"INF WRITE" message during recording
Hit record once, SP speed should record for 2 hours. Disc NOT full; only records about 15-17 minutes then stops and says "INF WRITE". Using new dvd-r discs. Does this sporadically. Will start again and record a while and stop again. Sometimes records non-stop just fine.
  • jimviviano May 12, 2009
    i have this problem on non copyright stuff. i get the error on the sony while recording but the disk will play on the computer and not on the SONY RDR-VX525 that i recorded it on which means that i could not finalize it. strange machine!
This is a copyright protection built in to these units. See page 3 of user manual under Copyright
Any program which is copyright protected will not record
Posted on Dec 17, 2008
I recently purchased the Toshiba DR570KU DVD recorder. I live and purchased this machine on a small Caribbean Island,and with respect to local people they have no technical knowledge of what they are...
Hi -
I'll try to explain without confusing you any further, but if anything doesn't make sense, please let me know. The instructions on page 79 are contradictory, which doesn't help very much. The upper part of the page suggests you can create extra space on a DVD+RW disc by deleting titles, while the lower part, in the grey box, states you cannot. The bottom part is actually correct.
I'll split this into two sections - blank/unused and used discs then explore a few scenarios.
Blank/unused discs
A DVD+RW is typically 4.7GB and will record approx. 2 hours of video in SP mode or 4 hours inLP mode. If you record more than one programme, they will appear consecutively in the disc editing menu, and shown as numbered blocks in the Title List. The last block shown will always be 'EMPTY', but the actual size of this block can be all or none of the total capacity of the disc.
If you insert a blank DVD+RW disc into the machine and view the title list, you will see this:
Although you can't 'record' to a block labelled EMPTY, this doesn't mean you cannot record to this disc. The blank space on the disc precedes the block labelled as 'EMPTY'.
If you then record one programme of 1 hour duration in SP mode. the title list will look like this:
Once again, although you can't 'record' to the block labelled EMPTY, this doesn't mean this disc is full or that you cannot record anything else on it. The next programme recorder will appear between title 1 and the 'empty' block - as long as there is sufficient space on the disc remaining to record the programme.
If you then record a second programme of 1 hour duration in SP mode. the title list will look like this:
This disc is now full as 2 hours of video has been recorded in SP mode. However, if you'd only recorded 1 hour in total for these 2 programmes, you would still be able to record another hour of video in SP to this disc. The additional programmes would appear between the last numbered title and the 'empty' block - until the disc is full.
The empty block is always present and you cannot 'get rid of it', but it doesn't mean the disc is full or cannot be recorded on.
Hopefully, this goes some way to explaining it, but I still need need to explain what happens with used / full discs when you want to delete programmes and re-record.
There is a maximum length for messages posted on FixYa and I may be getting close to this, so rather than break off in mid-flow, I will continue the explanation for used discs in another message below this one. I will do this right now, but it will probably take me 20 minutes or so to write part 2, so keep checking back. It will be less confusing if you hold any questions until I've written part 2, but I will be happy to answer any after that.
Regards,
BElectric
May 02, 2011 | Toshiba DR570 DVD Recorder
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
How do I select the recording speed "SP" mode on my Panasonic DMR-E55 DVD recorder
1 Press [< OPEN/CLOSE] on the main
unit to open the tray and insert a disc.
≥Press the button again to close the tray.
2 Press [W X CH] to select the channel.
To select with the numbered buttons:
3 Press [REC MODE] to select the
recording mode (XP, SP, LP or EP).
4 Press [¥ REC] to start recording.
Recording will take place on open space on disc. Data will not
be overwritten.
≥You cannot change the channel or recording mode during
recording.
≥[RAM] You can change the audio being received by pressing
[AUDIO] during recording. (Does not affect the recording of
audio.)
Feb 02, 2010 | Panasonic DMR-E55 DVD Recorder
EVERYTHING YOU NEED IS IN MY LETTER BELOW.
1. On your remote, find the record mode button; it is near the bottom on the left side. This button sets
the recording speed for the DVR. Faster recording speeds provide higher quality recordings.
2. Look at the display on the front of the machine: it should say XP ( records 1 hour on the disc,)
SP ( 2 hours, ) LP ( 4 hours, ) or EP ( 6 hours. ) You can also set it to record 8 hours on a disc,
but the quality of the recording will be poor.
3 Press the record mode button until the screen displays the recording speed that you want.
4 Note: if the powers fails or the Machine is unplugged, the machine will automatically reset itself to
SP mode.
Apr 29, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
DSR 11 won't record DV tape to its end
You need to use longer tapes. The DER-11 is a DVCAM deck which when recording, uses a faster tape speed then mini DV. Think of your older VCR's. They had SP, two hours, and EP or SLP, which would be six hours. The SP speed would give a better picture. DVCAM is more like an SP recording except digital and a lot better. More information is laid down on the tape.
You'll have to jump up to the full size DVCAM tapes in order to record the full hour.
Apr 10, 2009 | Sony DSR-11 DV / Mini DV VCR
Limited recording time
WS-100: 64 MB
HQ mode: Approx. 4 hours 20 minutes
SP mode: Approx. 8 hours 40 minutes
LP mode: Approx. 27 hours 20 minutes
You can go to the menu of the device and change the recording mode from HQ to SP to get longer recording time. Page 7 of the instructions explains how to change this.
Mar 19, 2009 | Olympus WS-100 Digital Voice Recorder
How to switch the tape speed on Go Video dvd/tape.
  1. Press SETUP,
  2. Toggle with the left/right arrow to the RECORDING OPTIONS (icon has a dot and the letters REC below it in the icon menus at the top of the set up screen.)
  3. While RECORDING options is selected, press the DOWN arrow to select VCR RECORD QUALITY.
  4. Press ENTER to go to the submenu.
  5. Use the ARROW UP/DOWN buttons to select the desired quality.
  6. Press ENTER to confirm selection.
  7. Press SETUP to exit the menu.
This is the same procedure for selecting the quality for the DVR recording speeds.
VHS speeds are:
SLP is 3x the recording time of SP.
DVR recording options are:
HQ=1 hour
SP=2 hours
EP=4 hours
SLP=6 hours
per disc.
Mar 18, 2009 | GoVideo VR3845 DVD Recorder/VCR
Changing from sp to ep
it will automatically play at the speed the tape was recorded at. but if you want to change record speeds here's how: you should be able to access menu functions from the front of the vcr, if so, put a tape to be recorded into the unit and then set the timer for a couple of minutes.while you are on the timer menu it will ask you for recording speed. set the timer record speed to ep and let it record for two minutes and let it record for the full time untill it stops recording. the record speed will automatically change settings to whatever you used last on timer record.
May 01, 2008 | Sharp VC-A560U VHS VCR
Dub VHS to DVD
I am not sure why the DVD recorder is stopping after 25 mins of recording. However, once a disk is finalized all the remaining space is unrecordable. That is why your computer is showing the disk as full. The same applies when finalizing a CD. As for the first problem, check to see what record speed you are using. XP is 1 hr, SP 2hr and so on. But stopping after 25 minutes is weird. Even if you use a quick record button, (aka OTR) the recording is usually done in 30 minute increments. Try it again. If it still is only recording for 25 minutes, you may want to contact the manufacture's customer service or tech support. Hope it helps.
Mar 23, 2008 | Zenith XBR716
Recording from the hard drive
you have to choos the sp mode which is over 2 hours in recording. i noticed that after you set it in sp mode and you press the record button on the recorder panel more than once, the recording time changes.
Feb 25, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Televison & Video Logo
892 people viewed this question
Top Televison & Video Experts
Electro Med Services...
