I am trying to scan a document, but I have no ink in the printer so I keep getting error message UO51. At one time I was able to get around this and scan, but am unable to do it again. Please help!
I have a canon mx330 fax print and scan all in one printer
To scan without ink just hold the back button in after the ink message comes up it should eventually take you to the main menu then you can hit the scan button.
Sorry I meant the stop button not the back button
SOURCE: Printer won't recognise cartridges UO51
Hi there
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
Power off printer
Hold down STOP/RESET button then Press and Hold down Power button
Keep Power button down and Release STOP/RESET button
Release power button
Push STOP/RESET button twice
Wait 20-30 seconds - our LED showed Idle
Push STOP/RESET button four times
Push Power button twice
Power off
Next time the printer is started the waste count will have been reset.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: error message UO51
Are you using official Cannon cartridges or "ink refill" cartridges? Did you reset your ink levels in the software?
SOURCE: canon mp 145 scan not working ink catridge
Hi, The scanning unit is independent from printing unit. You can scan even with empty ink cartridges. At sametime, if you wanna copy documents, you need both scanning and copying units to work. Try reinstalling the Driver from the provided drive CD.
SOURCE: My canon mp540 doesn't scan
no other solution except one - replace emthy ink cartridge!
SOURCE: Canon MX330 - trying to use ADF. No doc inside on
Canon Pixma MX330, ADF error, Code : 2,103,0
Here's what I found. There were no stuck gears or pieces of plastic caught anywhere.
The ****** can still feed paper, except for (consistently) the last page -->error/stuck.
1) In order to CLEAR THE ERROR you need to do two things
a) & b):
a) Press OK, WITH THE HOOD OPEN, with a piece of paper loaded in the ADF, being careful to grab the paper manually as it comes out of the bottom of the hood.
b) Windex the strip of glass surface which sits under the ADF next to the platen. This needs to be done with attention to minute detail, and a bright LED flashlight; since ink smudges off of documents and collects on the glass with alarming frequency. The machine may think these smudges are caught/jammed paper.
2) In order to SCAN a stack of paper, add one blank sheet to the bottom of your document. This page will be the one that
fails to clear the ADF, generates an error, and must be manually cleared before the next job.
The rest of your pages will have already scanned.
Repeat Every Time You Use it
To scan without ink just hold the STOP BUTTON in after the ink message comes up it should eventually take you to the main menu then you can hit the scan button.
