There is a good possibility your tv has a bad picture tube,the fact that is blurry and the age point to that conclusion,you should invest in a new television and prevent the waste of money on this one.
Hi There are three things that can cause this problem. Your lcd screen, t-con board or the signal board. Most likelly in your case since you say it's only half the screen it's going to be your t-con board. You can try removing it and cleaning all the contacts and replacing it see if that helps. If that doesn't help then replace it. If that does not solve it then it's going to be your screen.
Thats caused by a convergence failure. The Sony type 1 convergence repair kit from www.tvrepairworld.com will usually correct that issue the kit contains the components and the CD with repair instructions so you can repair yourself.
Howdy,
Sounds like the TV has lost the VIDEO and only has color. Make sure all the cables are secure and good. 2) Reset the TV by unplugging the TV or any BOX you have attached to TV. Unplug both from a/c for 3-5 minutes, plug back in and turn both on.
If no fix. Go to service Company that is Authorized and get an estimate, possible cost $450.00 +. Too many areas of concern to help you with particulars.
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
bad convergence amp ic http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html Sony Convergence http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/ http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
This is a Plasma TV set, there is no convergence adjustments on this set. the convergence adjustments are for tube type projection TV sets. You could have a few problems with your TV. You could have a bad color whell assembly, a bad light engine assy. or a problem with the main board. This is not a set a that some who is not trained on plasma TV sets should attempt to troubleshoot and or repair. depending on how old this set is, it may still be under warranty. if it is not, call out only a Samsung authorized servicer, as they will have the boards and proper tools to service this TV. Good Luck
That sounds like the screen and focus controls you are adjusting. It sounds like you have a bad HV Splitter inside the TV.
#205064
or
#204809
Depending on your model number.
http://www.matelectronics.com/acatalog/Mat_Electronics_Replacement_Parts___TV_134.html
sells them for about 20 bucks.
