Question about Fuji FinePix F20 Digital Camera
Faulty fujo f20 finepix digital acmera
Use wrong ac adaptor to charge my batteru , i used 9v instead of the original 4v?
would like to know which component went wrong
2 Suggested Answers
SOURCE: Lost AC Adaptor Fuji Finepix F20
My factory reconditioned outfit won't properly properly charge the battery in the camera. Everything seemed to be working but the battery would take very little charge and expired in minutes. Charging in the camera isn't that bright an idea anyway, so before I fought it out with Fuji over the warranty, I decided to see if everything else worked OK. I got a $10 external charger for the NP70 battery on EBay. While I was at it I got 2 spare batteries to keep charged, these were like $6 each and boasted higher capacity. Fantastic success. I may still fight out the issue with
Fuji but I can use this great little camera in the meantime. I may never need the spares though, the original battery is just fine and has lasted longer between charges than I expected. search for NP70 on Ebay.
Posted on Aug 24, 2008
Power supply
Yes you can, but there are 2 important considerations. One is if the adapter puts out AC or DC signal. Adapters may have the same plug on them and putting the wrong one on could permanently damage your equipment. The other thing to look for is amperage, or an A rating. You may see something like 9V DC 2A on an adapter. If you are replacing a damaged adapter, look on it before you try a new one. Most all adapters have printed on them, by the plug, what their voltage, amperage, and AC or DC output are. Try to get the closest possible match. If you are off a bit on the amperage, the equipment may still work, but may act sluggish, or not like it is powered up all of the way. You could still damage the equipment this way too, so do be careful.
Mar 20, 2014 | Behringer Audio Players & Recorders
Fuji jx520 wont charge
Your battery probably is in the wrong way.So take it out and look on the bottom of it.You will see 3 copper cubes.Next look in to the slot where the battery goes and you will see 3 metal wires.Now take your battery and carefully line up the copper slots with the metal wires.Then push the battery in and close the battery slot.And your done go plug it into your USB slot and you will see a white battery symbol and you will know that it is charging.
Simple fix for a simple problem.
Aug 29, 2012 | Fuji film FinePix Z70 JX520 JV200 Z900EXR...
FUJO A850 Internal Memory transfer
Use the Copy command in the playback menu (page 53 in the manual) to transfer images to/from internal memory.
Apr 26, 2012 | Fuji FinePix S700 Digital Camera
My finepix f20 is not being recognised when I plug
Do what the pros do...use a card reader instead of your camera.
Jan 30, 2010 | Fuji FinePix F20 Digital Camera
Batteries
I think you will find that one 9 volt battery would not last any time at all. the 6 AAs have a big capacity and that's why they use them, a little 9v battery is intended for low power equipment.
I see it is supplied with a 12v AC adaptor, if you connect a 12V battery via the adaptor socket you may get a longer run time if its a rechargable battery even better.
Jan 22, 2010 | Meade NIghtView NIght Vision Monocular
Finepix f20 to windows vista
Use a card reader to download your pictures to a folder you create on your desktop.
Oct 05, 2009 | Fuji FinePix F20 Digital Camera
Fuji Fine Pix Z5 battery won't charge
I had the same problem!! Try flipping the battery around and then charging it. It worked for me! Hope this helps!
Feb 22, 2008 | Fuji FinePix F20 Digital Camera
Battery Chargeing
I'm sorry, it will not. You will need to use the ac adapter to charge the battery. Here is Fuji's link to all about your F20:
http://www.fujifilmusa.com/JSP/
fuji/epartners/ServiceSupportProduct.jsp?prodcat=856005
Jan 12, 2008 | Fuji FinePix F20 Digital Camera
Go to a reputable Fuji supplier, or www.fujifilm.co.uk
Nov 05, 2007 | Fuji FinePix F20 Digital Camera
Camera Finepix not working
you have most likely fried the internal circuits of the camera. Buy a new one. The $100 will be well spent vs trying to fix this issue
Jul 28, 2007 | Fuji FinePix F20 Digital Camera
Fuji FinePix F20 Digital Camera Logo
44 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
