Graphics card I have Intel D101GGC motherboard. Now I want to buy a graphics card because most games nowadays require high graphics e.g. fifa09. Which graphics card would suit my computer best. I have 1GB DDR RAM.
    Scholar:
  • 94 Answers
OK, Your motherboard has a 'PCI Express* x16 bus add-in card connector'. It should be the closest connector to your processor. You can buy a card from ebay quite cheaply. A card like this would be suitable ->EBay UK Auction<- You will find like cards on EBay US if you.re stateside.
Regards
Philip
Posted on Nov 03, 2008
Upgrading graphics quality on my pc.
There is a large range of graphics card on the market in both performance and prices to match.
The graphic card that suits your requirements depands upon what you want in terms of performance and the application that requires a particular level of graphic capability.
Check the software documentation or games program for the graphic card that is required to run with their program. Generally games programs that require photo realistic rendering require high end graphics cards.
You may select a graphic card that is a bit above your current requirements to cover for future requirements.
I suggest you Google search the Internet or go to your computer shop to see what is available that meets your requirements. You can spend a lot of money on a very high end graphics card when a lessor graphics card would still suit your requirements and not burn a hole in your pocket.
Jun 15, 2012 | Gigabyte Computers & Internet
Which Graphics card is supported for Intel D101GGC motherboard and how much capacity (512 or 1 GB or anything) can be supported with 1 GB DDR RAM
The graphics card's ram memory is independent of the system ram memory.
Doesn't matter if your computer system ram memory is DDR Sdram, and the graphics card has GDDR5 graphics ram memory, and 1GB of it.
(1024MB)
To expound;
Integrated, (Also known as OnBoard Graphics) Graphics borrows from the system resources. The Processor and Ram Memory.
A graphics card has it's own Processor.
The GPU. {Graphics Processing Unit}
http://en.wikipedia.org/wiki/GPU
A graphics card also has it's own ram memory. Graphics Ram Memory.
The best expansion slot for a graphics card on an Intel D101GGC motherboard is the PCI Express x16 expansion slot.
The motherboard chipset is an ATI Radeon Xpress 200 (For Intel)
The code name is RC410
The ATI RC410 chipset was brought out in March of 2005.
http://en.wikipedia.org/wiki/Comparison_of_ATI_chipsets#Comparison_of_Northbridges_2
In 2005 the PCI Express 1.1 technology was being used.
PCI Express 2.0 technology wasn't brought out until January of 2007.
Your motherboard's PCI Express x16 slot is using the PCI Express 1.1 technology.
http://en.wikipedia.org/wiki/PCI_Express
Can you use the newer PCI Express 2.0, or PCI Express 2.1 graphics cards?
YES
PCI Express 2.0, and PCI Express 2.1 is Backward Compatible with PCI Express 1.1
Will you get the full capability of the PCI Express 2.0 graphics card?
NO
BUT you won't notice either, trust me.
You can use a graphics card based on ATI or Nvidia.
Doesn't matter.
What does matter IMHO, is to buy the best graphics card for the money, and not purchase one that will
'Break the Bank'.
You have to read through all the hype, and the flashy advertising, and make a choice based on deductive reasoning and intelligent thought.
More 'Bang for the Buck'.
You also have to base what kind of Wattage your power supply puts out, and the maximum Amp's on the 12 Volt power rail. (Or combine the 12 Volt power rails, if multiple 12 Volt rails are used)
When you look at the graphics card you wish to purchase, look for the Minimum System Requirements.
The Power Supply minimum Wattage requirement will be listed.
If it is a real powerful graphics card, the minimum 12 Volt Amp's will be listed also.
Two examples;
1) http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6680896&CatId=3669
Scroll down to the > Specifications heading.
Read the bottom of the list > Minimum PSU Wattage Requirement > 400 Watts
A 400 Watt PSU (Power Supply Unit) will have at least 20 Amps on the 12 Volt power rail.
{It isn't listed in the minimum PSU requirements. This is a given}
[Is the above graphics card a decent card? You Betcha! 192 Stream Processors]
2) http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6463720&CatId=3669
Uses less power than a comparable Nvidia GPU based graphics card.
A 300 watt power supply will be just fine.
[Note*
The minimum power requirements set by the graphics card manufacturer, are based upon a test system build.
They use a test computer with a gamer motherboard, powerful Processor, lot's of Ram Memory, and the power required for their graphics card.
The minimum Wattage (And 12 Volt power rail Amperage) is Not just based upon what the graphics card will use.
For questions please post in a Comment.
Regards,
joecoolvette
Dec 07, 2010 | Intel D101GGC Motherboard
Suggest Compatible Graphics Card for my D101GGC Motherboard m/c.
that board uses a pcix vid card go here and select any of these or buy one from where ever you want. make sure it is a pci express (pcix) card not a pcix 2.0 your mobo does not support the 2.0 cards.
http://www.tigerdirect.com/applications/Category/guidedSearch.asp?CatId=28&sel=Detail;55_158_13067_13067
a little advise if you want to paly serious games you will want at LEAST a geforce 6800 or gretaer card. an excellent gaming card for the money is a 9800 gtx about $100 or so look here:
http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=9800+gtx
you do not need the 3d cards they are expensive just look at #3 in that list. a good card for decent price. i personally use a xfx 9800 gtx to game with. no problems and most games can have the grphics turned right up. where you will run into trouble is with your single core pntium 3.2. that will limit how much you can turn everything up as some of the graphics options for games are controlled by the processor believe it or not. but still i would get a 9800 gtx if it were my system
Jun 27, 2010 | Intel D101GGC Motherboard
I have 101ggc mother board i have graphics card but that board is not supported pci graphics card
All you can do is buy a compatible graphics card, If it does have a graphics port and it is not PCIe then check and see if it's AGP.
Mar 07, 2010 | Intel D101GGC Motherboard
Can I My motherboard support a PCI video card?
Hi there.
Your motherboard will support both kinds of Video card.
PCI is quite old and is only supported up to 128MB of video memory.
PCI Express is new technology and is by far the best card that you can buy giving you the best graphics experience and can support up to 1GB of graphics memory making it good for gaming.
Good luck and thanks for using FixYa!!
May 13, 2009 | Intel D101GGC Motherboard
Upgrade
moz-screenshot-3.jpgmoz-screenshot-4.jpgIt appears that there are two PCI Express slots on the MB, 1-1X and 1-16X. You should be able to put in a PCI Express video card. If you are going to be gaming, pick out one with more memory, but be prepared. More memory equals more money.
Good luck and let me know how it works out.
Feb 20, 2009 | Intel D101GGC Motherboard
Does the motherboard of model 102ggc2 have a graphics card slot..??? can nyone recommend which graphics card will be the best....?????
Hi there
The best graphics card this board supports is PCI Express card, you can buy anything up to 128MB - 1BG.
Good luck and thanks for using Fixya!!!
Feb 12, 2009 | Intel D101GGC Motherboard
Intel D101GGC Motherboard PCI Express compatibility issues........
i'm using NVIDIA GEFORCE 8600 GT on my d101ggc board and its working fine
Jun 30, 2008 | Intel D101GGC Motherboard
Motherboard Intel D101GGC no display
Hello dheyx, your Intel D101GGC board used an intergated ATI Radeon Xpress 200 graphics. If you lost display than you're intergated Radeon has died. Suggest you replace it with a
PCI-E X16 graphics card. The Intel D101GGC board does have an opened X16 PCI-E slot. Do not forget to change the bios video card setting. You want the board to see& load the PCI-E first.
Apr 24, 2008 | Intel D101GGC Motherboard
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
