Question about Singer Featherweight 132Q Mechanical Sewing Machine
Bottom threads are big loops
I have a Singer Merritt 3130, but no manuals. I have threaded the machine and the bobbin as correctly as I know using some on-line pictures and descriptions. However, my top stiching is fine, but the bottom stiches are nothing but big loops. Any help is appreciated.
I had the same issue! Check the little tray that holds the bobbin. I got very very frustrated with my machine, and even put it away for a year and a half. Look at the diagram of this part in the manual (you can get them at http://www.singerco.com/accessories/manuals.html free) and see if your looks exactly the same. Mine came (I don't see how it could have gotten jostled on it's own!) turned about 45 degrees counter-clockwise from how it's supposed to be. I unscrewed the metal plate - just removing the little plastic door to the bobbin area doesn't work - lifted out the tray (easy), turned it, and put it back in. Now the machine works perfectly! (as perfectly as can be hoped for a beginning sewer ...) I hope this works for you, too. Maybe a bad batch came from the factory?
Posted on Dec 18, 2008
    Scholar:
  • 110 Answers
Your problem is the top thread. Make sure you lift the presser lever BEFORE you thread the machine. After threading the machine, just before you thread the needle, lower the presser foot, and test the top tension by pulling down on the thead. If there is little or no tension, adjust the top tension to a higher number, say from 3 to 5, or from 5 to 7, and test the tension again. If you fail to increase the tension by above procedure, look for cotton that might be stuck in the tension blades and remove it. Hope this will help you
Posted on Nov 03, 2008
Singer 328K is jamming.
Most likely there are jamming threads at bobbin room under the machine stepping pedal, try to dismantle it to get rid of these threads.
Sep 22, 2017 | Singer Sewing Machines
How to thread singer merritt 3130?
Do you have a manual? If not, you can download one from singerco.com. It sounds like the top tension is too loose. Lowering the presser foot will engage the tension disks. The tension disks are located behind the needle thread tension dial. Slowly lower the presser foot, watching the tension disks press together. The thread passes between the tension disks around from the right, underneath and back up to the take up lever. The manual will tell you the location of these parts.
Mar 18, 2013 | Sewing Machines
I have a Singer 3140, and I have misplaced the book. I need to adjust the tension so that the threads are balanced, but have forgotten the correct procedure.
Get some scrap of the fabric you'll use.
Remember this phrase. Loops on bottom top tension too loose. Loops on top... top tension too tight. (or bobbin tension too loose)
In your case you need to loosen the top tension until you start to see loops on the bottom... then tighten it slightly.
Here's a manual for future reference
http://www.singerco.com/uploads/download/652_288-974-972-244-2405-588-875-1195-3130-3140.pdf
Jul 19, 2012 | Brother SE-270D Computerized Sewing...
SINGER MODEL 3130 WILL NOT STITCH CORRECTLY
Have you tried cleaning and oiling your sewing machine.Sometimes old thread gets caught up under the pressure foot near bobbin if not cleaned out the bottom teeth that pull material through will not move bobbin thread up to be caught by needle thread. P.S. Are you sure your using the right needle for the machine? To short of a needle will also cause this problem
Apr 10, 2012 | Sewing Machines
How to thread Singer merritt#9608? Probledm with birdnesting
what size bobbin and do you have pictures to show how to thread 9608 singer machine
Mar 10, 2012 | Singer Sewing Machines
Bobbin thread does not loop up when threading machine. Then the needle thread get wraped around the inside the bobbin sewing the material to the machine
There are so many thing you need to re-check.
First clean out the bobbin area to be sure there aren't any thread tangles still there.
Open the manual and start from the beginning with threading the machine with the presser foot lever UP - always.
Read the instructions and do not rely solely on the pictures as we all sometimes rush to do (I am just as guilty as the next person to do this).
Make sure the bobbin thread is feeding from the bobbin case in the correct direction.
Hold onto the end of the top thread (after needle has been threaded) and lower then raise the needle to catch and bring up the bobbin thread.
Place the fabric under the presser foot and as you hold onto the ends of the top and bobbin thread, hand walk the first stitch, then use the power pedal.
If you need a manual, you can download (free) from Singer - http://www.singerco.com/accessories/manuals.html
Mar 25, 2010 | Singer 8280 Mechanical Sewing Machine
Singer/merritt 2430 bobbin fill
If you lift up the thread holder, the bobbin holder is inside. Loosen the hand guide to stop the needle from going up and down. Pull the thread around the top thread guide and back into the bobbin holder. Thread the bobbin and move the bobbin over so the guage is "inside" the bobbin. As for the manual, the Singer Merritt 2404 is applicable to the 2430 if that helps.
Jun 18, 2009 | Janome 6019QC Mechanical Sewing Machine
Bottom thread loops
More than likely the Bobbin is not threaded correctly and the tension is not being controlled.  review the manual carefully, pay attention to the direction the thread is wound on the bobbin and place it in the case exactly as illustrated, feed the thread through the tension groove.
I would also advise returning to the bobbin to the factory setting and leave it there.
Jan 01, 2009 | Singer 3116 Simple
Singer Featherweight 132Q Mechanical Sewing Machine Logo
301 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
