Question about Toshiba CN27V71 27" TV
TV turns on but no picture and only blinking remote LED senser?
When I turn on the TV, I get the high voltage static sound of the tube powering up, and the picture blinks slightly, enough to know there is power to the set,then only blank (black) screen, the remote control LED on the TV blinks once every 2 - 3 secs, after any where from 1 min to 15mins the picture actually comes on and I can use the set like there was nothing wrong, it actually works very well, it was and still is a very nice TV. Any help on this would be nice, thanks in advance!
    Sergeant:
  • 337 Answers
Try hitting the side of the set while you are waiting for the pix to turn on,dont over do it and see if the set reacts,if it does you will be looking for loose conections in the main board or crt board,these solder points need to be resoldered,if you are familiar with tv service it will be something you can do but if not be safe and call for help,the repair should not be expensive right now.
Posted on Sep 26, 2006
Samsung Plasma won't power on
this is not a capacitor problem. set is only 18 months old - has something to do with x y sustain boards not allowing smps to power on the high voltages.
May 27, 2013 | Samsung Televison & Video
Red LED Light Blinks 7 Times Tv Wont Turn On PLEASE HELP!
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
You must have through knowledge in electronics to proceed. This is a very skilled wor. You must have all measuring instruments, and ability to follow its schematic diagram.
Jun 12, 2012 | Sony KV-36XBR400 36" TV
When i turn on tv it blinks 7 times no raster and on sound you can hear the high voltage goes up to the picture tube and then stop
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
You have a power regulator fault and it shuts down to reduce the X radiation from the tube.
Check the 135Volt line!
Dec 24, 2010 | Sony Televison & Video
When i on the tv by remote the red standby light turns into green and i hear the tv sound but not picture and after a one or two second the green light turns into red. The tv goes into standby mode when i...
the high voltage or flyback transformer is not working.the sound runs off a separate fixed power supply.if you run your hand across the screen,is there static?that would mean the high voltage is ok but there is another circuit fault
Jul 08, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have a 50 inch rca tv model m50wh185 no picture but has sound
do u hear any high voltage static when you first turn on. possible high voltage problem with the high voltage splitter or focus pack. ussally when there a problem with these high voltage is being generated but not delevered to the tubes
Mar 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Problem with RCA TV Model 27F634T
You almost certainly have a bad picture tube. The green screen was from one of the elements inside shorting out. The static sound you're hearing is the high voltage arcing out through the end of the picture tube to other parts inside the set. It's more economical to buy a new TV than to repair this one.
Sorry to have such good news, but this is one of the ways a picture tube can go bad, and it happens quite often.
Mar 11, 2009 | RCA 27F634T TV
Sony KV36H5500 WEGA TV (flat screen tube) will not turn on
Pull the back Off Disconnect CRT board connected at End of picture tube then turn set on and see if it comes on with volume, high voltage you can feel front of tv for static elect.... Let me know what happens then i can tell you what is wrong with TV.
Dec 27, 2008 | Sony KV-32XBR85 TV
Blinking standby light on the front of tv...wont turn on no sound
They are dropping like flies -
Just posted this for the same set:
The sound; is it a click or a sharp snapping sound?
The first can be a relay turning on, the second is most likely related to a high voltage discharging.
If it is a relay, then the set could be trying to protect itself from an overload or the power supply has failed; the blinking ON LED is pointing toward that.
If it is a high voltage discharge (you may be able to see it through the vents in the rear housing) then it is possible that an accumulation of dust and household airborne contaminents has created a path that can be removed with some targeted cleaning.
Dec 04, 2008 | Sony KV-32S45 32" TV
Power up then off, no picture, blinking red LED
The high voltage does come up but the set goes into shutdown because is sensing a problem somewhere in the set,the shutdown circuit gets activated when the high voltage is too high, a problem in the horizontal deflection circuit or because there is a problem in the secondary of the output transformer,this transformer helps develop voltages supplies and if one is missing the set senses the problem and shutsdown,there is another possibility and is related to the picture tube,there is a resistor in the crt board ,it should measure 51 ohms only ,sometimes it opens up and gives you same symptom.If you are familiar with tv service you can check this resistor and be alert of the other possibilities,if you are not too familiar be safe and get assistance from a servicer. Let Us know how it goes,or if you need more information.
Oct 25, 2006 | Philips 32RF52S 32" TV
Turns on but not picture or sound. Power LED blinks
Your set might not be producing the high voltage it needs to light up the screen , it might be missing the supply voltage the supply volts to the output transistor ,if this voltage is missing is because the transistor is likely bad(shorted) and it has opened a fuse or a safety resistor.If you are familiar with tv service you have a place to check but you are not too familiar be safe and call a professional,high volts circuits are dangerous.
Oct 16, 2006 | Akai PT4298HD Rear Projection Television
Toshiba CN27V71 27" TV Logo
56 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
