Question about Samsung Digimax S630 Digital Camera
Samsung S630 Flash Problem
When I go to take an indoor picture using my Sansung, the flash does not go off. What is wrong?
TENGO UNA CAMARA S630 Y EL MODO FLASH NO FUNCIONA EN NINGUNA DE LAS MODALIDADES Q PONGO EMPIESA A PARPADEAR LA LUZ SUPERIOS A LA PANTALLA Y LA CAMARA NO RESPONDE..EN LA PANTALLA APARECE UN CODIGO Q DICE F7.1 O 2.8 Y ABAJO DA VALORES COMO 1/1500 O 0.7S INTENTE CAMBIARLOS SIGUIENDO LOS PASOS DEL MANUAL PERO NO LOGRO CONSEGUIR Q LA CAMARA FUNCIONE
Posted on Jan 31, 2013
  • 34 Answers
Does the flash fully charge?
If so, it may be that the flash tube is faulty and will require replacing.
This should be done by your authorised Samsung repair centre.
Posted on Nov 16, 2008
Flash doesn't work. Flash icon shows on screen but doesn't fire.
It is detecting it has enough light and not flashing. Look for an "indoor" or other appropriate mode for what you are shooting since most Samsung cameras have them. The flash will only go off when the camera thinks it is needed. Canon Cameras are useless indoors but Samsung's are pretty good indoors when you find the right setting. Their latest models have dozens of modes, most of which you will never use. They are just VERY slow to take pictures. It appears to be cheaper version of their WB250F I had for a while.
P.S. - Never drop a Sansung camera. They will chip and even get damaged from as little as a foot or so. I had one fall about a foot onto pavement and it was permanently ruined. Their older models also stop with lens out when the battery dies but the Galaxy Cam is finally smart enough to retract the lens before the battery dies. It alos does so when shutting down unlike the older models.
Apr 16, 2015 | Samsung ST-200 16 Megapixel Digital Camera...
My Samsung S630 Digital Camera doesn't flash after a series of picture taking. Now it fails to flash although I set in Manual mode and selected Flash manuall, but still t doesn't flash. What should I do?...
Hi there remove the memory card and reset the camera. Now turn on the camera with out the memory card and make the camera flash light ON mode and take a snap. If the flash not working after this setting, then you need to replace the flash tube. The flash tube is cut off and thats why its not working.
Feb 19, 2011 | Samsung Digimax S630 Digital Camera
Pictures I'm taking indoors always come out yellow, even when I use my flash. I am taking pictures in dept. stores. HELP!
Check your white balance....it may be on the wrong setting. Either use "auto WB" or if you're using flash, flash WB.
Nov 18, 2010 | Olympus FE-46 Digital Camera
My samsung s630 camera takes great pictures, but my flash will not work on any setting i choose please help
Dear Sir,
1.Please put your camera in manual mode or program mode after this select the flash option and then select fill in mode.
2.After this press the shutter button and hold it this will energize the flash and help to take the photo.
3.If these steps do not work then you will have to change the batteries.
Regards, Chandrachur
Nov 02, 2010 | Samsung Digimax S630 Digital Camera
My camera was dropped and since then it won't take pictures using the flash. The screen keeps saying "F 2.8 1/45" while the flash is charging, but never takes a picture. The camera takes pictures fine...
This means the flash or flash circuitry broke due to the drop. The camera will take pictures as long as the flash is not required. Only resolution is to have the camera repaired, which unfortunately may cost more than the camera is worth.
Apr 26, 2010 | Samsung Digimax S630 Digital Camera
My S630 Samsung shows a code on the screen evry time I try to take a picture. The code is F2.8 1/45 and the little eye on the left that indicates the flash blinks for a few seconds.
your carera is set on shutter priority,,,
change it to auto
what its telling you is,, its set at a lens opening of F2.8 ( thats wide open ,,,so little or no depth of field in photos) ,(and a shutter speed of 1.45 of a second?) witch means its realy dark were you are??
the little eye flashing tells you to use the flash,,,
i bet you have left it set on flash photos only?
switch it over to auto mode and out of flash mode!
Oct 28, 2009 | Samsung Digimax S630 Digital Camera
How to use selftimer on Samsung S630
Hey hpnotiq_babe,
Directions on how to set the self timer on this camera are on page 27 of your camera manual. I have included a link to a PDF download of your camera manual in case you need it. I have copied the instructions on how to set the self timer on your camera below. I hope this helps!
● Selecting the self-timer
1. Rotate the MODE DIAL to select a RECORDING
mode with the exception of VOICE RECORDING
mode.
2. Press the SELF-TIMER button until the desired
mode indicator displays on the LCD monitor.
A 10 second, 2 second or double self-timer icon
appears on the LCD monitor. In Movie Clip mode,
only the 10-second self-timer will work.
•2SEC self-timer ( )
: Pressing the shutter button will allow an
interval of 2 seconds before the image is
taken.
•10SEC self-timer ( )
interval of 10 seconds before the image is taken.
•Double self-timer ( )
: A picture will be taken after about 10 seconds and 2 seconds later a
second picture will be taken. When using the flash, the 2-second self-timer
may be delayed for longer than 2 seconds depending on the flash charge
time.
3. When you press the SHUTTER button, the picture will be taken after the
specified time has elapsed.
http://www.samsungcamera.com/customer/cus_main.asp?cat_uid=11
Sincerely,
Allan
Go Ahead. Use Us.
Jul 24, 2008 | Samsung Digimax S630 Digital Camera
Red eye button when I try to snap a picture
I believe that's your flash setting. Just press to the left of the Menu/OK button to change the flash setting.
Apr 03, 2008 | Samsung Digimax S630 Digital Camera
Flash
make sure that there is enough light on china or a picture and please off the flash and take a picture.
since the surfaces are very smooth,the flash automatically reflects.this is called reflection of light phenomenon in physics.
so,make sure that there is enough light and switch off the flash, while you are taking a picture of that.
Mar 30, 2008 | Samsung Digimax S630 Digital Camera
Can't get the camera to Flash
EXACT same problem. Tonight I tried to take a picture and heard a loud pop sound but I didn't think it was my camera... anyway it took the picture but didn't use the flash. Later, my sister went to take a picture with the flash and it made the same loud pop noise and now the camera wont work if the flash is on.
Jan 19, 2008 | Samsung Digimax S630 Digital Camera
Samsung Digimax S630 Digital Camera Logo
292 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
