Question about Asrock 775VM800 Motherboard
Swapped mother board
Hell swapped mother board to new case but can not power up the pc can you tell me how to connect the 8 pin power swith many thanks paul
    President:
  • 2,351 Answers
Hi Paul,
see page 8 number 15 for location. Than see page 19, System Panel Header in your manual.
The basic wire color's for positive are red, blue, green & can also be light blue, light green, light red.
Negative wires are usually white or black. Case wire colors do vary from case to case.
To see pin one shown on page 19, (positive + for hard drive led = HDLED+). Bottom row farthest pin to the left of set. Pin two is above pin one. Pin two is, PLED+ (known as power led). Pin 3 is to the right of pin one & is HDLED- (Hard drive led, negative). Pin 4 is above pin 3 & is also PLED-, (Negative for power led). ECT!
swapped mother board - 6781222.jpg If your new case has an internal speaker (Used for P.O.S.T, power on self test). This would connect to, Chassis Speaker Header located on page 8, number 16. Again, normally only two wires are used across the 4-pin connector. (One at each end of the connector).
To see ASRock's main site for the 775VM800 motherboard click this link:
http://www.asrock.com/mb/overview.asp?Model=775VM800&s=
Good luck Paul!
Run into a snag, just post the issue here.
Mike
Posted on Nov 03, 2008
I cant find where do i connect power switch there no slot indecated on the board help me pls.
Hello Friends,
If you are ask mother board power option. There are two power option every mother board, one option is SMPS power and sec option is Power Jumper. SMPS two power socket indicate 24 Pin and 4 pin also same option 24 pin and 4 pin socket available in mother board. Second option is 9 pin jumper socket hear connect to HDD power, reset power, cabinet power, power LED, and +5v DC. So you open PC and see all section and solved you problem.
Thanks.
Aug 22, 2013 | Gateway Computers & Internet
MB schematic for HP Pavillion 7960 desktop pc
it is wrote on the mother board... look in the front left hand cornor,youll see a bank of 8 sets of 2 pin conectors..the abriviations are...pw=powe swith..rs= reset ....pw led = front powere light...hdd led = hard drive led
Mar 12, 2012 | HP Pavilion 7960 PC Desktop
Just changed the mother board on a Dimension 4600. When I turn it on, everything powers up for a moment and then stops and the power light flashing green.
Usually a ram problem. Make sure the memory is correct for the board. Also, when you swapped cpu's were you sure no pins got bent? Make sure the 4 pin power is connected at the top. Make sure the cpu fan is 4 pin & connected.
Apr 07, 2011 | Computers & Internet
MOTHER BOARD NOT POWERING ON
I want you to try first swap the power supply box  of the PC if no change ?
go to the CPU socket remove the CPU check if any component is burnt that area if ok put a new CPU  then on it .
If still behaving the same ,then the mother board is bad get a new mother board
Good luck
Oct 01, 2009 | Foxconn P9657AA-8EKRS2H (6938279104065)...
No power to E-Machine T1860
hi,
Issue seems with the power IC of the motherboard need to repair.
May 29, 2009 | E-Machines T1860 PC Desktop
Please tell - the mercury mother board p1865d7 - how we connect the reset button and start button on mother board. please send the diagram. i could understand. thank q sir jitendra
OK, Here is a picture:
As you can see the Reset switch is connected to pins 5 & 7 and the Power switch is connected to pins 6 & 8.
This is directly from the manual. You can download it from:
http://www.mercury-pc.com/downloads_list.php?productid=684
The link is at the bottom of the page.
Thanks for using Fixya. A "Fixya" rating would be appreciated.
Jan 22, 2009 | Mercury KVM400M-U Motherboard
Installed an Upgrated Mother Brd,in my Hp Desktop Tower,but the power Switch receptacle in the New Mother Brd has 16 pns
You need to track the wires from the case front panel to thier locations: one will be your power switch, one your reset, one hard drive activity light, and one your power light. You want to note and label which light or switch they go to then go to the new motherboards manual and plan which wires need to go where.
the front panel switches : reset and power switch- these are momentary switches so it doesnt matter which way they go.
hard drive activity and power light- these should have a colored wire and a black or white. the colored wire will be your + side.
Nov 08, 2008 | Computers & Internet
New Problem
The manual you need will be on the board manufacturers web page, howevr I will bet you have the case power switch and perhaps the reset switch on the wrong pins on the mother board. To check this, remove the switch leads from the mother board, then use a small screw driver and bridge the pins on the mother board a pair at a time. All of these leads plug on to the board in a line and not across the two lines of pins. when you get the mother board to fire up by this method geet a torch and look closely alongside the pins you will see the letters PWR SW or RS SW. It does not matter what polarity these two sets of leads are plugged onto both will work. The LED lights on the case front will only work if the polarity is correct but it will not do any harm if they are backwords. On the board you should se two sets of pins marked HDD and PWR these are the led light pins you will know you have them right when the usual red and green lights are working at the front of your tower. Regards mistyman
Aug 15, 2007 | Balance CP4401 PC Desktop
Asrock 775VM800 Motherboard Logo
280 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
