Question about Maytag MMV4205 Microwave Oven
GE Profile Microwave
My daughter ran my microwave with nothing in it for 1 1/2 minutes. Now it will not work - no lights, no power, nothing.
What should I look at first?
Thanks
  • Maytag Master
  • 5,568 Answers
It may have a blown internal fuse.  The back covers on most ovens can be removed with a half-dozen screws and the fuse should be pretty easy to find inside but may be tougher to find as a replacement part.
Running a microwave (or any magnetron) without having a load (a place for the power to go) causes a near 100% reflection of the power back to the maggie; not a healthy situation. Because of the physics governing transfer of power, the magnetron dissipates half of the power in heat anyhow and making it eat the other half too can be fatal for most and it may be shorted. Magnetrons as replacement parts are not costly (any more) but in my experience, they are also inferior to the original and there is no way to tell before they are installed and operating. If they are not as capable as the original, you will notice a distinct 'slow-down' in its heating capacity.
Posted on Nov 02, 2008
GE Profile Microwave, model JES2251SJ02, just stopped working.
1= reset the c.breaker from your home see if are tripped and reset.
2= open for thermal fuse open, test continuity with DVOM OR VOM and replace.
3) test the power cord for open or broken or break.
4= check the switch for door maybe is open must be continuity until 0 , or swtich defective see the diagram attached. God bless you
Jul 13, 2012 | Microwave Ovens
My GE Profile over range microwave spacemaker xl 1800 model jvm1870bf02 was working just perfect until my daughter decided to use the microwave as a timer and actual ran the microwave with nothing inside...
Magnetron is blown.
This high-energy microwave-transmitting device hides behind a small plate on side of oven.
The waveguide sticky-out part looks like a small tube.
Normally, water molecules absorb the energy, heating the food.
Without an absorbing 'load' inside the oven cavity, the high-frequency, high power energy bounces back into the magnetron and it destroys itself. (Magnetron Hari-Kiri).
In a nutshell, tech must renew magnetron.
Then iInstruct family members to never run it empty.
Oct 11, 2017 | GE JVM1850 1000 Watts Microwave Oven
Change inside microwave light GE profile microwave
open the screw and then full out the side and top cover
Apr 21, 2010 | GE JNM1851SMSS Convection/Microwave Oven
Microwave was ran for 5 minutes with nothin in it now no display
most have an internal fuse check it first if that is not it check the thermal fuse both parts run 10-15 dollars
Jun 30, 2009 | Maytag MMV4205 Microwave Oven
I have a GE JE 1860. Someone ran the microwave for 15 minutes with nothing in it. Now it doesn't work at all , no power, no lights, nothing. Is there a fuse that may have gotten burned out? Is this...
There is a fuse and cavity thermal fuses as well as one on the magnatron that is supposed to reset itself.. The fuse is behind the control panel and the cavity fuses will require removal of the cabinet. Did you check for power at the plug?
Eric
Jun 20, 2009 | GE JE1860 Microwave Oven
Microwave was working fine. Suddenly stopped.
First thing to try is to check the power point.
If there is power there, but still no activity when you turn it on, no display no lights, it will need to be taken in for service. Sorry for the bad news but hopefully it's just the circuit breaker for your power point.
Apr 26, 2009 | General Electric Microwave Oven
Microwave will not heat food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
wsw
Oct 09, 2008 | GE JVM1640 Microwave Oven
Maytag MMV4205 Microwave Oven Logo
55 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
