Apr 23, 2008 | Maytag Performa LAT2500A
Maytag Washer overflowwing
I had the same problem. My whole basement flooded. Inside the back (you can see it thru a small hole 1/2 way up on right) a small white hose connects to the water shut off collection area. This hose carries the water from the tub to the collection area and tells the machine to cut off for the size of load selected. Mine had come undone and so the machine could not sense it was full and the water poured all out the bottom. I simply removed the small gray panel at the bottom on the back and reached up inside to reconnect.
Jan 26, 2008 | Maytag Performa PAV2200
Maytag Performa washer Waterlevel/agitator problem
CHECK your stand pipe hasn't fell over (the one the drain hose goes to when emptying)If not,Either the pressure switch is broke or there is a hole or split in the pressure switch rubber hose.This switch stops the water when it reaches required level.
Aug 15, 2007 | Maytag Performa PAV2200
Washing Machines Logo
124 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
